Swollen Nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tackleberry, Sep 20, 2021.
  1. Sep 20, 2021 at 4:47 AM
    Tackleberry
    Tackleberry [OP] Rifleman not a cook, Appleseed program
    Mark
    Shelton, CT
    Tacoma 2011 DC long bed Mag Gray
    Extang Trifecta Tonneau Cover, Toyota OEM Roof Rack, Console Vault, Weathertech floor liners, LUND bed extender, Gauge pod, Outside Temp, Enviro gauge, Maglite mount, J-hooks for scope stand, MetalMiller's Devil Horns, AVID Light Bar and Side Steps, Pop-N-Lock, Westin Driving lights, Hella 500 Off Road lights, Tacoma Bed Liner, Door Trim Guards, LED dome, map and plate lights
    I figured it was a good attention getting title.
    So my trouble is my lug nuts do not fit my lug wrench, the wrench is too small. I was told by a friend that is is not the wrench its the lug themselves. It is because the lugs had swollen over the past few years since my last tire change. I have had the tires rotated fever other oil change, so I didn’t know there was an issue. My questions are, first is this a well-known issue? And two what are the best replacement lugs for stock factory rims.
    Thank you all in advance for your help
    Tack
  2. Sep 20, 2021 at 4:54 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Is there any possibility you have the wrong size lug wrench?
    And why does your friend think the lugs have swollen?
    Mark77 likes this.
  3. Sep 20, 2021 at 4:55 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Stock Tacoma nuts have a SS sheathing (I don’t know if its all, some, or most). It can get distorted.
  4. Sep 20, 2021 at 5:29 AM
    Tackleberry
    Mark
    Shelton, CT
    I have since asked around and the stealership said that it happens. Between the SS coat and the nut rusts and swells the nut and the lug wrench dosent fit. It was a big suprise to me when I got a flat and couldn't get the lug wrench to fit. Now I don't know what to do, Is there a good set of lugs to get to replace them?
    wilcam47, mikalcarbine and Key-Rei like this.
  5. Sep 20, 2021 at 5:41 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You can get half mil sockets as a temporary solution or as you ascertained replacement lugs.
    Depends on your wheel type.
    Gorilla lug nuts are decent and what I have on my truck but I do not jave stock wheels. I have Extended seat thread lug nuts and SCS wheels.
  6. Sep 20, 2021 at 5:42 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Today I learned that tacomas did use SS seathing on lug nuts. Ive only seen it on fords and dodges. Lovely
    tacoman45 and mikalcarbine like this.
  7. Sep 20, 2021 at 5:48 AM
    BasicallyTaco
    BasicallyTaco Well-Known Member
    Ga
    2021 Tacoma SR5 2WD silver, "basic little truck"
    13th Gen F150s were notorious for lug nut swelling. It's one of the first things I changed out on my previous F150. The stock ones are a 2 piece design and would swell then break off when loosening the lug nut. It would probably be a good investment in swapping out your Taco's lugs for some 1 piece Gorilla lug nuts.
    wilcam47 and wi_taco like this.
  8. Sep 20, 2021 at 5:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    This more commonly happens in salt country.
    When was the last time you examined / treated your frame?
  9. Sep 20, 2021 at 5:59 AM
    Tackleberry
    Mark
    Shelton, CT
    I havent treated my frame. Am I looking for problems there too?
  10. Sep 20, 2021 at 6:00 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Over time the cheap lug nuts with a thin sheet metal cover used by most manufacturers get out of shape and will no longer fit. You can force a socket one size smaller over the lug nut to get it off once, but once doing that it can't be reused. I'm lucky that the ones on my 2007 Tacoma still work, but I had to buy 24 new lug nuts for my 2014 150 several years ago.
  11. Sep 20, 2021 at 6:04 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    The original Lugnuts that came with Toyota had a chrome tannish type of material over the log not know what time those will not fit a log not anymore this is telling you it’s time to go out and buy a brand new set
  12. Sep 20, 2021 at 6:08 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sunlight will shrink your nuts
    Kolter45 and Tackleberry[OP] like this.
  13. Sep 20, 2021 at 6:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    https://www.tacomaworld.com/threads/do-i-need-a-new-frame.733215/#post-26112920
    Read post 8 carefully. I'd be calling a dealer and setting up an inspection/preventative treatment, as you are rapidly approaching the 12 year from first date of in service window.
    There are hundreds of other threads of a similar nature here too, should you wish to search for others.
    Good luck!
  14. Sep 20, 2021 at 9:30 AM
    Tackleberry
    Mark
    Shelton, CT
    Ok thank you all for your help. I have the original rims on the truck, so I need to find the correct gorilla lugs for them. Do any of you know if the original equipment are “narrow spindle?” Or does anyone have a link they can post to get the right size lugs. Thank you all again
    Tackleberry
  15. Sep 20, 2021 at 9:53 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  16. Sep 20, 2021 at 10:02 AM
    Tackleberry
    Mark
    Shelton, CT
  17. Sep 20, 2021 at 10:22 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  18. Sep 20, 2021 at 3:45 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    NAPA sell's the factory style lug nuts.
  19. Sep 20, 2021 at 3:51 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I occasionally squirt a shot of WD-40 in my nuts. This will keep out the moisture and keep them from swelling in their skin (stainless steel). I've been putting WD-40 on my nuts for years.
  20. Sep 20, 2021 at 5:00 PM
    Archertl33
    Archertl33 Active Member
    2010 tacoma trd off road / 2018 4runner trd
    This happened to mine after 11 years recently. I just replaced them with solid ones.
