Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmhart32538, Oct 11, 2011.
  1. Oct 13, 2011 at 6:07 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Using the synthetic may be cheaper in the long run if you keep the truck a long time. No sludge buildup at 100,000 miles.Heat causes dino oil to sludge.If I were to use dino oil I would change it at 3,000 miles.Toyota requires synthetic oil change at 5,000 miles for a unsaid reason and I think it is because of sludge.
  2. Oct 13, 2011 at 8:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    True enough that... just take the freebie oil changes. But after the first 25k what then? Nothing anyone has related should make anyone believe you HAVE to use synthetic or, if you do choose to, that you HAVE to change it at 5k intervals.
    A minor quibble on my part: I don't think it's correct to say it's the warranty that covers the oil changes. Oil change costs aren't part of a risk pool, as would be a warranty risk pool. You completely paid for every one of those oil changes as part of the purchase price. It's buried in there but you paid for it.
  3. Oct 13, 2011 at 8:47 AM
    Swanson52
    Swanson52 Well-Known Member
    I've talked to 2 dealers in the Denver metro, and neither will change my oil at 5k because it's synthetic ('11 RC 4cyl). They straight up will not do it.
  4. Oct 13, 2011 at 10:23 AM
    billwot
    billwot Well-Known Member
    Eastern NC
    '11 Access 4 cyl auto SR5
    That's a myth!
  5. Oct 13, 2011 at 10:30 AM
    billwot
    Eastern NC
    Strange. I have taken my '11 4 banger in for the 5 and 10K services, and they installed 0-20 synthetic. On my lasit , the service writer even commented on the requirement that they use 0-20 synthetic.
    He said it is specified because it improves fuel economy, and lowers emissions.
  6. Oct 13, 2011 at 10:37 AM
    little red
    little red Well-Known Member
    Central GA
    PreRunner SR5
    Did you get the Toyota Care booklet with your purchase? You were supposed to as per Toyota. If you didn't, contact Toyota. If you did, show the dealer the note about it being covered in the 5K service intervals.
  7. Oct 13, 2011 at 2:23 PM
    Swanson52
    Yessir; I took the booklet in with the owners manual and all theyd do is rotate tires and check fluids. I'll have to start calling up the Toyota chain; I paid for the service at purchase and I'm not comfortable with 10k oil change intervals.
  8. Oct 13, 2011 at 3:04 PM
    saugus
    saugus Well-Known Member
    ^^^Says you.
  9. Oct 13, 2011 at 3:10 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    whats different about the '11 motors over the pre '11 2tr-fe?
  10. Oct 14, 2011 at 4:47 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    There aren't any. Toyota's trying meet new fuel efficiency standards.
    Remember that these standards are applied to their overall fleet, not a per-model basis.
    Requiring super light weight synthetic oil for the 2.7L probably helped contribute to a 0.003% improvement in overall fleet fuel efficiency. Seems small, but the number crunchers at Toyota thought that it was significant enough.
    Doesn't mean that you have to do what they recommend, it just means that they can claim a higher MPG rating for their fleet when they report to the Fed's.
  11. Oct 14, 2011 at 5:08 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Exactly my take also. Unless there was a major engine design change (which there wasn't), it is for Goment compliance only. Isn't it great that "they" are looking out for us?
  12. Oct 14, 2011 at 8:41 AM
    WV150
    South Carolina
    The Tacoma I4 does use 0w20.The book says 5w20 can be used if 0w20 is not available but must be switched back to 0w20 the next oil change.
