Synthetic oil for an old truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bmanjr, May 14, 2025.
  1. May 14, 2025 at 7:04 AM
    Bmanjr
    Bmanjr [OP] Member
    2023 Tacoma
    I was told that it’s not good to use synthetic oil on an old car. I have a 97 Tacoma. I was told the seals can leak. Is this true? What type of oil should I use?
  2. May 14, 2025 at 7:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It'll be fine
    That advice is from back when cars had much more primitive gasket/sealing systems like cork and rope crankshaft seals
  3. May 14, 2025 at 7:45 AM
    Tacotony1624
    Tacotony1624 Well-Known Member
    Central Valley/California
    1995 Tacoma 2.4L. 2WD/RWD
    Bmanjr
    I have a 95
    2.4 with 200k and I use 5/30 Valvoline full synth oil and no leak whatsoever or oil loss.
    Use a solid filter and good oil and change it often and you’ll be fine.
    If you do have a leak you’ll notice lol
    thinking out loud here : I try to stay consistent with the same brand and type of oil I use (either conventional or synthetic). Never had a issue
    check that valve cover first thing. Easy to replace and a very common culprit for oil loss on older Tacoma’s.
    hope this helps
  4. May 14, 2025 at 9:50 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I’m going to agree with “was told by” opinion
    synthetic oil, in layman’s terms, is thinner
    More chance of leaks
    More chance of oil deprivation (bc of miles to engine internals)
    this has been and will be a hot debated internet topic
    Just my opinion
  5. May 15, 2025 at 4:39 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    All modern oil are detergent oils......so now they all have an equal chance of weeping
    makes no difference
    cold starts is what accelerates wear......synthetic oil is best defense against this
    ZColorado likes this.
  6. May 15, 2025 at 4:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    so you're saying a 5w30 syn is 'thinner' than a 5w30 dino?
    viscosity is viscosity, regardless of the composition source.
    Kleenax and soggyBottom like this.
  7. May 15, 2025 at 4:58 AM
    soggyBottom
    soggyBottom Well-Known Member
    SR-71A likes this.
  8. May 15, 2025 at 5:05 AM
    soggyBottom
    SAE J300 defines 20 weight engine oil e.g. 0w20 at 100c to have a thickness between 5.6 and 9.3 cSt (Centi Stokes). Doesn't matter what additives are in it or what it's made of. If it has a SAE label on the bottle, and it's Xw20 engine oil, it will have the same thickness range at 100c.
  9. May 15, 2025 at 1:15 PM
    rish57
    rish57 Well-Known Member
    2000 Tacoma 3.4L SR5 4x4
    :rofl:
