Synthetic oil change every 10k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VanGo3, Sep 28, 2021.
  1. Oct 10, 2021 at 4:25 PM
    #281
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What about the filter housing? Enjoying to take it off?
    ...perhaps you should reconsider fumoto after your incident..
  2. Oct 10, 2021 at 5:58 PM
    #282
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I actually now have a spin on filter. I’m sticking with the Fumoto. I don’t need a single tool to change my oil. Easy Peasy. I don’t think anyone torques their filter housing. All your trying to do is seat the o-ring.
  3. Oct 10, 2021 at 6:36 PM
    #283
    Vlady
    Issy, WA
    And?
    My response was in the context of the price of the first diy oil change vs the dealer.
    So you spent like what $250 on the adapter??
    What are the benefits? You almost lost the oil with Fumoto(per your confession) and most likely you oil filter is hanging low now( or you routed it under the hood?). What are you guys trying to invent? All these modes create an extra point of failure.
    zoo truck, Junkhead and The hammer like this.
  4. Oct 11, 2021 at 6:57 AM
    #284
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  5. Oct 11, 2021 at 7:11 AM
    #285
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You could go to a 2K interval with extra virgin, possibly 3K if you send in samples regularly to your local Italian specialty grocer for taste test.
  6. Oct 11, 2021 at 7:30 AM
    #286
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I change my oil/filter, tire rotation & inspection every 5k miles FTW
    jerrybear, Taco_mike73 and Junkhead like this.
  7. Oct 11, 2021 at 7:38 AM
    #287
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    In a pinch, the engine would run on Veggie oil from the kitchen. Or Peanut oil. Or Canola. Or Corn..........
    Any oil is better than no oil.
  8. Oct 11, 2021 at 7:42 AM
    #288
    The hammer
  9. Oct 11, 2021 at 9:16 AM
    #289
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Oddly enough at a place I worked that made sulphuric acid, olive oil was recommended as a lubricant in the molten sulphur pumps because mineral oil would quickly deteriorate.
  10. Oct 11, 2021 at 12:52 PM
    #290
    mquibble
    Michael
    2021 TacomaTRD Pro
    You can find a thread on the adapter. I’d tell you the benefits but your question isn’t sincere. You do you and I’ll do me. I can do that- apparently you can’t. No biggy. I’m here to learn and help, not to think I am better than anyone.
  11. Oct 11, 2021 at 1:05 PM
    #291
    Vlady
    Issy, WA
    Hey, you brought the torque wrench uselessness up....
  12. Oct 11, 2021 at 8:50 PM
    #292
    CalgaryQuicksand
    CalgaryQuicksand Well-Known Member
    Calgary, Alberta
    2025 White Tacoma TRD Offroad Double Cab
    Skid plate. Running boards.
    Maintenance SVC 1 is every 5000 but oil change SVC 2 is every 10000. They recommend coming in for other maintenance in-between oil changes. Up here in Canada it’s every 8000km but oil change interval is 16000km.
  13. Jan 1, 2022 at 5:00 PM
    #293
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Isn’t the first start after oil change the most damaging to engines? So reducing to a ridiculous interval
    Like 100 mile will increase wear.
  14. Jan 1, 2022 at 5:21 PM
    #294
    mquibble
    Michael
    2021 TacomaTRD Pro
    I think we could possibly identify several startups that would be worse than what you propose.
    1. An Engine start after the vehicle sitting for months. Components likely will have much of their residual oil drained off of them.
    2. An engine start with contaminated oil.
    3. An engine start at very cold temperatures.
    These are my guesses anyway.
  15. Jan 1, 2022 at 6:54 PM
    #295
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    If you score your cylinder walls, do you lose your soul? What if you score the thingies that cradle your cam shaft, does your soul suffer more? Should it? Really?
    Do eulogies discuss one's oil change intervals? If they did, would this mortal coil be better off? Does the mortal coil benefit from "fake" synthetic oils or "real" synthetic oils (you bobistheoilguy freaks know of what I speak of)?
    In the end, this illusion will end, and oil type and change intervals will amount to nothing but a chasing after the wind. Nothing is new under the sun.
    May satisfaction be found in oil changes (whatever interval might occur) under this sun during the few days of life God has given us — for this is our lot.
  16. Jan 1, 2022 at 7:00 PM
    #296
    Dbarffish
    Doug
    Montana
    Stock
    But not coconut.
  17. Jul 23, 2023 at 3:33 AM
    #297
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Just had my last oil change tested. Oil was from the las dealer freebie. Refilled with Quakerstate ultra with a stock filter.
    Oil was changed with 6,250 miles, they said I could have gone to 8,000.
  18. Jul 23, 2023 at 5:02 AM
    #298
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Just make sure when using olive oil, not to use the one for frying, or cooking.....it hasn't the right viscosity.
  19. Jul 23, 2023 at 5:10 AM
    #299
    zoo truck
    None
    Thats as bad as the $50 newly rebuilt engine a friend got suckered into buying. We tore it down, and it didn't look much better.
  20. Jul 23, 2023 at 5:29 AM
    #300
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    In all seriousness, and interestingly enough, olive oil can be used to cook in many high heat situations, including frying, you just can’t go too high. The argument against is a smoke point argument, and the smoke point of the ole extra virgin is high enough. It just isn’t ideal for sautéing a V6.
    zoo truck[QUOTED] likes this.
