synthetic oil for 10k?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by olive, Aug 4, 2016.
  1. Aug 4, 2016 at 12:32 PM
    olive
    olive [OP] Member
    Given the 5k maintenance for regular engine oil, do you ever push synthetic to 10k between changes in your V6?
  2. Aug 4, 2016 at 12:35 PM
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    I've heard that you can, but for safe measures I personally stick with the 5k interval
  3. Aug 4, 2016 at 12:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would just stick with 5k changes. You need to rotate the tires every 5k anyways so that gives you something to do while the oil is draining plus it gives you the chance to look everything over.
  4. Aug 4, 2016 at 12:47 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "it gives you the chance to look everything over." I like this. I don't understand these ridiculous OCI unless you trade every 3 yrs.
    kidthatsirish and shakerhood like this.
  5. Aug 4, 2016 at 12:56 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Is the filter rated for 10k?
    I change both every 5k, with Mobil 1.
  6. Aug 4, 2016 at 1:08 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    160k on mine now with mobil one and zz3 filter at 10k intervals. No problems at all
  7. Aug 4, 2016 at 1:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Only any independent lab test will answer your question correctly. Because it will determine the health of your engine, the additives in your oil of choice, and tell you the remaining life/mileage you can safely expect.
    That said, I know many who have made this effort and been shocked to find that both time and mileage remaining were much greater than they would have expected.
    Give it a try. Everything else is speculation.
  8. Aug 4, 2016 at 1:15 PM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I change the oil (Mobil 1 EP) at 10k but change the OEM filter every 5K then top off with half a quart.
    There's a member here who would go up to 14K miles on Mobil 1 EP and a larger after market filter who has over 400K miles on his truck. I believe QYNLA is his user name.
    Crom and Rambo MARINE Recon like this.
  9. Aug 4, 2016 at 1:24 PM
    shakerhood
    Southern Ohio
    Same here.
  10. Aug 4, 2016 at 2:17 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Oil is cheaper than metal...I change mine every 5k. I use either Mobil1 or QS Ultimate Durability with a OEM filter, usually takes me about 40 minutes cause I'm old and I kinda look stuff over under the hood and under the truck. Cost me less than 32 bucks, pretty cheap insurance I think.
  11. Aug 4, 2016 at 3:52 PM
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    Mechanic friend of mine heard I was doing 10-12K on my T100 (which I did, and it now has 260K) and said that if I went past the 6 months that was bad juju. He thought time was more important than miles. Something about the chemistry or PH of the oil changing.
    I kind of go by that. But I'll go to 8 months looking for a good time to do it (weather often). I think if I needed to drive 10K in a 6 month period for some reason, I'd be cool with keeping an eye on the level and then ditching that oil at 6 months. But if 10K means a year or more, I'd say no.
  12. Aug 4, 2016 at 4:23 PM
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    Mobil 1 at 7500 for me, seems like a reasonable interval with synthetic.
  13. Aug 4, 2016 at 4:30 PM
    george3
    New Jersey
    I don't think there is a filter that is any good past 7500 and unless U investigate and spend the $$ 5000 is about it.
  14. Aug 4, 2016 at 4:55 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Most filters will go past 5000 miles. Ive gone 7000 miles on toyota filters
    Rambo MARINE Recon likes this.
  15. Aug 4, 2016 at 6:17 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've gone 10,000 miles on Mobile 1 and changing only the filter every 5000 for years on every vehicle I've owned. I have 172,000 on the Tacoma and 95,000 on the Honda. The only time I add oil is to top it off after the filter change. Actually 10,000 is being conservative. You can probably be safe for 15,000
  16. Aug 4, 2016 at 6:20 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    10k on Mobil 1 and Toyota filter. I really need to get a sample and send it off to Blackstone labs, I already have the kits.
  17. Aug 4, 2016 at 6:47 PM
    bchannell
    bchannell Active Member
    Bob
    2010 Tacoma SR5 4x4
    None
    10k is not out of line. As stated an oil analysis would tell for sure. 7.5k seems a reasonable compromise. Any top notch filter will do 10k, such as Fram Ultra or purolator Pure One or Bosch Premium etc. Go over to
    bobistheoilguy.com and read up.
  18. Aug 4, 2016 at 7:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Search here for filter comparisons, Chris4x4 has cut open several of them.
  19. Aug 4, 2016 at 8:12 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I've been changing my oil twice a year ( May 1 and November 1) regardless of miles since the weather is nice and it's right before the extreme seasons. I've used synthetic for the past 4 years and every time I change it, the oil looks pretty clear as if it was just put in.
    I've been debating going once a year oil changes, but we'll see. I guess with the fumoto valve it isn't really a chore since it's a 20 minute job with zero cleanup.
  20. Aug 4, 2016 at 8:38 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    2 times a year, and the oil looks clear..... How many miles? This is hard to believe unless you don't drive it much. My oil comes out pretty dark at 10k miles.
