Switching Tail lights
Discussion in 'Technical Chat' started by Delrivpilot, Oct 30, 2009.
  1. Oct 30, 2009 at 1:57 PM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I have an 06 and just bought the tails from an 09. I took off my tail light and it doesn't look like it is a simple switch out. Has anyone done this and can they give me a bit of help? Much appreciated!
  2. Oct 30, 2009 at 1:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You may need to use a Multi Meter to find what wires corelate to what. Shouldnt bee too hard, as each light only has 3 functions. Brake, Iluminate, and turn.
  3. Oct 30, 2009 at 2:00 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    ...It's plug and play dude.
    Twist the bulb holders out.
  4. Oct 30, 2009 at 2:01 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Dude, not plug and play. I just took off the old one and the wire connecter is totally diff:)
  5. Oct 30, 2009 at 2:01 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Ok, Chris, I'll look into that. Was hoping find someone on here who already did it. I know many have made the switch. Thanks for the advice
  6. Oct 30, 2009 at 2:03 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    That is weird, mine was plug and play going from 06 to 09. The plug is not the one you think, its the one attached to the tail light on a little black clippy thing.
    edit: What I mean by that is the one that looks like you unplug doesn't fit, follow the wiring harness to the taillight and there is another plug closer to the housing.
  7. Oct 30, 2009 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive never done it, so you might want to listen to Judy and Viet2100
  8. Oct 30, 2009 at 2:05 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Ok, Mom, let me take off my old one again and try disconnecting the wire and then going from there. If I can't figure it out, I will take a couple of shots of what I am looking at, and post them.. THanks for the advice
  9. Oct 30, 2009 at 2:08 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    sounds like a plan. :)
  10. Oct 30, 2009 at 2:14 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    I have '09 tails ;)
  11. Oct 30, 2009 at 2:18 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Call off the dogs!!! I got it. I got confused with the connection for the middle led light and the actual supply to the light. BUt, I looked a bit closer and you all said it could be done, and I just did it!!! Thanks everyone. Lovin the 09 lights on my Impulse Red. Will take a couple of shots in better light and post later. THnks!!!
  12. Oct 30, 2009 at 2:24 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
  13. Oct 30, 2009 at 2:44 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    New tail lights. Thanks again everyone for your input!
  14. Oct 30, 2009 at 6:56 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    :woot:
    Looks awesome!!!
