Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Dec 16, 2008 at 7:58 AM
    Dark Knight
    Dark Knight [OP] Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    who uses it and what brand do you use? what benefits have you seen, if any? I just changed to Castrol Syntec.
  2. Dec 16, 2008 at 8:00 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    They are all good oils, but Mobil 1 seems to be easy to find. JMO.
  3. Dec 16, 2008 at 8:09 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I use Pennzoil synthetic. I started using that about 2 weeks after I bought my truck so I can't really compare to non-synthetic oil. My bad.:(
  4. Dec 16, 2008 at 8:16 AM
    praetor
    praetor Well-Known Member
    Carlsbad, NM
    08 Prerunner Accesscab TRD Off Road
    +1
  5. Dec 16, 2008 at 8:22 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Castrol syntec 5W/30 in all my vehicles.
    Shark18 likes this.
  6. Dec 16, 2008 at 8:23 AM
    Dark Knight
    Jeff
    NC/SC
    thats what I just put in after 60,000 of dino oil. how long have you used it?
  7. Dec 16, 2008 at 8:23 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    I thought about using RP or Amsoil, but they seem extremely hard to find. I can get M1 pretty much anywhere. I have used M1 in previously vehicles, I like it, and will continue to use it for my Tacoma. Plus, M1 is the synthetic that my dealership uses, so it will be the same oil if I ever get it changed there.
  8. Dec 16, 2008 at 9:22 AM
    808trdsport
    808trdsport Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
    i read a long time ago about reading the oil stamp on the bottle. the api, sae, and acea standards. and decided to not pay for the premimum cost synthetics. So I use the Car quest brand synthetics. No problem so far and the price is not bad too.
  9. Dec 16, 2008 at 9:24 AM
    808trdsport
    Honolulu
  10. Dec 16, 2008 at 9:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Mobil 1
  11. Dec 16, 2008 at 9:49 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez alot of you guys are using Mobil 1!! I wonder if I should switch brands?! But I've been using the pennzoil synthetic for about 2 years. Should I change brands, and does anyone know why mobile 1 is preferred so much?:confused:
  12. Dec 16, 2008 at 9:51 AM
    808trdsport
    Honolulu
    easy to find. Costco sells it too.
  13. Dec 16, 2008 at 9:56 AM
    praetor
    Carlsbad, NM
    +. I can get Mobil 1 oil and a filter a mile from my house.
  14. Dec 16, 2008 at 10:53 AM
    tacomaracing
    tacomaracing tacomaracing
    GEORGIA
    2005 toyota tacoma 2wd 2.7L
    AFE stage 2 intake,heavley ported throttle body,one of the gas buddys off ebay,fitch fuel catalyst,electric fan and relay kit,oil catch can,gibson exhaust,magnaflow catalytic converters and the spark plug non fouler no CEL light,wraped exhaust manifold,wideband o2(innovate),relocated IAT.
  15. Dec 16, 2008 at 11:36 AM
    maricopa_taco
    maricopa_taco Well-Known Member
    Maricopa, AZ
    07 Prerunner
    6 inch procomp lift, 315/70/17 BFGs AT, Eagle Alloys, Carr step, TRD exhaust
    Not sure about that motorkote video. If you look at when they test the motorkote oil, the pressure bar never moves, you will hear clicking but that is it. When it test the other brand, the pressure bar is moving fast.
  16. Dec 16, 2008 at 12:26 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yeah but you start to see smoke at the end of the video.
  17. Dec 16, 2008 at 12:36 PM
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    I chose other... I use Valvoline SynPower... have used it for years and just like it.
    Kidd36 likes this.
  18. Dec 16, 2008 at 2:38 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Other.....AMSoil 5W-30 100% Synthetic Motor Oil......Just started using it via my dad's recommendation of about 5 years or so of use
  19. Dec 16, 2008 at 2:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i checked mobil1, cause thats what i normally use, but i just changed my oil and for this go round im using pennzoil platinum...............walmart was outta m1......and i aint paying almost $28 for a 4 quart jug from autozone. i have used penn plat before and i like it pretty good, but i'll go back to mobil1 next change........hopefully they'll have it then.
  20. Dec 16, 2008 at 3:14 PM
    nocarsallowed
    nocarsallowed Well-Known Member
    09 TRD Off Road 4X4 - Access Cab
    NO MODS YET! 20" Enkeis with NT420 performance tires coming soon...inspired by genxer36.
    Hi,
    I see the benefit of using synthetic is less frequent oil changes. Won't this void the warranty?
    Also, I don't have to use "Toyota Genuine Oil" do I? If I use Valvoline and Penzoil it won't void the warranty? I used those brands for years.
