switching to 4x4 problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Nov 3, 2012.
  1. Nov 3, 2012 at 11:51 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    Hey guys
    Im having a small issue switching to 4x4 with my 07 if the truck is running and i turn the switch nothing will happen, if the truck is turned off but with the key in the on position my 4H will actuate and continue working once i start the truck, if i turn the switch back the 2H while the truck is running it will dissengage but it wont re-engage unless i turn the truck back off, so far ive tried cleaning the connector to the actuator but made no diffrence, any ideas guys?
    Thanks
  2. Nov 3, 2012 at 11:59 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Are you in nuetral?
  3. Nov 4, 2012 at 12:02 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    ive tried in drive and neutral still nothing
  4. Nov 4, 2012 at 12:39 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    the selecter swich may not be working on your dash.
  5. Nov 4, 2012 at 12:56 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I had this problem as well, and I fiddle fucked with the selector swicth until it worked.
  6. Nov 4, 2012 at 1:33 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Use a ford wrench... Er, i mean hammer. Force fixes everything.
    Sorry, I can't offer any advice on this. Ghosts in the electrical systems of vehicles these days are gettin rediculous.
  7. Nov 4, 2012 at 1:37 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Only for going into or out of L4 (Low Range) do you need to stop and put the auto tranny into N Neutral.
    H4 is shift on-the-fly, moving or stopped (it may not engage until you begin to roll, if stopped)...
  8. Nov 4, 2012 at 7:43 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    SOunds like you are having problems with your front actuator. This is a known problem that occurs when the truck has ever been through a few water crossings or gotten moisture built up over time. Try removing the actuator from the ADD front diff and taking out the screws. You can then pull the cover off the actuator and look inside. That should tell the story. SOmetimes there is water in there and that can make the actuator stop functioning. You can clean it out and make sure the connections in the solder are connected. If you hve checked this and still cant get it to work, you may have to change the actuator with a new one.
  9. Nov 4, 2012 at 7:43 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    so it wouldnt be the 4x4 actuator then?
  10. Nov 4, 2012 at 7:45 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    It most likely is, but sometimes you can clean it out and check the solder to make sure it is still connected before replacing it.
  11. Nov 4, 2012 at 7:58 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
  12. Nov 4, 2012 at 1:27 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
