Syncing TPMS
Discussion in 'Wheels & Tires' started by Blue Taco 18, Jan 30, 2022.
  1. Jan 30, 2022 at 12:10 PM
    Blue Taco 18
    Blue Taco 18 [OP] New Member
    Long time reader. First time poster.
    I have a 2018 TRD PRO that came with dealer installed Procomp tires and wheels. I managed to keep the original TRD PRO wheels and tires. The Procomp tires are nearly worn out and I want to put the original wheels and tires back on. I am hoping the original wheels have the TPMS in them. Will I need to sync the original wheel's TPMS to the truck? If so then how?
    Thanks.
  2. Jan 30, 2022 at 12:24 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    A reputable tire shop should be able to scan the wheels and tell you if there are TPMS sensors installed and if they’re still operating/transmitting signal. Yes, you will need to sync the sensors to the truck, and a reputable tire shop should be able to do that as well for around $25 dollars, unless you have your own TPMS scan tool, etc.
  3. Jan 30, 2022 at 1:11 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Are the Pro wheels holding air?
    I bet the OEM TPMS sensors have silver metal stems. What type of stems are on the Procomp wheels? What about the Pro wheels?
    Metal stems sensors can be re-used.
