Synthetic oil or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wb_doublecab, Jul 27, 2022.
  1. Jul 27, 2022 at 8:34 PM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    outdoor frenzy likes this.
  2. Jul 27, 2022 at 10:24 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Make sure its Nitrogen. Best to send out the air for a sample. Even better is to remove the valve cores and let all of the old air out overnight before re-filling.
  3. Jul 27, 2022 at 11:28 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Has anyone sent out a sample to see if syn or dino flavored blinker fluid performs better than the other?
  4. Jul 27, 2022 at 11:30 PM
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    (waiting for links from 35 different threads on the subject)......
  5. Jul 28, 2022 at 12:04 AM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    Blend you get the best of both worlds :anonymous:
  6. Jul 28, 2022 at 12:38 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This is an example of what happens when you use synthetic oil….. I’ll only use regular oil in my engine to prevent something like this.
    https://mustangforums.com/forum/5-0l-general-discussion/368307-i-m-done-with-this-car.html
    “My car was idling like crap the other day so I figured since I just got it, it may have been awhile since anyone changed the oil out. I decided to go ahead and change the oil. I used Mobile 1 synthentic oil like I was reccomended on here. Anyways, I drain out the oil and noticed it was extremely dark and even after 10 minutes of draining, it was still coming out. I decided to go ahead and flush it to make sure all the bad stuff got out. I hooked up the hose, ran water through the engine, started it up and was waiting for the water to come out clean (The engine never went above idle so I was told this would be ok). Anyways, About 3 minutes into this, then engine starts shaking and shuts off. I figured it was all cleaned out so I plugged it up, added the oil and figured I was ready to go. WRONG! The car won't freaking start now. This car has been nothing but trouble for me, I think I am done with it.”
  7. Jul 28, 2022 at 1:33 AM
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    "Ran when parked, I know what I got - No low baller's"
    Grindstone and Hairless_Ape like this.
  8. Jul 28, 2022 at 2:59 AM
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    This question is a read the book question and you guys still bang your head on the wall answering it ,who’s the dummy here ? This will happen for ever if you keep answering this lazy questions.or maybe you got nothing better to do
  9. Jul 28, 2022 at 5:44 AM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    I run synthetic in my 2016 every oil change. I go 5-6k between changes
  10. Jul 28, 2022 at 5:48 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I for one have nothing better to do. What, you expect me to turn off the TV and go outside or somethin'? It's hot!
    andagi808 and davidstacoma like this.
  11. Jul 28, 2022 at 6:23 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    and polish the knueter valve while changing the oil...
  12. Jul 28, 2022 at 6:36 AM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    I've had good luck with Pennzoil Ultra platinum.
    davidstacoma likes this.
  13. Jul 28, 2022 at 7:03 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Jul 28, 2022 at 7:37 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    The best part of that thread is other people advising him that he can tear and rebuild the motor down and have it running again for $600 or less in parts. This is a guy that just ran water through his engine to clean out oil. Like he's a candidate to undertake a successful engine rebuild. Hilarious
  15. Jul 28, 2022 at 7:47 AM
    #35
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's the 21st century, no reason for conventional oil to even still be made. Use synthetic of the correct viscosity and change every 10,000 miles. Yes, every 10,000 miles is often enough. Brand doesn't matter much.
    outdoor frenzy and zoo truck like this.
  16. Jul 28, 2022 at 8:31 AM
    #36
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If you don't they with get rusted to a point they will need replacement.
    RIX TUX[QUOTED] likes this.
  17. Jul 28, 2022 at 8:36 AM
    #37
    zoo truck
    None
    Make sure you read the date, and where it comes from....a single mediterranean country is best. You want to avoid a mix of this oil from different countries.
  18. Jul 28, 2022 at 11:43 AM
    #38
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Was that guy serious with the water?
  19. Jul 28, 2022 at 12:57 PM
    #39
    zoo truck
    None
    If they are, they have more problems than just a car that won't run.:crazy:
  20. Jul 28, 2022 at 1:13 PM
    #40
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Even "Full Synthetic" is a misnomer, almost all of them use a dino add pack and are group 3 base stocks.
