Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Dec 23, 2008 at 9:47 PM
    #41
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey now how often does everyone change their oil at? Every 3,000 or 5,000? I know the factory says every 5,000 but I've been changing mine around every 3,000 and I'm using synthetic oil. I got this from a friend of mine when I first bought my truck a little over 2 years ago. I was talking to a guy at the parts store today and he said I shouldn't even worry about it until the 5,000 mile marker if I'm on synthetic oil. Who should I listen too?
  2. Dec 24, 2008 at 5:27 AM
    #42
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
    Just took my truck in for the first oil change and had them switch to Mobil 1. I don't put a lot of miles on my truck so I'll probably end up having the oil changed every 6 months.
  3. Dec 24, 2008 at 5:30 AM
    #43
    98tacoma27
    Ben
    Not Beech Creek
    X2. Ran this in my taco. Switched all other fluids to Amsoil brand also.
    Benefit: Change oil once a year. Made a 125K mile motor run quieter and smoother. Smoother idle, slightly lower engine temp (so it seemed by the gauge). Gonna get enough to do the Tundra with when my taxes come back.
  4. Dec 24, 2008 at 12:26 PM
    #44
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Most of the good mechanics, at least the ones that I talk to , suggest that you change out the oil between 5-6 thousand. To me 3 thousand is way to early, my oil doesn't even get dirty at 5K.
    Mobil 1 is not cheap to buy, I usually change it at about 6 thousand or when ever it just starts to turn color.
    If you like to change your oil that often(lots of Mobil 1 owners do) then its OK.
    Jeff , 06,V6,SR5, 4x4, 6spd.
  5. Dec 24, 2008 at 1:08 PM
    #45
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I think I'm going to hold out longer on this run around. I actually use pennzoil platinum-full synthetic and has never been an issue. But it does get a little pricy changing it every 3,000 miles! Factory says 5,000 so it can't hurt to go 5,000 especially on synthetic.
  6. Dec 24, 2008 at 1:11 PM
    #46
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i change the oil in our honda accord and my tacoma every 5k miles, and i run mobil1 or pennzoil platinum in both of them(i use the penn in times like now, when walmart doesnt have the mobil1...or when there is a good deal on it...never have had a prob with it).
  7. Dec 24, 2008 at 3:04 PM
    #47
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Cool sounds good! Yeah I never had a problem with PP either so I'm going to stick with it. I think I'm going to go till 5k this time around. Hey it shouldn't hurt my engine since I've been doing it every 3k right if I switch it to 5k?
  8. Dec 24, 2008 at 3:10 PM
    #48
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not at all man!!! going 5k miles is ok,since its synthetic.......doesnt break down as quick as dino oil does. if you wanna be on the totally safe side......get an oil analysis from blackstone labs, but other than that........you are good to go buddy.:)
  9. Dec 24, 2008 at 3:16 PM
    #49
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Now whats that oil analysis deal your talking about from blackstone labs?
  10. Dec 24, 2008 at 3:18 PM
    #50
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    basically....you send in to them a bit of your used oil from an oil change, and they analyze it and see how its performing.
  11. Dec 24, 2008 at 3:22 PM
    #51
    hoosiertaco
    hoosiertaco Well-Known Member
    :D
  12. Dec 24, 2008 at 3:26 PM
    #52
    IB Slingin
    IB Slingin Well-Known Member
    Amsoil 5W-30 synthetic and Amsoil Ea057 oil filter every 5K miles. I'll do this until my factory warranty expires.
  13. Dec 24, 2008 at 3:41 PM
    #53
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no other way to word it brotha......i do the work on the both of them!!:D;)
  14. Dec 24, 2008 at 5:58 PM
    #54
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    I use only AMSOIL 0w30 in all my vehicles and use extended drain intervals.
    It is simply the best motor oil you can use. This is backed up by industry standardized tests that always shows AMSOIL out performing everything out there. That is why I use it.
    Most of us bought our Toyota trucks for their high quality instead of say a Ford Ranger. Why would you not use the same standard when you buy your motor oil for your Toyota?
    I really believe in this stuff so much so I am going to give all of you the very best hook up I possibly can.
    Go to my website, http://gadgetonline.com/AMSOIL.htm and follow the link to sign up as a dealer or a preferred customer. Either way it only costs $10 to sign up and you will save way more than that on your first order.
    By signing up, you can then order direct at WHOLESALE cost. Exactly what dealers pay. You just cannot get it cheaper than that. You will be amazed at how much money you can save only paying WHOLESALE for it.
    Gadget
  15. Dec 25, 2008 at 5:02 AM
    #55
    CanTac
    CanTac Well-Known Member
    Peterborough On./Ocala Fl.
    23 TRD Sport 4X4 D/Cab Long Box
    Amsoil is all I use in my vehicles. For those of you changing your syn oil out at 3000k, you are just wasting your money. Might as well be using dino oil if you are going to keep it in for only 3000k. Even at 5000k is a little early. You should be able, with no problem getting 10,000k highway miles or 8000k if you do a lot of city driving on an oil change with the Amsoil. Change out the filter and top up if you wish at 5000k, I have run all my vehicles like this for years. Never had a problem. JMHO
    CanTac
    Hal
  16. Dec 25, 2008 at 6:43 AM
    #56
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    sign up on Mobil 1 site and you can get a 10$ rebate form because of the shortage (limited time offer) and - they have a rewards program !
    of course, after reading through this thread - I will give Amsoil a try at my next change !
  17. Dec 25, 2008 at 7:18 AM
    #57
    Joe B
    Joe B Well-Known Member
    +1!:)
  18. Dec 27, 2008 at 5:13 PM
    #58
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey dumb question! My buddy gave me a Tacoma magnetic replacement screw for my oil pan to collect what ever metal particles are lingering in my oil. Now are these even worth using? Also, they are safe to use right?:rolleyes:
  19. Dec 27, 2008 at 6:07 PM
    #59
    Gadget@URD
    Yes.
    Gadget
  20. Dec 28, 2008 at 5:59 AM
    #60
    Jeff
    Hopkinton,MA
    Mag plugs have been around for some time and if they fit your Taco oil pan, there is nothing wrong with using it.
    I would suspect that these days there are not as many of the fine metal particles, just due to the better machining process that car manufacturers use.
    I have a friend who uses a magnet next to his oil drain plug, instead of the mag plug.
    So I would say go ahead and use it.
    Over the past few days we have had 22" of snow, then rain and now 55deg weather. Good time to fill up my windshield washer and check my oil and maybe wash some windows in our vehicles. Hope things in Nevada are snow free and warming.
    Jeff. 06,V6, SR5, 4x4,6spd....
