Symptoms of a warped brake drum?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by abhamber, Jun 19, 2020.
  1. Jun 19, 2020 at 9:42 AM
    abhamber
    abhamber [OP] Well-Known Member
    Aman
    Alberta, Canada
    2018 BBP Tacoma TRD Sport DCLB
    Hey everyone, my dreaded driveline vibrations have returned.
    I tried another trip to the dealer, and after a through diagnosis, the dealer mentioned they would have to contact Toyota Canada for further assistance. I'm starting to become convinced that I may have a warped rear brake drum(s)
    Symptoms
    - Vibration between 40 to 50 mph felt primarily in the seat
    - Pulsing sensation when braking between 45 to 20 mph
    - Speed range of vibration tends to slightly vary a bit depending on how much and therefore how hot the brakes are
    - Feels like the rear is "hopping"
    What has been done
    - My initial vibrations began at 20000 miles. My dealer replaced the axle shafts.
    - Axle shaft replacement at 20000 miles fixed my vibration for about 6 months or 8000 miles
    Now 8000 miles later, I'm back at the dealer for similar vibrations and after a lengthy discussion with the technician, he mentioned the following:
    - Pinion angles are in spec
    - Drive shaft was removed and the truck was driven in 4HI, and the vibration was still there
    - Tires are balanced
    - No visibly vibration when the rear drive train was spun on the hoist
    - Since the pinion angles are okay, the leaf springs are deemed okay
    - During the previous winter tire change over, the lug nuts seemed excessively torqued (over 83ft-lbs)
    To my knowledge, the only thing that hasn't been checked is the 'roundness' of the brake drum. I seriously doubt my new axle shafts are out of spec within 8000 miles.
    Based on my information above, does this sound like a possibly warped drum? The dealership won't check the drum unless instructed by Toyota Canada to do so arrghhhh.
    cryptolime and TacoSteve1234 like this.
  2. Jun 19, 2020 at 10:04 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    If the vibration is only there during braking then it more than likely is the drums. You can go to an independent repair shop and get the drums turned yourself for not a lot of Loons.
    Holling, abhamber[OP] and SR-71A like this.
  3. Jun 19, 2020 at 10:06 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    It could definitely be the drums.
    also, what tire size are you running? The rear leaf shackles are known to be weak and can cause similar symptoms. BAMF and Archive garage have some replacement hangers that have corrected similar problems. If it’s the drums, great, If not, then the hangers should be your next fix
    abhamber[OP] likes this.
  4. Jun 19, 2020 at 10:20 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    If you have vibration without brake application, you have other problems.
    SR-71A likes this.
  5. Jun 19, 2020 at 10:24 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I push the button on the e-brake and keep it pushed. Then apply it softly till the brakes engage to see if it vibrates. Don't do this at low speed. You'll lock up the rear brakes. Also, be careful
    SR-71A likes this.
  6. Jun 19, 2020 at 10:31 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    As others said, if the vibration is there when you're normally driving (not braking), its probably not the brakes. But an easy way to test just the rear brakes would be to use the e-brake when you're on a remote back road.
    It is good to know that the vibration persists with the rear driveshaft out of the picture. That should help remove a lot of possible culprits.
    You said tires were balanced.. Was that a 'road-force' or just a normal balance? A tire that is not round may balance out fine, but it will still feel like shit on the road. If its bad enough the tech may be able to see the run-out of the tire as it spins on the machine
    abhamber[OP] and wrightme43 like this.
  7. Jun 19, 2020 at 11:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When my rear drums on the tundra became very worn and warped at around 150k, i had my brake pedal pulsing when applied.
  8. Jun 19, 2020 at 11:56 AM
    Dravnx
    Dravnx Well-Known Member
    jeff
    Santa Rosa, Ca
    2018 SR5
    I had the same issue. I brought my truck to my local dealer and told them it was coming from the rear. They changed the front pads and machined the rotors. Dumb asses. Took it to another dealer. There is a service bulletin that addresses this. They replaced my rear axles and fixed the problem.
  9. Jun 19, 2020 at 1:02 PM
    abhamber
    Aman
    Alberta, Canada
    Is a warped brake drum the same as a "out of round" drum. Would a 'out of round' drum be unbalanced and still cause vibrations without applying the brakes?
    While trying to self diagnose possible issues, I switch to my winter rims and tires (which were road force balanced 6 months ago) and the vibration was still there, if not a tad worse.
  10. Jun 19, 2020 at 1:03 PM
    abhamber
    Aman
    Alberta, Canada
    Unfortunately my vibrations came back 6 months after my axle shafts were replaced.
  11. Jun 19, 2020 at 2:14 PM
    zoo truck
    None
    Back in the the day toyota had a service bulletin like that on the tundra for rear drum pulsing, also one to upgrade to a finer tooth brake cylinder adjuster.
  12. Jun 22, 2020 at 5:44 AM
    SR-71A
    Zack
    Southern Maine
    I wouldn't think so, but Im not sure. So your saying that you feel one vibration while driving without touching the brakes, and another vibration (pulsing) when hitting the brakes?
  13. Jun 22, 2020 at 7:30 AM
    abhamber
    Aman
    Alberta, Canada
    Correct. I get a pulsing sensation from the rear while braking (don't feel anything in the pedal) and a noticable vibration between 30 to 40mph (wheel balance, and the driveline has been ruled out)
  14. Jun 22, 2020 at 7:40 AM
    SR-71A
    Zack
    Southern Maine
    How do you know its the rear brakes?
  15. Jun 22, 2020 at 7:51 AM
    abhamber
    Aman
    Alberta, Canada
    It's just a hunch, and I figure I'd ask here before replacing my drums. But I think they are because:
    -pulsing sensation while braking
    -driveline angles and leaf springs were checked and confirmed okay
    - wheel balance is ruled out
    - axle shafts replaced 8000 miles ago
    - vibration is worse in the morning with cold brakes
    - the speed range the vibration tends to occur seems to vary slightly with brake temperature
    -the vibration is felt in the seat
  16. Jun 22, 2020 at 7:56 AM
    SR-71A
    Zack
    Southern Maine
    Did you try my suggestion of using the e-brake to slow down? (do this on a rural road with little traffic..)
    The e-brake uses a cable to actuate the rear drums only. Takes the front brakes completely out of the picture
  17. Jun 22, 2020 at 7:58 AM
    abhamber
    Aman
    Alberta, Canada
    Yes, I could feel it, but it was very slight tbh.
  18. Jun 22, 2020 at 8:13 AM
    SR-71A
    Zack
    Southern Maine
    I guess I'm not 100% sure how much of that pulsing would transfer back to the pedal through a cable vs through the hydraulics of the main service brakes..
    I suppose you could always take the drums off and take them to a local machine shop. Have them chuck them up and indicate on the inner surface, see if theres any run-out or warping.. Not sure if Tacoma drums are thick enough to resurface or not. Ive never done it
  19. Jun 22, 2020 at 8:17 AM
    abhamber
    Aman
    Alberta, Canada
    No worries! Thanks for the help Zack.
    SR-71A[QUOTED] likes this.
  20. Jun 24, 2020 at 5:04 AM
    abhamber
    Aman
    Alberta, Canada
    I'm scheduled for a brake inspection this Friday.
    I've noticed the vibration changes with brake temperature. There is very little vibration while my brakes are still cold (while on my way to work) and after spending sometime in "stop and go" traffic with repeated brake applications, the vibration in the rear becomes signifiantly more noticeable (and more so when braking)
    Definitely seems like a warped drum. If my drums are warped, is that something that's usually warrantable?
