Synthetic gear / MT oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Sep 29, 2017.
  1. Sep 29, 2017 at 5:56 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    What's the general consensus on synthetic vs traditional gear oil in the (manual) trans, t-case, and diffs on these trucks?
    It seems there's mixed results. Some say synthetic (redline, amsoil) makes the shifting smoother and at least one person said it made it worse. I'm curious as the way mine shifts definitely leaves a bit to be desired. Also with the syncro probs of the last 6sp mt, I'm looking for preventative options.
    I just remembered that I read a post today that said Toyota specifies a proprietary oil for the t case...first I'd heard that...
    Anybody got a few K miles on synthetic with results to share? Trans, t case, diffs, any and all? Again, how many miles on the synthetic?
  2. Sep 29, 2017 at 6:03 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I use AmsOil in my engine, transmission, transfer case and differentials. Shifting was noticeably a bit easier after switching.
    swordfish, digitaLbraVo and 1bad2k like this.
  3. Sep 29, 2017 at 6:03 PM
    Rujack
    How many miles on the amsoil?
  4. Sep 29, 2017 at 6:04 PM
    eon_blue
    Azusa, CA
    Redline MT90, best MT oil I've ever run.
    Edit: assuming 3rd gens use 75w90 like 1st and 2nd gens do
  5. Sep 29, 2017 at 6:05 PM
    Rujack
    Cool. How many miles?
  6. Sep 29, 2017 at 6:06 PM
    eon_blue
    Azusa, CA
    I always change it out at the recommended interval (about every 30k), between my supercharger and the 4x4ing I do I like to keep it fresh. I'm sure it could last longer than that though. It's a popular choice here on the forums, I'm sure others will chime in about their experiences.
  7. Sep 29, 2017 at 6:08 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Amsoil throughout. Will be in my AT when it needs servicing.
  8. Sep 29, 2017 at 6:10 PM
    Rujack
    I'm leaning toward the redline.
    On a side note, I changed out my engine oil at 1k with Mobile 1 synthetic, but noticed it runs quieter with the Toyota stuff.
  9. Sep 29, 2017 at 6:11 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    The Toyota syn is probably better than Mobil 1. Try amsoil signature next time. I think you'll like it.
    Rujack[QUOTED][OP] likes this.
  10. Sep 29, 2017 at 6:12 PM
    cosmicfires
    David
    Everett, WA
    About 20,000 and 3.5 years.
  11. Sep 29, 2017 at 6:12 PM
    Rujack
    Why do you guys have a preference re: amsoil v redline? is there any data that shows one being superior? just curious...
    Capespencer68 likes this.
  12. Sep 29, 2017 at 6:13 PM
    Rujack
    Nice
  13. Sep 29, 2017 at 6:13 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Check out bobistheoilguy.com and you'll find all the info you could possibly ever want of automotive lubricants.
    tonered likes this.
  14. Sep 29, 2017 at 6:16 PM
    Rujack
    i'll check it out
    1bad2k[QUOTED] likes this.
  15. Sep 29, 2017 at 6:26 PM
    bluenv
    bluenv Well-Known Member
    There is a good amount of research from differential builders to suggest synthetic is not the way to go for diffs. It doesn't dissipate heat as well as traditional oil, and has been known to cause problems in diffs. At least one aftermarket diff company says synthetic oil voids their warranty.
  16. Sep 29, 2017 at 6:28 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Which company?
  17. Sep 29, 2017 at 6:31 PM
    BeaverNation
    BeaverNation Well-Known Member
    Ford XT-M5 is the best mt fluid you can buy
    Clearwater Bill likes this.
  18. Sep 29, 2017 at 6:34 PM
    Rujack
    That actually sounds familiar, thanks
  19. Sep 29, 2017 at 6:34 PM
    Rujack
    Are you running it?
  20. Sep 29, 2017 at 6:36 PM
    BeaverNation
    Yup have been for about a year! Personally I wouldn't say any fluid will dramatically smooth out shifts. Also when I changed mine at 18k the stock fluid looked new still. It was slightly smoother than stock however.
