Synthetic Oil Change Intervals.
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Aug 25, 2011.
How long do you go between Synthetic Oil Changes?
Poll closed Sep 24, 2011.
  1. 3,000 on the dot.
    5 vote(s)
    3.4%
  2. 3,000 to 4,000
    20 vote(s)
    13.4%
  3. 4,000 to 5,000
    21 vote(s)
    14.1%
  4. 5,000 on the dot.
    48 vote(s)
    32.2%
  5. 5,000 to 7,500
    26 vote(s)
    17.4%
  6. 7,500 on the dot.
    3 vote(s)
    2.0%
  7. 7,500 to 10,000
    16 vote(s)
    10.7%
  8. 10,000 and beyond...
    10 vote(s)
    6.7%
  1. Aug 25, 2011 at 8:19 AM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    I know the "What type of oil do you use?" and the "Synthetic vs. Conventional Oil" topics have been beaten to death but I am interested in intervals between oil changes.
    I did a little bit of research on Oil Change Intervals and I was just wondering how long other people go between oil changes when using Mobile 1 or any other type of synthetic.
    I bought my truck with 21,500 miles on it and I have personally always used Mobile 1 with a Bosch filter and have been going 5,000 miles between changes just to be on the safe side. But from what I've read maybe you can go longer with synthetic.
    Thanks for the input.
  2. Aug 25, 2011 at 8:36 AM
    Panther
    Panther Well-Known Member
    Kaiden
    BH, ME & BOS, MA
    2021 TRD Sport DCLB
    OEM lift. Ditch lights
    I usually do 4,000 ish with Valvoline. It depends on how many miles have been spent driving on dusty roads I guess. I just like keeping things clean. Probably excessively.
  3. Aug 25, 2011 at 8:37 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I do 5K with Redline and a K&N. Works for me.
  4. Aug 25, 2011 at 8:54 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    5,000 on the 5 and 10...easy to remember
    Mobil 1 and a Napa Gold (wix) filter.
    The Jeep is on the same schedule.
    Howard
  5. Aug 25, 2011 at 8:55 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
  6. Aug 25, 2011 at 10:26 AM
    veg hed
    Utah
  7. Aug 25, 2011 at 10:36 AM
    scocar
    scocar hypotenoper
    The manual specifies 7500 for regular service, 5000 for severe service (towing, offroading, stop and go, etc.), if I recall correctly. This is for non-synthetic.
    So, doing it more frequently than those intervals with synthetic is a complete waste of time, money, and good oil.
  8. Aug 25, 2011 at 10:41 AM
    veg hed
    Utah
    Where in the manual did you see the 7,500 for regular service?
    I agree that doing more frequent change with synthetic is a waste of time. What would you consider to be a more frequent interval then? 5,000?
  9. Aug 25, 2011 at 10:41 AM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    change it at 5k give or take 100 till i have time. i'd rather be cautious and change mine more often than necessary to make sure she keeps running good. it's not that much effort to change it and i need to rotate my tires then anyways
    CanisLupus likes this.
  10. Aug 25, 2011 at 10:58 AM
    scocar
    scocar hypotenoper
    Yes. I am starting on a 7500 interval after strarting with synthetic a couple changes ago with 5000 intervals and no problems. I had no idea what was used by the previous owner, so I was being conservative in case I started getting some leaks, but I've had none.
    I'd have to go look. It is either in the owner's manual, or in the service record booklet.
    You can also look on toyotaownersonline.com. Enter VIN, get service intervals...
  11. Aug 25, 2011 at 11:02 AM
    phsycle
    phsycle Well-Known Member
    CA
    My Land Cruiser gets 9-10k oil change intervals. Always a used oil analysis after each change. I've had the best results with Valvoline and Amsoil full-syn fluids. I use WIX, but have used K&N and Amsoil EaO as well.
  12. Aug 25, 2011 at 11:13 AM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    I do the filter change every 5000 miles and change the Amsoil every 15000 seems to be doing fine.
  13. Aug 25, 2011 at 11:16 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i go 6000 with Pennzoil Ultra
  14. Aug 25, 2011 at 11:19 AM
    scocar
    scocar hypotenoper
    Just a note to all posters: The OPs truck is a 1st gen 3.4, so opinions for the same spec vehicle and its factory-recommended intervals are probably most helpful.
  15. Aug 25, 2011 at 11:22 AM
    RideFast
    Jesse
    Tacoma
    Yea and at 3.99 for toyota filter why wouldn't anyone use oem.
  16. Aug 25, 2011 at 11:48 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i use royal purple and K&N filter usually every 3kish but extended this time due to impinging hurricane, i aint changin my oil before it
  17. Aug 25, 2011 at 11:51 AM
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
    Clicked on 5000
    That's 5000 km for me, so 3000 to 3500 miles for me! :eek:
  18. Aug 25, 2011 at 12:48 PM
    veg hed
    Utah
    Whoops, I should clarify Miles!!!
    I forgot about our brothers in the great white north, or any other country for that matter. Thanks for pointing that out.
  19. Aug 25, 2011 at 2:43 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I run Mobile One and change it every 6 months (which comes out to around 2,500 miles.)
  20. Aug 25, 2011 at 2:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    5k miles with toyota oil filter and penn platinum or ultra...used ultra the last 2 changes.
