Synthetic oil change every 10k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VanGo3, Sep 28, 2021.
  1. Sep 29, 2021 at 8:36 AM
    #41
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I'm leaning at paying the $77 to do the oil/filter change. I just feel better doing it.
    My driving hasn't been harsh although, the past couple of weekends I have been launching from signals with the wife sitting shotgun asking, "why are you driving like that?"
    Ed
  2. Sep 29, 2021 at 8:38 AM
    #42
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Topping up windshield washer fluid you can do yourself for 10 cents and 30 seconds of your time
    Junkhead and Kev250R like this.
  3. Sep 29, 2021 at 8:39 AM
    #43
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Expected that question. Why I underlined the "so often" in the last post...
    The lubricating properties of the oil do NOT wear out, but the additive package* can get used up and contaminates can intrude. So a change is factored in. There are also allowances for eliminating a change. As in never change it, and this can only be done with synthetics. So that tells you something about the quality of the oil which makes 5k or 10k changes very premature.
    *The additive pkg contains the anti-foam, water dispersant, acid neutralizer, detergent, etc. agents in the oil -can't name them all from memory just now-. About 7-8 of them.??
    A great air filter is the single biggest help to stop the majority of the contaminant intrusion.
    A great oil filter is needed to catch what the air filter didn't.
    So this great oil filter:
    To allow the oil to last forever, a VERY fine filter (1 micron) must come into play. With it in place, the synthetic oil does not ever have to be changed. Guaranteed and warranted! And proven since the late 70s. This 1 micron will even filter out water.
    Hold your key strokes a minute. Above is true, but...
    Such a fine filter would take better than five minutes to get all six quarts of oil through it. That's too long for normal operation and the engine would starve for oil.
    So the normal 12-25 micron (depending on brand) filter remains in place and the 1 micron becomes a by-pass filter (means it filters just a little of the oil at a time & full flow filter is unaffected). The full flow still gets changed out at 12.5 or 17.5k interval and the 1 quart of oil top-off still happens.
    ***That one quart replenishes the additive package.*** Therefore the change interval recommendation nulled out.
    The oil doesn't get "changed", but eventually actually will be over a period of years, one quart at a time.
    The by-pass filter gets changed when it's plugged and that is evident by being cool to the touch when the engine & oil are both hot.
    Synthetic oil is amazing stuff! It is the only things that works in turbines. It works from -45F to +400F. It was investigated by the Nazi's when petroleum was scarce for them. It isn't some "new fangled" invention that is still on the drawing board. It works and we should let it do it's thing and shine. Don't cut it short simply because "I'm used to changing at 3,000 miles." As I said, it is guaranteed and warranted.
    Next question will be: "why do Toyota engineers recommend 10k?"... Simply because they have to allow for the lowest common denominator of inattentive, nonmechanical, abusive drivers. They sell to everyone and odds are they'll get those kind of owners. Not all Toy drivers are Tacoma enthusiasts who love, dote on, and pay attention to their ride.
    I'm not selling you anything. You will do as you feel is proper. I just like to shout the value of the product. If it saves someone a bit of cash and helps the environment, then lucky me, I can feel good.
  4. Sep 29, 2021 at 8:43 AM
    #44
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I do weekly checks on fluids...windshield fluid is fine...radiator fluid is also good. Brake fluid, power steering fluid, transmission fluid...all should be checked and are ok last time I checked.
    I'm anticipating they do a visual inspection on all fluids and if needed...top it up and put it in the notes of the invoice...as they normally do.
    Ed
  5. Sep 29, 2021 at 8:48 AM
    #45
    Darkice
    Darkice Well-Known Member
    This guy gives some great insight on oil changes for Toyotas.
    https://youtu.be/v4JS7PybV2k
    Start at 10:30 if you don't want to watch the whole thing
  6. Sep 29, 2021 at 8:49 AM
    #46
    maxmk8
    No one is checking your trans fluid. Ps/brake fluid shouldn’t be topped off as they shouldn’t leak. So you’re left with windshield washer and oil…
    minium and Kev250R like this.
  7. Sep 29, 2021 at 8:56 AM
    #47
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Good points!
    I'm anxious for 4pm today. The dealership is 13 miles south of my location.
    Ed
  8. Sep 29, 2021 at 9:05 AM
    #48
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I’m not the one who made that statement. I’m sure eventually even Synthetic oil will ‘wear out’ however based on multiple Blackstone oil analysis reports which have been posted on this forum showing that at 10K miles the oil in these engines is still in good shape, I’m comfortable going 10K miles or once a year with my Taco.
    The fact that your thoughts are not based on current, factual information makes them opinion or feeling.
    I’m not sure how something written in a manual in 2006 for a different generation of truck with a completely different engine (was the 4.0 an Atkinson-cycle engine? I doubt that it was) is even relevant to this discussion. The owners manual for my ‘61 Honda Sports cub makes a lot of recommendations for service items which the owners manual for my ‘20 KTM Duke fails to mention :rolleyes:
    minium, Lt. Dangle and TartanEagle like this.
  9. Sep 29, 2021 at 9:09 AM
    #49
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Some of ya'll need to watch Scotty.
    minium likes this.
  10. Sep 29, 2021 at 9:11 AM
    #50
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    He talks a lot.
    Junkhead likes this.
  11. Sep 29, 2021 at 9:12 AM
    #51
    yoopersteeze
    WI
    Sure does, but generally has valuable information.
  12. Sep 29, 2021 at 9:12 AM
    #52
    maxmk8
    He says about 60-70% generic truths and 30-40% BS. Sometimes the latter becomes really fking annoying.
    Kev250R, Lt. Dangle and Junkhead like this.
  13. Sep 29, 2021 at 9:14 AM
    #53
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Toxins? Did someone try to poison your tacoma?
    minium, Kev250R and Junkhead like this.
  14. Sep 29, 2021 at 9:16 AM
    #54
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    77 is not expensive.
    1st diy oil change will cost you about the same, if not more once you drain the tranny by mistake.
    TartanEagle likes this.
  15. Sep 29, 2021 at 9:17 AM
    #55
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    My "thoughts" are based on the Scheduled Maintenance for my '06 Tacoma. Still not opinion or feeling.
    In truth, a shorter change interval damages nothing in the truck (1st, 2nd or 3rd Gen).
    The clearest choice is to follow the recommendations in the Owner's Manual for YOUR truck.
  16. Sep 29, 2021 at 9:32 AM
    #56
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Generally don't get involved in these discussions because this isn't the first (nor the last) I've seen this discussed on a forum. I will say that yours are some of the few posts I've seen that have very good information in them. Don't get me wrong, I was a 3k mile proponent for a while. Then I did some research. Paid for some analysis back when three people knew what Blackstone was. And realized I'm a moron. I go with what the manufacturer calls for. This is after experience with testing of a few turbo'd cars (one of them very hard driven), some not and a crap-ton of motorcycles. We're not messing with your dad's Quaker State anymore. Heck, I've witnessed even the old garbage oil do some pretty amazing endurance. If you want to waste money, then go ahead.
    To me the people that insist on low oil change intervals are the same folks that insist on putting high-octane gas into their vehicle that doesn't require it, thinking it gives them some kind of advantage.
  17. Sep 29, 2021 at 9:36 AM
    #57
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Back in the day I used to change my oil at 5K with top teir synthetics. My buddy would take my used oil and run if for another 5K. True story.
    Kev250R, shotgunbilly420 and Junkhead like this.
  18. Sep 29, 2021 at 9:39 AM
    #58
    maxmk8
    $15 oil wrench
    $5 oil filter
    $30 in oil
    ~$50 for me
    Subsequent $35 oil changes.
    minium likes this.
  19. Sep 29, 2021 at 9:39 AM
    #59
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I believe it. I had a co-worker that would do the same thing. The cheap bastard.
  20. Sep 29, 2021 at 9:46 AM
    #60
    Grossomotto
    2017 4WDV6LB6MT
    My buddy really had to be. He was a courier and drove 60k miles a year, just supplemented his oil with mine. His 1st gen ran to 450k miles before he sold it (all fluids were leaking from everywhere)
