Synthetic oil change every 10k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VanGo3, Sep 28, 2021.
  1. Sep 30, 2021 at 11:08 AM
    #141
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Motor oil is getting thinner along with the tolerances within more modern engines. I seen an engine use 0W20 oil. That is closing in on sewing machine oil if you ask me. Back in the 60s, 70s and 80s the oil molecule was bigger and could shear, this and the dirt would reduce viscosity. This is why you changed your "mineral" engine oil every three thousand miles. The oil that you changed was returned to a recycling center and once they removed the dirt the oil's viscosity returned. I remember buying recycled oil much cheaper and was just as good or better.
    Enter the year 2021 and the oil withstands temperature much better, stays cleaner much longer and the viscosity remains within the oil much longer.
    SLeeper512 likes this.
  2. Sep 30, 2021 at 11:52 AM
    #142
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    0W16 recommended for our RAV4. When I change the oil it gushes out of the sump in about two seconds.
    hfjeff likes this.
  3. Sep 30, 2021 at 2:26 PM
    #143
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I also enjoy wrenching, however I don't like to do things which don't really need to be done, just for the sake of doing them. To keep my wrenching hands busy, 20 years ago I bought a project car, which has spawned other project cars and MC's over the years. Now with two VW's, a couple of ATV's, a house and a GF with a project car of her own and a house well I'm rarely at a loss for things which need fixin' o_O
    SLeeper512 and Junkhead like this.
  4. Sep 30, 2021 at 3:40 PM
    #144
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    No trolling, no sarcasm, no bullshit. All serious. On more than just one vehicle.
    Been using synthetic since 1978. Since that time I have learned it qualities, properties, abilities, and I have full confidence in it.
    I have been inside the engines, I have done the compression checks, I have seen the evidence.
    It truly does what it is designed to do and I'm fortunate to have discovered it so early in my life. I let it perform just as it was intended to do.
    SLeeper512 and DAS Taco like this.
  5. Sep 30, 2021 at 3:45 PM
    #145
    TartanEagle
    '17 ACLB 4x4 MT
    A post earlier joked about throwing out the cereal, tossing half the paint, etc. jokingly.
    But he was exactly right. If nothing is wrong with the oil, why toss it? It's doing the same quality job at 15,000 miles it did at 3,000 miles.
    Yes, I have been inside the engines. I have done compression tests. I don't ignore maintenance, don't ignore signs of trouble or wear. I replaced or repair when needed. Changing the oil early just isn't needed, so I don't.
  6. Sep 30, 2021 at 4:13 PM
    #146
    MasOlas
    MasOlas Well-Known Member
    Dallas, TX
    2019 Tacoma TRD OR
    The 5k vs 10k numbers are out there if you care to educate yourself.
    TartanEagle likes this.
  7. Sep 30, 2021 at 4:32 PM
    #147
    TacomaVirus
    TacomaVirus Well-Known Member
    Nick
    2020 Cement TRD Sport
    Do you have any oil analysis results after 30-50? Curious how you know the oil has nothing wrong with it. That being said, I guess the proof is in the pudding with 297k miles.
    Side note, what type of vehicle and motor is this vehicle?
  8. Sep 30, 2021 at 4:39 PM
    #148
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    For me it’s s not about 5k vs 10k. It’s every 6 months vs 12 months. I’ll barely have 3300 miles when I take it in for the 12 month oil change in a couple of weeks.
  9. Sep 30, 2021 at 4:44 PM
    #149
    trucknh
    trucknh Well-Known Member
    Southern NH
    Whats does an oil change cost $20; Spend an "extra" 20 bucks if it makes you feel good, or split the difference and change it a 7500.
  10. Sep 30, 2021 at 5:05 PM
    #150
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    It would be very interesting to see the results of a Blackstone oil test for your oil. Synthetic oils are wonderful, and what your doing without any engine problems is pretty neat.
  11. Sep 30, 2021 at 5:42 PM
    #151
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    After realizing 0W16 was fetching a premium and was difficult to find in my local stores my mechanic told me to just run 0W20 in my Rav4 which I have been doing for the past 35k miles with no issues. He explained that a four point viscosity difference is negligible and will not harm my vehicle in any way. I believe him
  12. Sep 30, 2021 at 8:33 PM
    #152
    VanGo3
    VanGo3 [OP] Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    :drevil:
  13. Oct 1, 2021 at 5:39 AM
    #153
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Consensus … I’m having dealer change mine at 5000 intervals … Decided. I think it’s good to give everything a once over while having this service. Yes … for me, always have used local dealer.
  14. Oct 1, 2021 at 6:19 AM
    #154
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    This is blasphemy bro!
    TartanEagle[QUOTED] likes this.
  15. Oct 1, 2021 at 6:56 AM
    #155
    willie2
    Nova Scotia Canada
    4 Banger 5 spd
    0W16 is scarce here also but same price as 0W20 so I will stick with it for the 0.000001% increase in fuel economy.
  16. Oct 1, 2021 at 7:06 AM
    #156
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I see 0w16 readily available in Mobil1 and Valvoline at Meijer at no additional cost. That said...0w20 won't hurt a thing. All 0w20s are all synthetic. It's 5w20s where you have to pay attention. They are available in conventional, blends and synthetics.
    That's why in Toyota vehicles that recommend 0w20 the owner's manual cautions against using 5w20. 5w20 will not hurt the engine. It's just that Toyota realizes that most people haven't a clue about oil or what may be in their engine. So to avoid the possibility of of someone puttering around in stop and go traffic or short tripping for 10k miles on a conventional oil they just basically discourage it. I run 5w20 in my wife's Corolla....but it's synthetic.
    Slick Taco[QUOTED] likes this.
  17. Oct 1, 2021 at 7:12 AM
    #157
    Plain Jane Taco
    USA
    And before the "modern engines have tight tolerances" crowd rolls in stating you can't run a heavier oil....a 0w16 at cold startup is considerably more viscous than a 0w20 is at operating temperature. So if running a heavier oil leads to damage then you would also be doing damage to your engine the first few miles using 0w16.
    And just for a little peace of mind...look up viscosity recommendations for the same engine in other countries.
  18. Oct 1, 2021 at 7:50 AM
    #158
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    So let me understand your statement. The 0w16 behaves like a 20 weight oil when cold?
    That claim is against the viscosity test as defined in ASTM documents. (Sorry, I forget the document number). The "winter" viscosity is tested at 0*F. The "summer" viscosity can be tested at either 100*F or 212*F.
    I think there is some fundamental comparison problems....
  19. Oct 1, 2021 at 8:01 AM
    #159
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    The bottom line is that everyone has their own opinion, and everyone thinks their opinion is right. Nothing any of us say to anyone else is going to change their minds, and all that happens is people get frustrated, throw insults around, etc. If we could have a civil exchange of ideas and just agree to disagree that would be one thing, but these threads never seem to go that way.
  20. Oct 1, 2021 at 8:04 AM
    #160
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    I should visit you, so you can be entertained with my truck. :)
    I'm pretty on top of maintenance, though living in an RV it is often a struggle to do DIY maintenance.
