switching transmissions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tac 2009, Jan 8, 2012.
  1. Jan 8, 2012 at 4:59 PM
    Tac 2009
    Tac 2009 [OP] Well-Known Member
    black 09 SR5
    from auto to manual or manual to auto. has it been done by anyone here?
  2. Jan 8, 2012 at 5:32 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    it would be cheaper to sell the one you have and buy the one you want.
  3. Jan 8, 2012 at 5:36 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    as far as i know its just the computer and transmission itself.
    this is a transmission, not 4x4 conversion.
  4. Jan 8, 2012 at 5:43 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    I've looked into it for a jeep. There are quite a few things that would need to be changed/gotten in order to do a swap. Flywheel, clutch pedal (and mounting hardware), master cylinder and slave cylinder with lines, clutch, pressure plate, computer, cooler lines to the radiator for ATF, transfer case might be different. Im sure there is more to it than that..
  5. Jan 8, 2012 at 5:44 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    sorry, all that was assumed :D
    clutch peddle, on first gen its a seperate assembly, related lines, res/cyl and such etc etc
  6. Jan 8, 2012 at 5:48 PM
    tacobell007
    Drew
    Westfield, MA
    I was just stating for the OP what would need to be done to put in a manual. I figured you knew about the stuff ;)
  7. Jan 9, 2012 at 5:39 AM
    jbrenn
    allen texas
    10 sr5
    Center console as well.
  8. Jan 9, 2012 at 5:46 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Unless he happens to have access to a donor vehicle (accident total) with all the necessary parts...
    And emergency brake handle.
