Synthetic gear / MT oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Sep 29, 2017.
  1. Sep 29, 2017 at 6:54 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Cool, maybe I'll give it a shot. What are the notable differences btwn that and the stock stuff in your experience?
  2. Sep 29, 2017 at 6:57 PM
    Rujack
    Dayum...$22 quart on Amazon! Does it rub your balls for you when you clutch?
    FishaRnekEd and Berto like this.
  3. Sep 29, 2017 at 7:04 PM
    Rujack
  4. Sep 29, 2017 at 7:31 PM
    eon_blue
    Azusa, CA
    I've heard good things about that Ford fluid but it's expensive as hell. Redline isn't exactly cheap either but it's not that high, and it gets great reviews as well. Made my shifting noticeably smoother.
    Redline also makes an oil called Shockproof in both heavy and light formulas, but it's more expensive and I haven't heard many reviews on it for Tacomas. Supposed to be even better though.
  5. Sep 29, 2017 at 7:33 PM
    Rujack
    It is expensive but I think it's totally worth it. This after I was just complaining about the price.
    After all, the cost over a couple years fades quickly into the black hole of mod expenditures
  6. Sep 29, 2017 at 7:34 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I've Run the Redline MT-90 in an NV3550 and it shifted nicely. I haven't changed the trans oil in the Tacoma yet, I might run the MT-90 when I do.
    The diffs on the Tacoma I'm running the cheaper Amsoil 80-90. Amsoil is to expensive for me for the engine. I'll stick to Mobil 1 for that.
    Amsoil and Kendall are grade 4 oils and have very long service lives. Redline and Royal Purple are grade 5 synthetics and have amazing protection, but don't last as long as a grade 4.
    Biggest thing is actually changing it as suggested by the manufacture.
    eon_blue likes this.
  7. Sep 29, 2017 at 10:36 PM
    Rujack
    Lazy question: how many quarts for the tranny?
  8. Sep 29, 2017 at 10:38 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Full synthetics in both my engines, diffs, and transmission. No noticed difference but I still happily load it up.
    I'm switching to Amsoil from Mobil 1 now.
  9. Oct 3, 2017 at 2:03 PM
    Rujack
  10. Oct 3, 2017 at 2:28 PM
    DPT852
    DPT852 Well-Known Member
    Dan
    Connecticut
    2017 BR TRDOR
    About a month ago I had to do a shifter assembly bearing and seal on my fathers Mazdaspeed3 and decided to do a fluid change while I was in there. After refilling with OEM Mazda fluid there was terrible groaning from the LSD and average at best shifter feel.
    So many on the Mazda forums recommended the Ford fluid over all else; I don't think I've ever experienced a simple fluid change make THAT big of a difference before, in any application. Now it's quite and smooth as can be. I have no idea what they put in that stuff but from what I have experienced the hype is definitely real.
  11. Oct 3, 2017 at 2:32 PM
    Rujack
    I was pretty convinced and about go with Redline and then I read the same thing on a Mazda forum about the Ford stuff. So what about the viscosity? I don't see 75/90 anywhere on the bottle...
  12. Oct 3, 2017 at 2:35 PM
    Rujack
  13. Oct 3, 2017 at 2:38 PM
    Rujack
    Alright, ordered the Ford / Motorcraft stuff. Should get to changing it in the next day or two. Will report my findings if anyone's interested...
    shakerhood likes this.
  14. Oct 3, 2017 at 2:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    You may or may not have 'instant' success of feel change. Some folks in my experience do, some don't. Partially depends on what you are coming from and if any issues are actually improvable via fluid.
    I will add this for encouragement. The first couple of generations of Miatas had an off the shelf truck 5 speed. LOTS of folks who used them for autox and HPDE, as well as full on track rats jumped on the Ford bandwagon. Many of them had significantly upgraded HP as well.
    As with most synthetics, if you are pounding on the vehicle (extreme duty) keep your OCIs at that level. If you are just a causual user with occasional additional stress, double your OCI. Otherwise you're wasting your time and $.
    Look forward to your thoughts after having it in for a hundred miles or so.
  15. Oct 3, 2017 at 5:28 PM
    #35
    Rujack
    I'm trying to smooth out the shifting. This transmission has always been a little clunky going through the gears unless I'm really paying attention. It isn't intuitive like all other manuals I've driven. It is to some degree driver's error on my part in the sense that if I'm paying a lot of attention to my shift points and time the clutch just right, I can glide right through the gears. On the other hand, the lag of the drive by wire mechanically disconnects the truck from the driver. It takes less effort if I'm really winding it up to say 3k + rpm for regular around town driving. But, I don't really like to drive that way - I'm a pretty conservative driver. Typically I shift around 2k unless I'm getting on the freeway for example, or am in 4 low. So I find myself really paying attention to shift points, as I already mentioned.
    This is probably obvious after the aforementioned, but I'm definitely not pounding on it. Although I almost found my rev limiter recently while passing an RV up a steep grade in Grand Teton park...
    OCIs? HPDE?
  16. Oct 3, 2017 at 5:33 PM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Oil Change Intervals (or lubricant)
    High Performance Driving Event
    Be careful not to shift at too low an rpm and lug your motor!
    1bad2k likes this.
  17. Oct 3, 2017 at 5:41 PM
    #37
    Rujack
    Ah, got it.
    Definitely not lugging it. I only shift low when I'm barely on the throttle - down shift if I need to get on it a little harder - or what is probably normal to the average driver.
  18. Oct 3, 2017 at 5:58 PM
    #38
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    I legit shift the exact same way. I feel like reading around here you’ll see everyone winds every gear out to 3500+ which seems absurd to me. But I feel like I experienced a similar learning curve with this transmission shifting more conservatively.
    I changed the MT fluid with Amsoil at 10,000 miles; between that and true break in its silk in that range now (shifting in the high 2ks) and cruising otherwise.
    OA
  19. Oct 4, 2017 at 3:44 PM
    #39
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    amsoil in everything since '78. never a problem.
  20. Oct 4, 2017 at 4:07 PM
    #40
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I'll usually shift around 2500rpm in low traffic/flat roads. I'll shift around 3000rpm if going uphill or merging into a freeway.
