Switching to synthetic at 93k...good or bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CNEDEER, Sep 22, 2011.
  1. Sep 22, 2011 at 7:20 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2015 DC SR5 4x4
    So I just bought an 06 tacoma with 93K, absolute best purchase I have ever made vehicle wise. I am hoping to switch to synthetic oil, just would like some feedback first as If I should do it or not. I've heard some on both sides of the debate as to whether its good or not. Whadda ya guys think?
  2. Sep 22, 2011 at 7:34 PM
    saugus
    saugus Well-Known Member
    Just do it. 7k changes. Don't skimp on the filter.
  3. Sep 22, 2011 at 7:36 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    eh... ive heard synthetic is a good starting point when the vehicle is new... and then swap to conventional then to hiugh mileage... and by no means if u care about the integrity and health of ur truck wait 7k miles? i change every 3k cuz i want it to last my .02
  4. Sep 22, 2011 at 8:24 PM
    CNEDEER
    2015 DC SR5 4x4
    Yea, I think the most I would wait is 4k miles, whether its synthetic or not. Just would like some feedback on anybody that has done or considering doing this?
  5. Sep 22, 2011 at 8:31 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I heard to start doing synthetic at the starting of the engines life. I don't know how good it would be for the engine or the benefit would be doing the change at that amount of km's.
  6. Sep 22, 2011 at 8:57 PM
    saugus
    There are 0 proven benefits to 3k oil changes aside from obsession. It is wasteful. The 2.7 has a 6.1 quart oil capacity. That gets pretty expensive fast.
  7. Sep 22, 2011 at 9:07 PM
    Crazyfrog
    Crazyfrog Well-Known Member
    Keith
    Monroe Ohio
    2010 TRD 4X4 DC
    OME 885's, Bilstien 5100, 2"AAL, Weathertechs, AVS visors, Access bed cover
    There is alot of info out there on synthetic oil, and the idea that you cant change from one to the other is bogus. If you want synthetic, put it in, and if you need to switch back to dino oil, do it. Google Amsoil and Royal purple, and you can find some really good info out there. Its more of an issue in the choice of filter than it is the actual oil.
    7500 miles between changes is pushing it, even if it is all highway. Style of driving plays a part in intervals. 5-6000 miles is plenty. (my .02)
  8. Sep 22, 2011 at 9:13 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    for what its worth i agree. I switched to mobile 1 full synthetic at 60k and i now have about 83k on my 06. No problems at all and i still change it out every 5k on the dime (i once went over to about 7k because i was traveling a ton and even though there were no signs of damage at all i was still having that feeling of "fuck my car is now going to blow up").
  9. Sep 23, 2011 at 4:29 AM
    JKD
    JKD Well-Known Member
    I used to freak out about long oil change intervals until I actually had the oil analyzed and the lab said the oil at 8,000 miles on my previous car was still perfectly fine. No values (viscosity, contaminants, additive package) outside of acceptable values, no wear indicators (copper, iron, etc.) outside of acceptable values.
    When warranty is over I'll start moving up in 2,500 mile increments until I find a good oil change interval for the Tacoma.
  10. Sep 23, 2011 at 4:45 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    I changed mine over to synthetic at 165,000 miles. I usually go 8k to 10k miles between changes and no problems at all. I've got 203,xxx miles on mine now. Runs like a top. I use Castrol syntec 5w-30 and toyota oil filters.
  11. Sep 23, 2011 at 4:55 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    You are fine swapping over, I think the only reason the myth even exists that you shouldn't switch to synthetic on an older vehicle is synthetic is thinner and therefore could leak?
    Meh, you will be fine.
  12. Sep 23, 2011 at 10:30 AM
    mknipp
    mknipp Well-Known Member
    I am in the same situation, just bought my first Taco and the odometer is getting ready to roll to 60k. I want to put synthetic in but have read since its a better,thinner oil, it can get through the seals causing leaks. I havent found much information as to when its safe or not, but have ready that at 100k, people see issues with leaks.
  13. Sep 23, 2011 at 10:35 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You can switch to synthetic oil at any time. If you experience leaks with synthetic, that in no way means the synthetic oil is causing problems...that means you had a bad seal to begin with, and conventional oil was masking the issue.
  14. Sep 23, 2011 at 10:38 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    There is no issue switching. Last time I checked, it still says 5w-30 on the bottle..... so it's not thinner.
  15. Sep 23, 2011 at 10:39 AM
    dalsmthme
    Ithaca, NY
    This is correct, the additive packages in the higher $$ synthetics often will loosen sludge blocking oil leak passages.
  16. Sep 23, 2011 at 11:56 AM
    CNEDEER
    2015 DC SR5 4x4
    Good info fellas. One of ya mentioned using the right kind of filter, what would you suggest?
  17. Sep 23, 2011 at 12:04 PM
    Crazyfrog
    Keith
    Monroe Ohio
    2010 TRD 4X4 DC
    I would stick with Toyota filters.
  18. Sep 23, 2011 at 12:04 PM
    dalsmthme
    Ithaca, NY
    OEM they are cheap and good quality filters
  19. Sep 23, 2011 at 12:12 PM
    saugus
    I got 14 of the dealer filters for about $4 each.
  20. Sep 23, 2011 at 12:18 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    it's oil, just put it in, you're engine knows what to do. i prefer synthetic myself
