Synthetic oil for 1st gen?
Discussion in '4 Cylinder' started by brigas, Jul 23, 2012.
  1. Aug 26, 2021 at 10:33 AM
    Tacoma Cutout
    Tacoma Cutout Well-Known Member
    I've been using Walmart brand full synthetic oil and filters for years in all my vehicles, with oil changes around 5K. 1990 Hyundai Accent went 199K then crushed because of emissions issue in Kalifornia, such a joke. Cost more to fix then car was worth.... 1999 4cyl Camry, 309K, then crushed ( see Hyundai above) both these cars ran fine... 2003 Lexus GX470, 170K, sold no issues. Currently 1998 2.4 Tacoma, with 175K no issues and 2010 Lexus is350C with 99K with no issues. Love me some Toyotas!
  2. Sep 2, 2021 at 10:18 PM
    trustyrusty436
    trustyrusty436 Well-Known Member
    2018 Tacoma, auto, 2.7, RWD Access cab, long bed, Utility model
    LCE exhaust header, AF Dymanics CAI, MagnaFlow cat back
    When I do the first owner oil change on my 2018, 2.7, probably going go with Supertech from Walmart. Truck has about 19k on it and I just drive it as everyday driver. If you have a high mileage engine, try ZMAX in it to clean out the sludge and deposits of crud in the motor.
  3. Sep 6, 2021 at 6:55 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there Should NOT be Any SLUDGE / Deposits in an 19k engine
    zmax might help with plugs temporarily
    sludge in sump or upper heads can rarely be removed with a flush
  4. Sep 6, 2021 at 7:04 AM
    Clearwater Bill
    Billy
    Largo Florida
    @ayyzee, this thread ended in 2012. OP has not been around since '13.
    Zombie fan you must be.
  5. Sep 6, 2021 at 7:18 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Short answer. You can use either syn or dino oil. Any brand.
    Just open the Owner's Manual (OM) to determine which viscosity is recommended and the API grade (American Petroleum Institute).
    Follow the change interval in the OM.
    Use a good oil filter. Some of the best filters are Toyota, WIX, NAPA, ACDelco and Bosch.
  6. Sep 6, 2021 at 12:38 PM
    trustyrusty436
    You need to read the post buddy! Do you know what ZMAX is? I think not!
    Potomus Pete likes this.
  7. Sep 11, 2021 at 10:29 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Walmart Hypertech synthetic is more than good enough for me. Just change the oil as recommended by the owners manual
  8. Feb 11, 2022 at 8:40 AM
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    Wondering how it's going to hold up with an oversized filter, never heard of this for a Taco DD but common on domestic build ups.
    Slightly baffled at sending oil to be analyzed but, some folks like to know the miniscule details?
    ZMax possible after 100,000 mi with "I have time" oil changes in between, finally going to pull the OEM plugs to see how they have been holding up first before adding. I do run the ZMax fuel about once a year, usually after winter when the stations lower the octane since it helps burn off any moisture build up.
