Synthetic Oil Damaging Engine??
Discussion in 'General Automotive' started by rwilso03, Nov 19, 2009.
  1. Nov 19, 2009 at 7:39 PM
    rwilso03
    rwilso03 [OP] Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    So, my dad just threw a rod in his 97 F-150 and according to the dealership it was because he was using synthetic oil even though his owner's manual said to only use conventional. This engine only had 145k miles on it an I know for a fact he had his oil changed every 3k miles throughout the life of that truck. The mechanic told him that his oil pump was not equipped to handle the synthetic oil. I thought that the oil is the same weight so matter what the type just as long as it has the same rating? Sound fishy to anyone else? Oh and my dad said that when it started knocking he changed over to regular oil at his last change and it went away for a little while before his engine completely went. I don't get it...:confused:
  2. Nov 19, 2009 at 7:44 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    That's BS, SAE certified oil, you can put what ever you want in your engine as long as the the oil weight is correct. 5W-30 is the same whether or not it is Dino oil or synthetic. The old pump makes no freaking difference what so ever.
  3. Nov 19, 2009 at 7:45 PM
    rwilso03
    Russ
    Dayton
    That's what i thought but i guess the guy somehow has my dad convinced now that the synthetic oil is what did it (not that that is hard to do)...
  4. Nov 19, 2009 at 7:47 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    That doesn't sound right to me on that one, that knocking could have been the lower rod bolts getting loose or space between the rod bearings and crankshaft, due to wear and not synthetic oil. Did he ever hear that knocking before at all? Maybe a couple thousand miles ago?
    Never have heard about that with the oil pump, maybe he just doesn't know what happened and made that up or something?
    What does everyone think on this one?
  5. Nov 19, 2009 at 7:51 PM
    jandrews
    '09 FourDubDee TRD OR
    The engine damage had nothing to do with him running synthetic oil. More likely, it was the fact that it was a 90s-era Ford...
  6. Nov 19, 2009 at 8:03 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    IMO--An engine is not going to "throw a rod" due to using a synthetic oil. There was obviously a mechanical problem and I seriously doubt the type of oil is going to cause it. Would have happened at some point with conventional anyways. If synth could have actually "caused" this, we would have already heard plenty more documented incidences. There's way too many people using synthetic oil in their engines that have run just fine. I'm not buyin' it. :confused:
  7. Nov 19, 2009 at 8:08 PM
    sebiotacoma
    sebiotacoma Well-Known Member
    Corpus Christi Tx
    TRD OFF ROAD
    wet okole seat covers,weathertech floor mats,wheel skin wheel cover,factory bed mat,factory skid plate,s.s. n-fad steps,undercoating,transmission TSB,REAR SPRING TSB,TRUCK BED DIVIDER/ROD HOLDER,paint protection film on hood-lamps-fogs-door-edge / avid off road rear bumper guard
    What brand of oil were you using
  8. Nov 19, 2009 at 8:23 PM
    rwilso03
    Russ
    Dayton
    To be honest with you, I have no idea. I think he just took it to those quick change places and payed the extra money for their synthetic oil change. Maybe that could have been his downfall.
  9. Nov 19, 2009 at 10:12 PM
    carmellocafe
    KEVIN
    N. California
    X2
  10. Nov 20, 2009 at 12:34 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    X2
  11. Nov 20, 2009 at 12:36 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    uhh get that thing back on synthetic...its not the fact that its runnin synthetic that threw the rod....its worse for you to run conventional now since hes been runnin synthetic its whole life...
  12. Nov 20, 2009 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When did he start using the synthetic oil?
    Has he been using it recently? Or the entire life of the truck?
    I call BS on the mechanic....... but... If the truck has been running on conventional oils most of its lifetime and you suddenly changed to synthetics, there could be some issues there. Synthetics penetrate more and cleanse also - which could disrupt the sludge/buildup that's already been in the engine for all those years.
    But, I still call BS on the mechanic pulling that excuse out of his ass. The truck has 145K miles on it - it could be anything.
  13. Nov 20, 2009 at 5:31 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Ford + Quickie Lube Shops = Destined for Failure :D
    I took an old G/F's car to a VW dealer for prematurely worn rear brakes (wore before the front ones).
    I told the service advisor that something is wrong, hinting that the calipers were seizing up, and he had the nerve to tell me that newer cars have more of a 50/50 front to rear brake bias so it is normal. What an F-tard.
    :rolleyes:
    So yeah.... don't always believe these dealers.
  14. Nov 20, 2009 at 6:09 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Be glad he got that many miles out of it. My dad had a 96 F-150 that blew three engines before reaching 60k on each of them. With regular oil and maintenance.
  15. Nov 20, 2009 at 6:10 AM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    If it has FORD in the name, that should be enough info for you! I had a 93 Ranger that was always getting fixed for some reason or another.
  16. Nov 20, 2009 at 6:39 AM
    jandrews
    Late model (2005+) Fords are excellent vehicles in quality and reliability. This includes the F-series trucks.
    But Ford didn't get turned around until about 5 years ago. During the 90s, they were shit...just as bad as GM and Chrysler. Of the Big 3, Ford is the only one that seems to be fighting its way back to competitive quality with imports.
    But I would still never buy anything they made before the 2005 model year.
  17. Nov 20, 2009 at 6:50 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's a bunch of B**L S**t. Synthetic vs regular wouldn't make a difference, but if you added any kind of "oil additive" that might make a difference, some of those snake oil things can loosen sludge and do bad things.
  18. Nov 20, 2009 at 11:07 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    x2
    I usually hate all domestic automobiles. I scoffed at anybody who told me to buy a ranger or something during my tacoma search.
    But I must admit, Ford is really starting to get their shit together.
  19. Nov 20, 2009 at 11:23 AM
    DIRTRIDER
    DIRTRIDER Active Member
    EAST AURORA,NY
    07 WHITE SR5 4X4 V6
    BULL BAR,DRIVING LIGHTS W/ OEM SWITCH,BLACK STOCK WHEELS,265/75/16 TIRES,XM RADIO,EXTRA BED D-RINGS,SPRING TSB,5100'S @ 1.75",FOG LITE MOD, A/C COMP.MOD
    What engine was in the truck ? 4.2 v-6 or 4.6/5.4 v-8. I worked for ford for 20 years at the dealership level and they had sludge problems in the v-6 creating low oil pressure and piston slap problems causing excess play in the cylinders on the v-8's. In fact, when we did customer oil changes the motorcraft oil we used was a semi-synthetic speced by ford.synthetic oil did not cause your oil pump failure.
  20. Nov 20, 2009 at 12:11 PM
    rwilso03
    Russ
    Dayton
    If i remember right it is the 4.2 V6
