Synthetic in 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stump jumper, Aug 1, 2013.
  1. Aug 1, 2013 at 6:25 PM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Just got my first oil change. Service tech said Tacoma's, Tundras, and FJs were synthetic and had 5000 mile change intervals. Other models are 10k. I said you sure about syn and he said yes.
  2. Aug 1, 2013 at 6:46 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    my understand that, the Tacoma 4 cyl takes synthetic (unsure of interval) and the 6cyl takes dyno oil from factory. 5k mile change on v-6 for sure. with synthetic and a good filter I imagine you could get 10k
  3. Aug 1, 2013 at 6:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    2.7Liter is full synthetic at 5000 mile interval or 6 months.
  4. Aug 1, 2013 at 7:02 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    4.0 gets Dino oil and 5k intervals. If the advisor gave you Synthetic, and insisted that it was factory, say nothing and let him fill your baby with yummy synthetic. It won't hurt anything, only help...
    2.7 has 5k intervals and Synthetic
  5. Aug 1, 2013 at 7:17 PM
    FTD
    FTD Well-Known Member
    2.7 is most definitely synthetic, every 5000 miles.
  6. Aug 1, 2013 at 8:23 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    You're right...
    OP, check your maintainance schedule.
    http://www.toyota.com/t3Portal/document/omms/T-MMS-13Tacoma/pdf/2013_Toyota_Tacoma_WMG.pdf
    Schedule A is for the 4.0 6cyl. It starts on page 40. As you can see, the oil change and filter is every 5,000 miles and uses non-synthetic. This doesn't mean that synthetic is bad, just not necessary.
    Schedule B is for the 2.7 4cyl. It starts on page 56. As you can see, the oil change and filter is every 5,000 miles and uses synthetic
  7. Aug 2, 2013 at 3:43 AM
    stump jumper
    Bill
    Texas
    Mine is a 4.0. They had $2.78/qt on invoice. I do think these guys know. At 2.78 I am guessing Dino. Of course my charge was zero.
  8. Aug 2, 2013 at 4:19 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    The serivce calls for Dino. That's what the dealership can bill Toyota for. If they bill the same rate to toyota for oil changes in general (Dino or synthetic) the advisor could have easily requested the wrong thing and it would get thrown in without question...
    If it got synthetic, it should say on the reciept somewhere.
  9. Aug 2, 2013 at 10:54 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    At $2.78 a quart it is probably dino oil.
  10. Aug 2, 2013 at 12:33 PM
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Why does the 2.7 need synthetic AND the 5K interval? I realize that is the schedule, but what is it about the 2.7 that requires the more frequent change?
  11. Aug 2, 2013 at 9:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Nothing except Toyota has not " Certified " it for longer change intervals.
  12. Aug 2, 2013 at 9:52 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    i put the Toyota 0w-20 synthetic in my truck, with the Toyota filter, no complaints.
  13. Aug 2, 2013 at 9:57 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    Never understood why the 4bangers got the 0w20 syn at every 5k. most Toyotas that take 0w20 syn get the oil change from Toyota every 10k. although I still prefer to use syn and change my oil every 5k anyways. if I used conventional I would probably prefer to change my oil every 3k like the good ol days.
  14. Aug 2, 2013 at 9:59 PM
    DSully72
    Daniel
    Appling, GA
    and by the way, your truck looks amazing in your sig with those destination mt's. perhaps ill give those in a 33 a run when I get spacers and need new tires. my uncle works at a firestone down in GA.
  15. Aug 2, 2013 at 10:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Good old days were never 3k.
    That was dreamed up by Jiffy Lube and oil manufacturers.
    http://www.tacomaworld.com/forum/at...ently-do-you-service-your-tacoma-2001toyo.pdf
    That's the 1st Gen Tundra... conventional oil, 5k severe service, 7500 normal service. That's miles, not kilometers.
  16. Aug 3, 2013 at 5:34 AM
    stump jumper
    Bill
    Texas
    that was my thinking. Next time I am going to walk in to service bay and ask tech.
  17. Aug 3, 2013 at 7:05 AM
    blm
    blm Well-Known Member
    Not sure about the synthetic oil being originally in the Tacoma or synthetic being recommended. I have my 2013 Tacoma manual in front of me. On page #455 (this is for 2.7 liter) it says " Oil grade: IL SAC GF-5 multigrade engine oil. Also says recommended viscosity 0-20. There are conventional oils that are GL-5 and plenty of them. If it states somewhere that synthetic is recommended for the 2.7 liter would someone please tell me where that is stated.
  18. Aug 3, 2013 at 8:19 AM
    junkman
    Erik
    Louisville
    Warranty and Maintenance Guide. Each page, 54-69 at bottom of page.
  19. Aug 3, 2013 at 8:32 AM
    blm
    Ok Thanks. I see it now. I must say that is not illustrated very clearly. There are many items/tasks listed on those pages and it just says "Schedule B Synthetic". Also the reference in the owners manual makes no mention of synthetic and this is in the portion that tells the owner what type of oil to use in their new Tacoma. In addition the 5K oil change interval is odd at best. I assume it is a cover your ass situation. I wonder if you could actually get in contact with someone in the know at Toyota Of America if one get get an explanation of these oddities.
  20. Aug 3, 2013 at 9:39 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    It is my understanding that 0-20 weight oil only comes in synthetic.
