switching to 4hi while not moving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06SR5canada, Sep 23, 2011.
  1. Sep 23, 2011 at 8:35 AM
    06SR5canada
    06SR5canada [OP] Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Hey everyone, ive read, and experienced, that *most* of the time you cant switch to 4hi while your not moving?
    mine let me about 3 out of 7 tries, and this worries me because I usually use 2hi till i get stuck then go to 4hi to get unstuck (in snow)
    the fact I live on an acreage in the prairies and frequently wake up to 4 foot drifts surrounding my vehicle worries me :canada:
    why does it do this? my old 98 blazer would click twice then lock in EVERYTIME moving or not, and it was nice.
    so anyone have any suggestions or input? besides leaving it in 4hi all the time
    :rasta:
  2. Sep 23, 2011 at 8:37 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Just keep using it and it'll lock easier and easier.
    Mine will lock damn near every time now if I'm not moving. If it doesn't it just takes a few inches for it to engage.
    Same goes for my Rear Locker. That engages no matter what I'm doing now.
  3. Sep 23, 2011 at 8:44 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Even after you turn it into H4, it may not 'click in' until your tires rotate a bit. I also suggest if there is snow falling the night before, you engage the 4WD then and not wait to get stuck in it the next day. As said above, the more you use it... the happier the truck is!
  4. Sep 23, 2011 at 9:39 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    ^^if i did that id be in 4hi for 5-6 months straight :p
  5. Sep 23, 2011 at 10:34 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Just reverse put the truck in gear or reverse if you are in park. I have good luck jumping to neutral when this happens. It isn't a big worry, just turn the knob and start doing your thing, it will lock in. The more you use it the less it will happen...
  6. Sep 23, 2011 at 11:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    That's what she said :p
    If I put the truck in neutral, click it in 4Hi, if it doesnt' engage right away then when I put it in either D or R, it'll lock in.
  7. Sep 23, 2011 at 11:41 AM
    fatty ac1d
    fatty ac1d Well-Known Member
    Liberal, Kansas
    15 MGM DCSB SR5
    This.
    I can go from 4Hi>4Lo and then sometimes to Diff lock without moving an inch.
  8. Sep 23, 2011 at 12:14 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    dammit, why do they even bother with rear open diffs on a TRUCK?
  9. Sep 23, 2011 at 12:17 PM
    Pugga
    Massachusetts
    F-150 Mod
    Because for most people an open diff is perfectly adequate. I've got 2 open diffs and can get anywhere I need to go. :cool:
  10. Sep 23, 2011 at 12:23 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Mine will go into 4hi from 2wd easily. It's 4hi to 4lo that's touchy. I have to be stopped. Sometimes I have to bump forward to get it to go 4lo.
    Keep using it, It'll engage easier.
  11. Sep 24, 2011 at 2:13 AM
    dalsmthme
    Ithaca, NY
    You just need to take the load off the drive train, this isn't that big of a deal. Just be thankful you don't have to get out to lock in hubs... Although I miss those days....
