Switching to 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tlk29, Nov 17, 2024.
  1. Nov 17, 2024 at 8:40 PM
    Tlk29
    Tlk29 [OP] New Member
    2022 trd Tacoma
    Hello, I’ve had my truck for three years and we had our first crappy weather day. I put my truck into 4H and it felt like my steering wheel was fighting me staying straight or correcting one way or the other. I know that when you’re making a turn, they trucks feel weird but I don’t remember my truck feeling like this the last couple years. Am I just misremembering and this is normal or does it sound like somethings wrong?
  2. Nov 17, 2024 at 8:42 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Was this on dry pavement sections or on ice/snow?
    ConantTaco and Ricardo13x like this.
  3. Nov 17, 2024 at 8:48 PM
    Tlk29
    2022 trd Tacoma
    slushy/ wet/icy and a mix of straight and curvy roads
  4. Nov 17, 2024 at 8:48 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Remember 4H and 4L only to be used on loose, wet, snowy surfaces.
    ConantTaco likes this.
  5. Nov 17, 2024 at 8:49 PM
    Tlk29
    2022 trd Tacoma
    I meant 4 high, not low my bad! Either way, it wasn’t dry pavement
  6. Nov 17, 2024 at 8:51 PM
    Ricardo13x
    Upland, CA.
    Then it’s normal, probably it’s binding a bit on the driest areas you’ve come across if you were turning.
    Tlk29[OP] and Chew like this.
  7. Nov 17, 2024 at 9:22 PM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    If it's getting traction when turning even in snow, you will get the jerking reaction.
    Pretty common
    Ricardo13x likes this.
  8. Nov 17, 2024 at 9:34 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you don’t regularly exercise 4WD, you might want to change your Diff fluids early to see if it gets back to how you remember.
    Tlk29[OP] likes this.
  9. Nov 17, 2024 at 9:40 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    It is recommended to use 4WD at least 10 miles per month (that is the technical phrasing). Else things gum-up. You could do worse than change fluids in transfercase and both differentials now, and should hurt nothing.
    ConantTaco and Tlk29[OP] like this.
  10. Nov 17, 2024 at 9:47 PM
    Tlk29
    2022 trd Tacoma
    It wasn’t just turning, it was happening on totally straight roads and going around curves too. My truck was way out of alignment until a few months ago so I can’t figure out if I was just used to constantly fighting with where my truck was leaning towards or if this is new
  11. Nov 17, 2024 at 9:57 PM
    TA2016
    Oregon
    I exercise 4WD on straight roads after a first rain when the roads are slick. I don’t feel any jerking and sometimes forget it is in 4 Hi.
    35 years ago when I bought my first 4x4, I was not good about exercising 4WD. When I changed the front diff fluid it came out like sludge.
    My lesson learned was exercise 4WD and change fluids sooner than later.
  12. Nov 17, 2024 at 10:01 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Having the front axle locked in 4WD will affect the steering feel. If there are no concerning noises or anything (other than gear whine from the transfer case being engaged), it's probably normal.
  13. Nov 17, 2024 at 11:29 PM
    ConantTaco
    Dave
    Why was it out of alignment? Possibly the cause of your alignment issues caused other problems??
    Chew likes this.
