Switching to Synthetic on Everything - Need input/help
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jul 30, 2011.
  1. Jul 30, 2011 at 5:23 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im switching to synthetic everything:
    -Transmission Fluid
    -Front/Rear Diff
    -Transfer Case
    Here is where Im starting (great link btw):
    http://www.tacomaworld.com/forum/at...and-vs-competition-amsoil-recommendations.pdf
    My question is this: How do I get the non synthetic fluid out? Draining it will still leave some still in the differentials/tranny/etc....
    Im planning on jacking the truck up to insure it all drains out or even using a hand pump, but before I go through all of that, does it really even matter?
  2. Jul 30, 2011 at 5:34 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    The synthetic and non are completely compatible. Mixing them will cause no issues, especially not with the small amount of residue left after draining.
    What horror stories Chris?
  3. Jul 30, 2011 at 6:22 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Well I know of leaky seals, but thats about it. Its more of a discovery than cause and effect though.
    How hard is it to replace seals?
  4. Jul 30, 2011 at 6:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.. Most "Horror Stories" are simply myths...
  5. Jul 30, 2011 at 6:33 AM
    JDMcQ
    Depends on the seal, but synthetic oils will not cause leaky seals. The only real downside to making the switch is the added expense, but in the grand scheme of things the expense is minor.
    I switched everything to synthetic a few years ago and have had no issues.
  6. Jul 30, 2011 at 6:39 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes, as I said...
    :rolleyes:
  7. Jul 30, 2011 at 6:40 AM
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    5k ago I switched to all synthetic and I gained ~4-5 mpg. I wouldn't worry about the remaining residue. It would take a lot of work to get the tiny bit of residue out and it doesn't make much difference if you leave it in there. Its enough of a PITA to change all the oils. The good thing is that all the drain plugs on the toyotas are at the lowest point so there is hardly any fluid left.
    Sythetics make a huge difference. I had some slop in my drivetrain and it tightened that right up. Make sure you get full synthetic not synthetic blend. I used royal purple all around for the tcase front and rear diff.
    You just drain it, and fill it until the fluid starts coming out the top. Pretty simple. I would recommend using a funnel with a long flexible stem. It was tough getting the oil cans inverted and into the funnel for the front diff.
  8. Jul 30, 2011 at 6:47 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    I know when synthetics first hit big on the market, there was an issue with them. But with todays formulas and the fact that most people aren't trying to dump them into old worn out engine, they work great. I use to run full synthetic in my 08 Magum before it got wrecked and I loved the stuff. I will be doing the switch in my Tacoma when I get home....
  9. Jul 30, 2011 at 7:29 AM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    i switched all my gear oil out to that redline synthetic shockproof gear oil, its awesome stuff, the only horror stories ive ever heard of is 20 bucks a quart
  10. Jul 30, 2011 at 7:49 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    $20 huh.... Ouch.
  11. Jul 30, 2011 at 8:09 AM
    JDMcQ
    $20 a quart does hurt. I went to Amsoil last year, $12 a quart for their Severe Gear 75/90
  12. Jul 30, 2011 at 8:20 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, Im going to look at some Amsoil products before I start this. Ill be underway all August and will probably have to wait till September to do the swap.
    Anyone know some good online vendors where I can get this stuff for cheap?
  13. Jul 30, 2011 at 8:29 AM
    JDMcQ
    If you are loking t Amsoil, just pay the $20 and become a preferred customer. You get a decent discount and it is easy to recoup the initial investment.
  14. Jul 30, 2011 at 10:33 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Pro 500; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Most of it's already been said, but the recent migration of my entire drivetrain to Amsoil was completely uneventful. (I did NOT jack my truck up or use a hand-pump to drain the old oil.) The dino-oil remnants left when you drain shouldn't cause any problems.
    Rather than a funnel, I sprang for a hand-pump to get the new oil in - it worked great. I haven't seen any significant mileage increase, but shifting (through the gears and in/out of 4WD) is noticeably smoother. Like jdmcq, I went with Severe Gear 75/90, which is API GL4/5 and MT-1 compatible.
    Check out http://www.tacomaworld.com/forum/1st-gen-tacomas/154350-tranny-t-case-diff-fluids.html#post3341726 for a detailed list of the washers you'll need to do this right.
  15. Jul 30, 2011 at 2:21 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ Awesome, thanks Steve.
  16. Jul 30, 2011 at 2:46 PM
    ontarioyota
    ontarioyota Well-Known Member
    SW Ontario, Canada
    01 reg cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs with D6XL AAL (removed), summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    good discussion...subbed!
  17. Jul 31, 2011 at 9:26 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    What are the exact specs for quarts for the front and rear axles and the t case. I have heard that the automatic transmission actually holds like 14 quarts. I was looking at max atf by royal purple and 14 quarts is a car payment at advance. Right now you can get mobil 1 75/90 for like 8.99 for the full synth on advanceautoparts.com if you use the code RAF7JA1102 you can get 35 bucks off 85 on pretty much anything except motor oil. I was going to go ahead and get some things but i dont know how much to buy.
  18. Jul 31, 2011 at 9:45 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Let me know Chris if you want anything Amsoil, my dad is an associate dealer and gets a good discount as JDMCQ said and you wouldn't have to spend the $20 to join.
  19. Aug 1, 2011 at 8:58 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The link above mentions the capacities. Ill probably verify with the Toyota dealer before I go through with this.
    Colton, that would be great. Im underway throughout most of Aug but Ill probably hit you up in September when Im planning this. Thanks!
  20. Aug 1, 2011 at 9:22 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    It can't be 14 quarts. I used less than 6 quarts for front and rear diff and tcase. Royal purple is only $6 per quart. I can't imagine this other stuff is that much better that its worth $20.
