Synthetic Oil Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by itsmebags, Jan 22, 2020.
  1. Jan 23, 2020 at 1:08 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    No downsides to using, or switching to synthetic at any time. Synthetic costs a little more upfront, but you can safely go to 10,000 mile oil change intervals which will mean less money in the long run with no loss of protection.
  2. Jan 23, 2020 at 1:21 PM
    Hoff
    Hoff Well-Known Member
    No matter what oil you use oil gets dirty. So why would you push off your oil change with dirty synthetic oil.
    1997tacomav6 and tacoma_ca like this.
  3. Jan 23, 2020 at 1:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Exactly.
    For every person who has a 400k mile truck who swears by synthetic, there are probably 10 others who used whatever conventional walmart crap was on sale, and probably weren't even religious about the 5k change intervals, either.
    tacoma_ca and Hoff[QUOTED] like this.
  4. Jan 23, 2020 at 1:25 PM
    jbrandt
    Justin
    Because you paid $12 a quart for it and need to feel like it was a good financial decision.
  5. Jan 23, 2020 at 1:53 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    My '95 turns 25 years old next month. With a couple weeks of treating her to (likely) her first synthetic, she developed some seepage.
    I'm pretty sure that's a downside.
    GQ7227 and tacoma_ca like this.
  6. Jan 23, 2020 at 2:01 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Walmart has supertech synthetic for $15 for a 5 quart jug, their conventional was $14, seems like a no brainer. Although I of course needed another quart, and the 1 quart bottle of synthetic was 14 cents per ounce, while the conventional was 9 cents per ounce. So I guess I'll have approximately 17% conventional oil in my truck for the next oil change. :notsure:
    Also.
    Oh nooooo not another oil thread!
  7. Jan 23, 2020 at 2:06 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    just found a small leak on my '12 with 79,000 miles. been running mobil 1 since first oil change. i cleaned it up and tightened two bolts on the timing cover by the leak. if she still leaks i'll try the hi-mileage mobil 1.
  8. Jan 23, 2020 at 2:12 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    you can, just get a 'high mileage' oil, it will make the seals swell up/condition them. You will have to use high mileage from that point forward though, the moment you switch back I am pretty sure the seals will go back to normal afterwards. (could be wrong but idk why you would do this). It is high mileage oil that generally confuses people when it comes to "switching back and forth".
    Or you could just replace the seal.. depends on your needs, financial situation etc.
    tacoma_ca and ace_10[QUOTED] like this.
  9. Jan 23, 2020 at 2:17 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I switched to syn and now my head gasket leaks, coincidence? I think not!
    GQ7227, tacoma_ca and ace_10 like this.
  10. Jan 23, 2020 at 2:39 PM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    In the winter I run full syn in all the vehicles including a 1996 Camry. I've found starting is easier in the -10 to -30 + range.
    Never a leak issue
    As one poster mentioned many oils nowadays are a blend even though it may say "conventional" on the label
    GQ7227 and tacoma_ca[QUOTED] like this.
  11. Jan 23, 2020 at 2:45 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    I think conventional oil, even if a blend, has a much broader polydispersity distribution and a different set of detergents. Since synthetic has a lower average molecular weight it it does pass through seals more readily, regardless of the state of the crud that may be removed by the detergents.
    This thread is a good resource for the various modes of thinking about it, thanks.
    ace_10 likes this.
  12. Jan 23, 2020 at 3:02 PM
    jbrandt
    Justin
    Would be weird to use a high mileage oil, then switch back, as if your truck is only temorarily "high mileage", lol.
    I could see that if you switch to a high mileage when you don't really "need" to, that could cause the seals to swell, and actually induce an issue that didn't exist before.
    Ideally, we'd always fix the actual problem (replace the leaky seals), rather than a bandaid fix like thicker oil or parking in the grass so you never see an oil spot...
    tacoma_ca likes this.
  13. Jan 23, 2020 at 3:09 PM
    eon_blue
    Azusa, CA
    The only risk I've heard with switching oils and tend to believe, is when your start using a high mileage oil the additives in it are designed to help swell up old seals to prevent leaks. If you stop using a high mileage blend after using one for awhile, your seals might not be very happy about that
    I've been using a high mileage oil for a couple years now, truck only has 88k on it but she's 16 years old and so are the seals.
  14. Jan 23, 2020 at 5:59 PM
    itsmebags
    itsmebags [OP] Well-Known Member
    Germantown, NY
    2003 Green Tacoma TRD Off Road
    After all the input I’ll be using standard conventional. Figure if it ain’t broke....
    Maybe when I buy that nice 2030 Tacoma I’ll go synthetic ‍♂️
  15. Jan 24, 2020 at 5:53 AM
    #35
    1997tacomav6
    Denver
    Personally I think it’s about keeping clean oil in your engine.
    It’s easy enough to look at the dipstick to see if it’s getting dark.
    I change my oil every 5k with regular oil like clock work and never have an part fail
    from an oil issue.
    Both oils get dirty no matter so I would prefer sooner oil changes with cleaner oil
    regardless if the oil will last 10k.
    Hoff and GQ7227 like this.
  16. Jan 24, 2020 at 6:00 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Your head gasket leaks oil?
  17. Jan 24, 2020 at 7:01 AM
    #37
    coopcooper
    alberta canada
    yeah man right into my tranny
  18. Jan 24, 2020 at 7:30 AM
    #38
    Wulf
    rock raisin
    You sure it's not the valve cover?
  19. Jan 24, 2020 at 7:31 AM
    #39
    GQ7227
    GQ7227 mw survivor
    J A Y
    rear main seal?
    Wulf likes this.
  20. Jan 24, 2020 at 7:48 AM
    #40
    coopcooper
    alberta canada
    I don't have valve covers
