Switching to Synthetic Oil at 80,000
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Calvin05, Dec 25, 2013.
  1. Dec 25, 2013 at 8:45 PM
    Calvin05
    Calvin05 [OP] Member
    Calvin
    Sylva, NC
    05 TRD Sport, 6-speed, 285/75 km2s. Red/Black
    Good or bad idea to do?
    I'll be hitting 80,000 miles on my 05 Taco Sport by Friday. Was considering going to synthetic. Or should I just keep on keeping on with 5w-30? Thanks in advance.
  2. Dec 25, 2013 at 8:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not a problem going to synthetic.
  3. Dec 25, 2013 at 8:52 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    5w 30 synthetic.
  4. Dec 25, 2013 at 9:13 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    This...
    The theory that you can't switch to synthetic is a myth. Noting bad will happen.
    The issues that people had way back when were engines that had small leaks already would leak easier with synthetic because it gets into nooks and crannies a lot better. This means if you already have a small leak, it could become noticeable with synthetic. With engine tolerances as tight as they are these days, you won't have a problem...you'll only see benefits.
  5. Dec 25, 2013 at 9:19 PM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    I had the Toyota dealer persuade me away from synthetic saying that I have been running regular oil since start and I should keep it the same.
  6. Dec 25, 2013 at 9:23 PM
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    What "benefits" should I expect? I've been told the actual Toyota branded oil is a synthetic blend and it is very good. Not accurate?
  7. Dec 25, 2013 at 9:26 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    ...find a new dealer.
  8. Dec 25, 2013 at 9:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Lower cold pour point (gets moving in the engine more quickly on cold starts)
    Better film retention (more oil remains on the bearings after the engine has been shut down, better protection during startup)
    Better viscosity stability (oil maintains grade longer)
    You'll notice that I did not mention extended drain intervals.
    It is certainly possible, but this is mainly because of the shear stability. The oil remains in grade longer, so it can be run longer... the problem is, you begin to give up some of the benefits of synthetic by running longer intervals.
    Personally, I don't go over 7500 miles.
    Not true. The 0w20 provided by the factory and REPUTABLE dealerships is a Mobil-1 product.
    I can't guarantee what you'll get if you drive into the dealership and ask for 5w30 synthetic... especially if it is a dealership that attempted to discourage you from switching to synthetic.
  9. Dec 25, 2013 at 10:06 PM
    Calvin05
    Calvin
    Sylva, NC
    Didn't expect so many replies so quickly. Thanks guys, guess I'll switch over Friday.
  10. Dec 26, 2013 at 9:56 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
