synergy10's 02 Extra Cab Build
Discussion in '1st Gen. Builds (1995-2004)' started by synergy10, Jul 21, 2013.
  1. Oct 10, 2018 at 10:50 AM
    #261
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Where did you get that battery tie down?
  2. Oct 10, 2018 at 3:27 PM
    #262
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Thanks :hattip:
  3. Oct 10, 2018 at 8:29 PM
    #263
    synergy10
    synergy10 [OP] @synergy10.sd
    San Diego
    Prayn4surf likes this.
  4. Oct 11, 2018 at 9:56 AM
    #264
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    synergy10[QUOTED][OP] likes this.
  5. Oct 11, 2018 at 11:53 AM
    #265
    synergy10
    San Diego
    No problem. Hopefully he’s still making them. I haven’t had any issues with it but then again, I probably haven’t hit the same type of whoops you have.
  6. Oct 11, 2018 at 3:16 PM
    #266
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    He is! Just ordered one.
  7. Nov 8, 2018 at 10:54 AM
    #267
    synergy10
    San Diego
  8. Nov 8, 2018 at 11:49 AM
    #268
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    Didn't see if you're running spacers or not. If not, do your tires rub the frame at full lock? I just went from stock wheels and 285's with a 1.25" spacer to 16x8 et0 Fifteen52's and 285's with no spacers and I'm rubbing the frame at full lock...
  9. Nov 8, 2018 at 11:59 AM
    #269
    synergy10
    San Diego
    Not running spacers and also rub the frame at full lock. More so when fully locked to the left. Locked to the right it barely rubs...I'm basing this on what I can hear.
    From what I can remember, even when I had -25 offset F5 wheels I'd still rub the frame. Were you able to clear the frame on your previous setup? If so, time to figure out what the stock wheel offset is + 1.25" spacers.
  10. Nov 8, 2018 at 12:13 PM
    #270
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    I don't recall any rubbing from my previous setup. Maybe at full lock and full stuff... But right now I rub when trying to back out of a parking spot which I'm not a fan of. I don't really want to go back to bolt-on spacers. Right now I'm planning to go to some extended ARP studs and I'm hoping to find, or have made, some 10-15mm spacers. I think that would solve the rubbing for street driving.
  11. Nov 8, 2018 at 12:17 PM
    #271
    synergy10
    San Diego
    That sounds slightly worse than mine. I only rub at the tail end of fully locking it left or right. So far no problems with parking, around town, etc. Off road I rubbing probably more than the frame...lol.
    I'd feel a lot better with extended ARP studs and spacers instead of bolt-on spacers. However, I have read that a lot of people have ran them off road with no issues.
  12. Nov 8, 2018 at 12:24 PM
    #272
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Factory BS is like 4.75 or 4.5. Most SCS's are 3.5 FWIW. Don't know the offset number that corresponds to. -20 or 25?
    synergy10[OP] likes this.
  13. Nov 8, 2018 at 12:31 PM
    #273
    synergy10
    San Diego
    The F5 wheels I previously ran were 3.5" BS (-25mm offset). My current wheels are 4.5" BS (0mm offset).
    @lambo So if stock is 4.5" BS and you had 1.25" spacers and that cleared. You're now back at 4.5" BS and that's with a wider than stock wheel. If you still have the spacers try slapping them on to test fit with your new wheels. This should tell you if you need the same, more or less spacing.
  14. Nov 8, 2018 at 3:10 PM
    #274
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    Yeah you're right, my issue is I don't really want that much poke. At least it seems like it would be a lot.
    stock wheels vs new wheels with no spacer:
    stock wheel with spacer vs new wheel with no spacer:
    stock vs new with spacer on both:
    But you're right, it would make most sense to try the spacers and see how much less I would need to clear properly.
  15. Nov 8, 2018 at 3:35 PM
    #275
    synergy10
    San Diego
    At least you know what you need to look into. I guess it doesn't bother me enough to really mess with it. Even off road it's not so bad.
    Either way, post up your results if you do decide to start test fitting the spacers.
  16. Nov 9, 2018 at 10:50 PM
    #276
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    Thats my same problem... don't want too much poke but don't want it sucked in the wheel well either
  17. Jan 18, 2019 at 12:21 PM
    #277
    synergy10
    San Diego
    I know we PM'ed back and forth a few times, curious, did you decide on a set for your truck?
  18. Jan 26, 2019 at 1:35 PM
    #278
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
    Love this build. I just bought a similar 1st gen for my DD. Hope it can make it like yours some day:thumbsup:
  19. Jan 28, 2019 at 10:14 PM
    #279
    synergy10
    San Diego
    Thanks! Hoping to get closer to finishing her up this year.
    Dalandser likes this.
  20. Jan 28, 2019 at 10:33 PM
    #280
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What does that phrase mean - I think it's code for "maxing out on build budget"
