Switching to all synthetic Castro oils?
Discussion in 'Technical Chat' started by JonasVoll, Jul 12, 2019.
  1. Jul 12, 2019 at 7:25 AM
    JonasVoll
    JonasVoll [OP] New Member
    Jonas
    Wichita, Kansas
    2009 Toyota Tacoma
    Hey all I am looking for some advice on switching, motor, front and rear difs, oil, transfer case, & auto transmission plus whatever I am forgetting.
    What about steering, brakes, ETC.
    I want to use the Castrol Full Synthetic products, In addition, anyone know how much of each to buy?
    2009 Tacoma 4x4 V6. Auto.
    Will order off Amazon!
    I forgot gaskets!
    Any better prices on Amazon?
    TH!
  2. Jul 12, 2019 at 7:26 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Brand doesn't matter, I get whatever is on sale.
    Lester Lugnut likes this.
  3. Jul 12, 2019 at 7:33 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    This, no such beast as 100% synthetic anyhow, only reason I use Mobil 1 is it is readily available and I use it in the R1 also.
    Easier to have only one type of oil for all the machines.
    TacomaSport86 likes this.
  4. Jul 12, 2019 at 11:21 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    oil is oil is oil is oil...……….
  5. Jul 12, 2019 at 11:28 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Quantities depend on what you want to do. Flush vs drain and fill. Goto “Mods & Tutorials”, these procedures are discussed in detail.
  6. Jul 15, 2019 at 6:59 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    For REAL 100% Full Synthetic ,use RED LINE,MOTUL,or AMSOIL Oils and Greases!Others are not real synthetics!
  7. Jul 16, 2019 at 5:54 AM
    Gixerkiller
    Dennis
    Taylor, TX
    There is no such animal as 100% synthetic oil for motor vehicles. ALL 100% synthetic oils are still base stocks of dead Dino grease.
    What makes a synthetic is ESTERS and other additives to highly refined base stock.
    Even your precious AMS oil is base stock oil.
    Full synthetic is a marketing gimmick and the stuff is no better than standard oil unless you live in Alaska.
  8. Jul 26, 2019 at 5:44 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Mobil 1 is one of many FULL SYNTHETIC oils.
    https://www.exxonmobil.com/en/basestocks/products If you review the basestocks used for the oil it becomes easier to understand.
    https://www.exxonmobilchemical.com/...hetic-base-stocks/synovation-series#synvideo1
    I use full synthetic oils in just about every engine I have. I have been doing that for more than 16 years. I also use full synthetics in the rear differentials. The exception is the 2004 Camry I picked up with 129000 miles. That car gets a synthetic blend at this time.
    Every vehicle I have gets 10,000 mile oil change intervals or 1 year. My 3 trucks have had this interval from brand new. They have all had Mobil 1 since the factory fill was dumped at 2000 miles or less.
    TartanEagle and StillNoPickles like this.
  9. Jul 26, 2019 at 5:57 AM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Full synthetic oil is a loose and unregulated term. While Mobil 1 is great oil, there are far more “synthetic” oils out there. Mobil 1 is a quality group 3 oil while there are higher quality ester based products on the market.
    OP:
    But for use in a Tacoma, it’s hardly going to matter much. I ran cheap Walmart Supertech Synthetic in both my 1st and 2nd gen. 1st gen has 305k miles and the 2nd gen had 257k miles, both with zero engine issues. Keep proper specs and amounts of fluids in the truck, and it’s going to take care of you.
    The Amsoil website also has a good database that shows fluid amounts for your vehicle.
    TartanEagle likes this.
  10. Jul 26, 2019 at 6:02 AM
    Gixerkiller
    Dennis
    Taylor, TX
    Full synthetic is applied only to the chemical additives. Base stocks are still petroleum, crude oil, natural gas, or even recycled oil.
    There is NO such animal as synthetic motor oil for motor vehicles. Group 3 and group 4 oils are still petroleum refined to a high standard then mixed and combined with whatever special stuff the company wants.
    Even tool making uses a “synthetic” oil like A-6 cutting oil, still has petroleum in it.
    I would say that dot 5 brake fluid is synthetic, but it is silicone based and I’m pretty sure it has some petroleum in it.
    Don’t believe the marketing hype.
    StillNoPickles likes this.
  11. Jul 26, 2019 at 6:20 AM
    sgtnewundies
    Eric
    14 trd sport red
    Research is your friend. Review the information provided its there. https://www.oilspecifications.org/articles/lubrication-glossary.php
    2. Synthetic oils surpass their mineral counterparts in lubrication, engine cleanliness and heat dissipation
    Synthetic oils are formulated from synthetic base stocks so their properties are exactly as they were designed in the lab. Mineral oils are formulated from mineral base stocks (refined crude oil), which are then enhanced with additives to improve their preexisting, subpar properties. Even though additives can significantly improve their properties, mineral oils can never achieve the same quality as synthetic oils
  12. Jul 26, 2019 at 6:39 AM
    sgtnewundies
    Eric
    14 trd sport red
    Another thing to remember here is 0w-20 is a synthetic oil. You have different variation of basestocks 1-3 is a mineral base. Synthetic is a whole different formulation. It gets complicated. This may help also: https://en.wikipedia.org/wiki/Petroleum
    https://mobiloil.com/en/article/car-maintenance/learn-about-motor-oil-facts/types-of-synthetic-oil
    "Where traditional mineral or conventional use refined crude oil (that stuff you find in the ground), synthetic oils consist of chemical compounds that are artificially made by breaking down and then rebuilding petroleum molecules. The end result is an oil containing specific molecules that are tailored to provide optimal lubrication properties."............
    The bottom line is you can research this as the information is endless. You can also view used oil analysis with the specific oils and determine if that is what you want to use. Most people don't hold onto their vehicles and researching oils for 16 years is probably of no benefit. However, if you are like me and hold onto them for a long, long time it may be of interest for you. Best of luck.
  13. Jul 26, 2019 at 8:26 AM
    Gixerkiller
    Dennis
    Taylor, TX
    this is the truth.
    https://en.wikipedia.org/wiki/Synthetic_oil
    https://www.idrivesafely.com/defensive-driving/trending/synthetic-oil-vs-conventional-oil
    https://www.valvoline.com/about-us/faq/synthetic-oil-myths
    https://lubeng.wordpress.com/2012/06/19/is-your-engine-oil-really-synthetic/
    https://blog.amsoil.com/are-all-synthetic-oil-groups-the-same-group-iii-vs-iv-vs-v/
    http://www.synlube.com/synthetic.html
    END THREAD
