Switching to synthetic blend from conventional oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Nov 17, 2019.
  1. Nov 17, 2019 at 5:44 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Getting ready to do an oil change and went to Walmart to pick up my Castrol GTX oil and found that it says that in the 5w 30 it is now a synthetic blend. Apparently it is called ultra clean. After doing some research the additive they put in it is synthetic. Which makes it a synthetic blend. My question is, is it OK to run synthetic blend if I have been running conventional oil all this time ?
    tacoglock19 likes this.
  2. Nov 17, 2019 at 5:56 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    why not a full synthetic ? just curious ?
    I buy Walmart Super Tech full syn 5w30 on line in 3 packs...$14 a jug shipped
  3. Nov 17, 2019 at 6:02 AM
    tacoglock19
    tacoglock19 Well-Known Member
    Jawja
    2019 Nissan Frontier SV V6 4x4
    Stock as shit!
    This has been long debated and I had the same question several years ago so I decided to ask a couple dealer service departments and ase mechanics. All of them said it was OK to switch without hesitation. Take that for what you will but I did it ten years ago and never looked back. The particular vehicle I did it on is still running and has no issues. I sold it to a buddy and he is still driving it to this day.
  4. Nov 17, 2019 at 6:09 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    As long as it meets the SAE standards required by the vehicles mfg; yes its ok.
  5. Nov 17, 2019 at 6:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    IMHO, if you are good with sticking with your oil change maintenance interval, the type of oil is not important. I change my oil around 3k miles and go with whatever is on sale. I switch back and forth between conventional, semi, and full synthetic all the time.
  6. Nov 17, 2019 at 7:22 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thanks guys for all your replys ! I have thought about going to full synthetic many of times. I have even done research on it but being old faction and then having some people tell me different issues they had I keep veering away from it. But I will readdress it once again. Thank you again for personal experiences. Much appreciated !
  7. Nov 17, 2019 at 7:35 AM
    Armed in Utah
    2003 Lexus LX 470
    Full syn....run it twice as long.......use a good filter.......call it good !
  8. Nov 17, 2019 at 7:38 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Rum synthetics at 5k to 7k intervals .still dont understand why guys change at 3k.
  9. Nov 17, 2019 at 9:02 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I run mobile1. It’s on sale at Wally World several times a years which makes it affordable to use.
  10. Nov 17, 2019 at 11:47 AM
    TacoTuesday1
    FL
    currently running synthetic Mobil 1 5w30 from Wal-Mart, usually comes out to $12 per big jug after the promotional rebate that M1 runs often (mail-in or online)
  11. Nov 17, 2019 at 4:37 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    No problem running synthetic.
  12. Nov 17, 2019 at 4:50 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    This one's been debated many, many times and there is (and never has been) a problem with switching from conventional oil to synthetic or the other way around. Mike drop. Personally, I run full synthetic and a premium filter with 7,000 mile change intervals.
    I do remember being in a local Pep Boys store about 5 years ago and a customer asked a clerk the exact same question. Much to my surprise, the clerk launched into a long dissertation about how one should absolutely never switch or even mix the two kinds of oil. I listened in for several minutes in utter amazement, then walked by and said, "I suppose you've never heard of synthetic blend oils have you?", then walked out the door. Words fail me.
  13. Nov 17, 2019 at 5:05 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Just use the correct grade oil and be done with it. And...yes...syn will blend fine...and it doesn't cause leeks like some say.
  14. Nov 17, 2019 at 5:10 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Only thing I would say is if you switch go blend, full synth or go back to full Dino. Word is with some synthetics it could be bad but mostly on high mileage as it won’t swell the seals and could leak. If your under 100k I see no issue but stick with it or switch back after or keep on synth. I switched and only SJ synth now.
  15. Nov 17, 2019 at 5:51 PM
    pg_osborne89
    pg_osborne89 Well-Known Member
    Phil
    Savannah
    2012 Tacoma TRD Sport
    I see M1 on sale at Walmart all the time. But I don’t see any rebates anywhere. Are they on the jug itself or just a flyer nearby?
  16. Nov 17, 2019 at 6:02 PM
    Crosis
    Dunedin Fl
    Check Walmart website. They will list it on there when the rebate is go8ng on.
    pg_osborne89 likes this.
  17. Nov 17, 2019 at 6:21 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Full synthetic changed every 10K will cost less in the long run and protect the engine better than conventional oil changed every 3K. I see no advantage mixing synthetic and conventional. Choose one.
    intrepidrook likes this.
  18. Nov 17, 2019 at 6:24 PM
    tacoma guy
    Joe
    Phoenix Az.
    Once again thank you guys for all the input and personal experience. I will have to do some serious thing of going to full synthetic.
  19. Nov 17, 2019 at 8:07 PM
    intrepidrook
    intrepidrook Active Member
    2007 tacoma pre-runner
    stock as can be
    07 with almost 55k miles with oil changes like clockwork every 6 months at dealership for the first 11 years. Starting in 2018 I put in Mobil1 full synthetic with OEM filter - engine runs smoother at highway cruising speeds. 2019 back to conventional oil (its a family communal truck) - zero issues.
    My personal vehicle (01 celica) has had full synthetic since the first oil change - it's worth the few buck IMO. My engine builder guy recommends OEM filters with full synthetic. Oil brand for majority of the folks is not a big deal - but those who push their engines, it sounds like the purple stuff is the way to go. I like using mobil one with a little lucas oil mixed in.
    I also 100% agree with Marshall - full syn is cheaper route to go as you can run longer between oil changes along with "better" performing oil. I still change oil every 6 months despite low miles.
