Swollen lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jkuniverse, Apr 20, 2019.
  1. Jun 10, 2019 at 3:08 PM
    #41
    T2018
    T2018 Active Member
    Sacramento
    -01 Tacoma base 2wd 2.4L, Least I took the camper shell off.
    RokStok, 179K miles.
    I had new tires put on last Friday at Americas tire, made a point to get it in writing that the lugs nuts were to be started, tightened, and then torqued all by hand. The guy mad a big deal about it and tried to tell me that the gun is fine, yada yada yada... Told him if he wants the sale to do it that way or I will find another shop. They did it all by hand, the shop guy was not happy about it, but hey it's my truck bro- after he did it I kicked him a 20 after to say thank you.
    06Tacooo likes this.
  2. Jun 10, 2019 at 4:58 PM
    #42
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Yes my OEM was swollen becuase of the thin sheet metal wrapped around.
    America's Tire sold me 24 Gorilla solid lug nuts for $50. I thought that was a fair price because Wheeler's Offroad is charging $60 for the same Gorilla lug nuts.
  3. Jun 12, 2019 at 8:12 PM
    #43
    zilla805
    zilla805 Weekend warrior
    San luis obospo
    4x4 TRD
    They a a good deal . Costco sells them for 1.75 each
    #43
  4. Jun 13, 2019 at 8:15 AM
    #44
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Only time I've ever seen them 'swell' is when someone took a 22mm or 7/8 to our lugs. They do that once, and congratulations - you now have 22mm lugs.
    At least ours are better off than ford. Even with the right size socket the tin can wrapping warps then you're using a hammer to remove, install, and torque. Try doing that 20 times to remove lugs, 20 times to install, and another 20 to torque :D
    Always get solid metal lugs, none of this tin can coated crap or you'll be on the side of the road pounding your tire iron on with a rock when you have a flat.
  5. Apr 25, 2022 at 1:18 PM
    #45
    Scott2006
    Scott2006 Active Member
    La Mesa Ca.
    Tacoma PreRunner
    I had to replace the front hub on my 2006 Tacoma the other day, imagine my surprise when I could barely get a socket on the lug nuts. I went ahead and bought 6 new ones from Toyota to finish the job and then today to Discount tire to complain about them wrecking my lug nuts. They gave me the same story about "swollen lug nuts" and kind of blew me off. So, I asked to speak to the manager and asked him why I hadn't been informed about the problem in the last 10 times I've had the tires balanced. After asking how I was going to change a tire on the road with the trucks lug wrench that didn't fit, he changed his tune and gave me a box of lug nuts with an extended head. :D I can't really blame Discount though, Toyota sold me the same lug nut that would probably "swell" and be a nightmare on the side of the road...
  6. Apr 25, 2022 at 1:24 PM
    #46
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s probably because they are using a 21.5mm socket.
    Most shops have them, you almlost have to if you are in the tire business.
    It’s so common, most shops don’t even think to tell the customer.
    I will agree, it would be nice to tell the customer “before the customer” has to change the wheel.
    And yes, I found out the hard way.
    https://www.tacomaworld.com/threads/i-got-a-case-of-the-swollen-nuts.686539/
