Synthetic Oil and Weight Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by nitto, May 2, 2012.
  1. May 2, 2012 at 5:05 PM
    nitto
    nitto [OP] Member
    I have a 2003 Tacoma 2.4L and I have decided to switch to synthetic oil. I know the manual says to use 5w-30 but the Toyota dealer in my area has always told me to use 10w-30 (I think because of the weather in southern California). If I change to synthetic oil, should I stick with 10w-30 as that's what my has always used for conventional oil or should I switch to 5w-30 as per manual?
  2. May 2, 2012 at 6:50 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    5w30
    Synthetic holds it's viscosity better at higher temperatures.
    Expect slightly lower oil pressure at idle.
