synthetic oil chenges 2.7L
Discussion in '4 Cylinder' started by snow dude, Jul 10, 2012.
  1. Jul 10, 2012 at 1:11 AM
    snow dude
    snow dude [OP] Well-Known Member
    Darius
    Brush prairie
    07 tacoma SR5
    undercover canopy, K&N intake, 1.5in aal, 1in diff drop doug thorley headers, total chaos upper control arms, debadged, fog lights, Nokya Arctic Yellow fogs, 25% tint, isimple aux, kings remote reservoir,
    Now hearing that the new 2012 tacos 2.7L come with fully synthetic oil, with this change does this mean that the 07's can change the oil at every 5k with fully syntheti? I'm currently running castrol high mileage and changing every 3k miles at 109k onthe motor. What are the pros and cons about this?
  2. Jul 10, 2012 at 1:25 AM
    2004tacoprerunner
    2004tacoprerunner Well-Known Member
    byron, mn
    2004tacoprerunner
    Damn, 3k is kinda excessive for a modern non-turbo charged engine even with dino.
    Swapping over to a synthetic and doing 5k is no problem at all.
    I'm doing this now on my 04 with 139k on it
  3. Jul 10, 2012 at 9:51 AM
    snow dude
    Darius
    Brush prairie
    07 tacoma SR5
    What about the life of the motor and gas milage?
  4. Jul 11, 2012 at 5:04 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The engine hasn't changed since 2005. The only reason for the 2012's requiring synthetic oil is because they switched to recommending the use of 0W-20 viscosity oil. The switch to lighter weight oil is for gas mileage purposes ONLY, and helps Toyota meet their fleetwide fuel efficiency goals/requirements. Because regular 0W-20 oil breaks down more easily in heat, Toyota wants customers to use synthetic because it's more robust.
    My 2006 (again, same engine) owner's manual recommends 5W-30 dino with 5,000 mile change interval. I would say that it's logical to assume that you'd be completely fine switching to synthetic and doing a 5,000 mile interval. In my opinion, you should stick with 5W-30 though.
  5. Jul 11, 2012 at 5:16 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    Toyota Reccomends 5w-20 or 0w-20 for the 2.7L 2TR-FE
    the 1GR uses 5w-30.
  6. Jul 11, 2012 at 5:48 AM
    ecoterragaia
    Central Virginia
    Well they must have made some changes to the owner's manuals since 2006 because mine doesn't differentiate between the two engines with regard to oil viscosity. 5W-30 is recommended across the board . . . I'm looking at Pg. 361 and Pg. 396 of my owner's manual right now.
  7. Jul 11, 2012 at 5:59 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    yeah, it says 5w30 on my oil cap on my 05. i wanna say it was 07 when it switched to 5w20? maybe 08?
  8. Jul 11, 2012 at 6:09 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    do your oil caps say just 5W-30?
    mine says both 5W-20 and 0W-20.
  9. Jul 11, 2012 at 6:11 AM
    ecoterragaia
    Central Virginia
  10. Jul 11, 2012 at 6:14 AM
    danteisme
    South Western PA
    ditto
  11. Jul 11, 2012 at 6:17 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    we need to find someone with an 07 to chime in on this rofl
  12. Jul 11, 2012 at 6:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, mine says 0-20 & 5-20. Have run both with no difference in mpg. Always run 5k using full syn with toyota filters. No issues.
  13. Jul 11, 2012 at 6:26 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    yeah x2 i started using 0W but it was getting irrtating to find it so i switched back to 5w20.
  14. Jul 11, 2012 at 6:40 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, that and they want 9.00 a qt for any 0-20 you can find and there are not any 5 qt with a filter sales on 0-20. So 45.00 just for 0-20 syn or 27.00 for 5-20 Penzoil platinum with a filter. I just get a filter for one of the other vehicles & use the toyota filter with the 27.00 sale oil.
  15. Sep 21, 2013 at 6:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There will be no difference in MPG between those oils because they are the same weight. 20 weight.
  16. Dec 8, 2013 at 11:53 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  17. Dec 8, 2013 at 11:55 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    2008....
  18. Dec 8, 2013 at 2:09 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    My 2011 2TR specs 0w-20 only, on the oil cap and in the Manual.
  19. Dec 8, 2013 at 2:30 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    My 07 has the same cap.
  20. Dec 8, 2013 at 4:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
