Switching to synthetic questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by igno1tus, Sep 20, 2020.
  1. Sep 20, 2020 at 9:15 AM
    igno1tus
    igno1tus [OP] Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    So I’m switching to Mobil 1 synthetic soon from semi synthetic and my questions are ..
    After I switch should I change the oil filter a few times within a certain number of miles because the synthetic will be ‘cleaning’ any sludge I do have out (the truck has had regular oil changes as filter changed every 5k with Toyota oil & filter)
    should I drain the synthetic after initially changing (within a certain number of miles) to get the “mixed” oil residue out of the motor ?
    if so what are your recommendations ? Oil guys speak up here , if your here to heckle me go do it in another thread :thumbsup:
    4.0 motor , 123k on it , no leaks and doesn’t burn or use oil currently . Consistent oil and filter changes with Toyota oil and stock filter . FWIW
  2. Sep 20, 2020 at 9:16 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Switch and just continue with your regular OCI. You'll be just fine.
  3. Sep 20, 2020 at 9:27 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
  4. Sep 20, 2020 at 9:29 AM
    igno1tus
    Sounds like it’s no big deal ? I would of thought there was a “procedure” to switching
  5. Sep 20, 2020 at 9:30 AM
    Bishop84
    Bishop84 Well-Known Member
    You are over thinking, these engines last forever on any oil, just stick to regular intervals.
    If you switch to synthetic, just do it and run longer intervals so you're not wasting any money. I'd do 6000 miles to 8000 miles on synthetic on a 4.0
    Sig45 and Accipiter13 like this.
  6. Sep 20, 2020 at 9:33 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I ran Gunk 5 minute flush through mine then let it drain overnight. Changing the filter again in a week or so would be a good idea. Edit: and I added this for shits and giggles. 389175CA-18B8-4119-85E7-D8A379C4362A.png I can see the eyes rolling
  7. Sep 20, 2020 at 9:35 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    This. I typically give myself a Window between 5000 to 7000 mile OCI when using synthetic and the factory Denso Filter. This gives me time to get the tires rotated and pick a Well timed weekend or squeak out another month to get to More favorable weather if possible.
    I have gone 10k+ Miles with synthetic and a premium Filter (Fram Ultra) when I was burning a lot of highway miles.
    Just swap it the next time and don’t think twice.
  8. Sep 20, 2020 at 9:47 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Seriously?
    Steves104x4[QUOTED] likes this.
  9. Sep 20, 2020 at 9:50 AM
    igno1tus
    I’m putting a fumoto valve on the truck for easier changing (as I live in a apartment now) so I was possibly considering sending a few samples to black stone to get a good idea how long I will be able to go exactly
  10. Sep 20, 2020 at 9:59 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    My real question is have you changed the rear diff oil? Edit: and I’ve had the Fumoto valve on the truck for going on 11 years, now
  11. Sep 20, 2020 at 10:03 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Sounds like your truck has had regular oil changes throughout its life, so I doubt you have any "sludge" to deal with. Switch to your hearts content, and no matter what they say you can switch back and fourth at will. Nothing bad will happen. First thing I did when I bought my truck is change the oil to synthetic. I still change mine at 5K; it might be a waste of money to some, but my truck, my money.
    igno1tus[OP] likes this.
  12. Sep 20, 2020 at 10:05 AM
    Bishop84
    Its a good idea, they will likely to tell you to run 10k oil change intervals.
    igno1tus[QUOTED][OP] likes this.
  13. Sep 20, 2020 at 10:15 AM
    igno1tus
    Yes all fluids and maint is done (thanks to TW!) trans case, front and rear diff, coolant, ps fluid, brake fluid ,transmission all done
  14. Sep 20, 2020 at 10:17 AM
    igno1tus
    The only thing I want to do is my belt and bearings & pulleys and tensioner as PM
  15. Sep 20, 2020 at 10:21 AM
    igno1tus
    Yea I’ve been noticing the current oil has been getting dirtier when it’s due . Seems like MAYBEE this might be where the sludge starts ? It used to come out pretty clean
  16. Sep 20, 2020 at 10:30 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Nah, oil color has really no bearing on remaining life, some say it does, but in reality, no (unless it's as dark as pure crude). It's what it is supposed to do, hold the contaminates in suspension. Different oils with different additive packs will do different stuff. My oil in my truck will get darker within 1500-2000 miles depending on the brand I use, and it's pretty clean inside. You should see how quick the oil in my VW GTI with the direct injected turbo gets dark.
  17. Sep 20, 2020 at 10:44 AM
    igno1tus
    Yea I would think M1 is really good for it , 10k mile changes . I don’t really do heavy driving either , it does have to withstand temp changes thou it’s 90+ here in the summer and anywhere in the freezing temps in the winter
