Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Jan 9, 2010 at 1:34 PM
    #381
    mb_edgar
    mb_edgar Well-Known Member
    Manhattan Beach
    Tacoma TRD Off Road Pack
    6000k headlights and fog lights, L.E.D lightning all around, satoshi grill, hella 5100's behind the grill, pnasonic in dash, dual fosgates ps3's behind back seat, powder coated back bumper.
    that was mobile 1 by the way the "leading synthetic brand" they tested
  2. Jan 9, 2010 at 1:44 PM
    #382
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    mobil 1 isnt really a synthetic at all!!!!! made from conventional base! more like a blend!!
  3. Jan 9, 2010 at 4:52 PM
    #383
    jandrews
    '09 FourDubDee TRD OR
    It's a group III basestock. All synthetics are made from group III to group IV base stocks, and rarely does any synthetic contain only one base stock - oil additives are not all soluble in the same base stock.
    Mobil 1 SuperSyn is predominantly a PAO base stock (group IV) with a significant portion of group III (hydrocracked). Other formulations I'm less sure about.
    In any event, it hardly matters. It's the behavior of the fluids that are important.
  4. Jan 9, 2010 at 5:02 PM
    #384
    lightfire
    lightfire Well-Known Member
    What are you referring to? I use syntec in my 300,000 plus miles doesn't use any oil '93.
  5. Jan 9, 2010 at 9:11 PM
    #385
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Other: Used M1 for a while, then switched to Penzoil Platinum because there was a major sale on it the last time I needed oil. Have always used OEM filter. Have 68000 miles on truck now, used synthetic since 37000. Dealer did the oil before that.
    Between whatever the dealer used, M1, and Penz Plat., I never saw a change in MPG and performance felt same.
    I'm only using synthetic for it's thermal stability and as long as I can find good prices on it (O'Reily in GA periodically had it for less than $4/qt). Hopefully I can find the same sales in TN now that I moved.
    I will say that the Pen. Platinum might clean better than M1 or OEM. I just recently changed out the first run of Penz. The filler cap on the engine use to have sludge-like stuff in it that I would wipe out and it would be back by the next change. Since using the Penz, the gunk didn't come back.
    Oh, when I had my 88 pre-taco 2 wheel drive with the 2.2R engine,it had used normal Castrol dino oil from the first oil change. Changed it every 3000 miles and used cheap Fram filter. When that truck had 180,000 miles on it, you could still hardly tell a difference in color between the old oil and the new oil when changing it.
  6. Jan 10, 2010 at 6:30 AM
    #386
    jandrews
    This is called "moisture sludge" and is most commonly caused by repeated short trips in the truck where the engine isn't up to operating temp long enough to boil all the condensed moisture off the crank case. Ideally, you should let your engine operate *at full operating temp* for about 20 minutes each week to prevent this. An enjoyable sunday drive does the trick nicely.
  7. Jan 10, 2010 at 6:45 AM
    #387
    iTacozz
    iTacozz Active Member
    Charlie
    Ormond Beach, FL
    Never heard of them..... But what company would not hype up their product and denounce all others on their own site.... I would trust an unbiased/ 3rd party site that has scietific data instead of a flash bar.
  8. Jan 10, 2010 at 6:46 AM
    #388
    iTacozz
    Charlie
    Ormond Beach, FL
    Always used amsoil in all my vehicle including my gsxr, never had a problem
  9. Jan 10, 2010 at 7:55 AM
    #389
    trdtacoman31
    trdtacoman31 Well-Known Member
    Raleigh, NC
    2011 Titan Pro4x CC
    Always have used Castrol.. thinking about trying Royal Purple thought in my new Taco. No real reason other than I found some at a local store for a comparible price to Castrol.
  10. Jan 10, 2010 at 9:15 AM
    #390
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Thanks for that info. I had never bothered to look it up. Maybe it wasn't the Penzoil that cleaned stuff then because I moved not so long ago and now have a 80 mile round trip commute to work.
  11. Jan 10, 2010 at 10:52 AM
    #391
    jandrews
    Most commonly forms on the filler cap because that's lower temp than the rest of the engine.
  12. Jan 12, 2010 at 3:26 PM
    #392
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Changed the oil today and this is the first time I used synthetic. Went with Mobil 1
  13. Jan 12, 2010 at 4:16 PM
    #393
    TacoSupreem
    Hayden
    Kentucky
    Have u never heard castrol syntec called the brown death? It supposedly coats ur motor in a brown sludge! i personally have never used it but have heard it called that from some supra guys that race and are always tearin there motor apart!
  14. Jan 12, 2010 at 4:47 PM
    #394
    Tadcaster
    Tadcaster Dogs n Trucks
    Pete
    Vermont
    09 Access Cab TRD Off Road
    Mobil 1 is available everywhere, cheap, protects, and helps the truck start at 30 below zero.
  15. Jan 13, 2010 at 8:24 AM
    #395
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    I just switch over to synthetic oil 5w20 waiter,got it done at the dealer.
    later tig1
  16. Jan 13, 2010 at 6:33 PM
    #396
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
    Brand isn't as important as the frequency of change. If you go 10k without a change you should be using one of the better brands (I'm not going to jump into that fire). Any of the three choices in the pole should work. If you change at the 3k to 5k range, about any synthetic should do fine.
  17. Jan 19, 2010 at 4:35 PM
    #397
    Tacoda
    Tacoda Well-Known Member
    Adrian
    Virginia
    2010 DC Sport 4x4
    I have used Mobile 1 in several vehicles. It will be going in mine with the first oil change.
  18. Jan 19, 2010 at 6:34 PM
    #398
    Fuguar
    Fuguar New Member
    NH
    2009 SR5
    Just changed to Mobil 1 after 2200 miles. I picked up 1 mpg for the last two tankfuls.
  19. Jan 28, 2010 at 7:17 AM
    #399
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    I've been using petro since day one in my 2006 TRD castrol gtx 5-30 I was always told (old school) that you can't switch back and forth from petro and synthetic true? I currently change oil every 3k about 3 times a year... How often is it required for syn? I just have 28k on my Taco now..
  20. Jan 28, 2010 at 7:36 AM
    #400
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You can switch between synthetic and conventional oil. They mix fine, in fact, they sell it as synthetic blend.
