Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Jul 3, 2012 at 6:49 PM
    #881
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... Out of warranty, I'd go 7500 if it weren't for the maintenance light not being adjustable.
    Extended drain intervals has always been the push in synthetic marketing because it saves product and takes some of the pain out of the bite of spending $6+ for a quart of oil.
    But that is only one benefit of synthetic.
    I'd still run full synthetic even if my warranty required oil changes every 3000 miles.
  2. Jul 4, 2012 at 1:53 PM
    #882
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    My 07 with 130k: I ran Amsoil for a couple years and sent a sample to Blackstone that I'd run 7k iirc and report said safe to push to 8500 FWIW....I got tired of hassling with ordering it and went back to Mobil1.
  3. Jul 27, 2012 at 2:02 AM
    #883
    grrillA
    grrillA Well-Known Member
    Long Beach, CA
    '99 3.4L 4x4
    mobil 1 5-30 since I hit 10k. have progressively put more miles on the oil in between intervals. Have gone from 4k,5k,5.5k,6k,8k,10k at the last change. oil still looks good.
    But for the past 3 oil changes I used the mobil 1 15,000 mile rated synthetic, don't know if there is really a difference, but it is roughly 3-5 dollars more for 5 quart jug, plus a few bucks extra for the individual quart I need to get the 5.5.
  4. Aug 4, 2012 at 6:29 AM
    #884
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Just swapped all oils to AMSOIL trans trans/case rear and front diffs engine and power steering and wow what a differance its makes 6 speed shifts better goes in and out of 4x4 better runs cooler GREAT stuff
  5. Aug 4, 2012 at 10:30 AM
    #885
    B1SLYFOX
    B1SLYFOX Active Member
    Brandon
    Virginia Beach
    2012 Prerunner TRD Offroad
    Just getting started.
    AMSOIL but used Mobile1 in my old 02 Ford explorer and had 10 years and the engine still ran like the day I got it.
  6. Sep 3, 2012 at 10:55 PM
    #886
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    Been using that stuff for years....works like a charm for me. Called up Mobil and they stated that it is warrantied to last for that long, just keep my receipts and upc labels.
    As far as filters go I constantly look at their filtration rates. Some are good, while others are flat outstanding. I haven't had to change my oil yet, but when I go shopping for the filter I always check filtration rates. The best I have gotten so far on a filter was Pureone Gold with 99%.
  7. Sep 4, 2012 at 5:49 AM
    #887
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I use Mobil 1 EP 5W30 (EP=Extended Protection), and have been using it since the day the truck was purchased new (now over 295k). I typically go 10k miles between changes and sometime will go 12-15k between changes with oversize Mobil 1 M1-209 filter. Oil looks good at change. Runs like new.
  8. Sep 4, 2012 at 7:06 PM
    #888
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mobil also states that if your vehicle is under factory warranty, that you should change based on that schedule.
    If you get sludge or some other oil-related failure during warranty, Mobil will not "have your back"
  9. Sep 7, 2012 at 12:39 PM
    #889
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I've been running Mobil 1 for about 10 years now. I was sold on it when a mechanic explained its "cold pour" properties to me when I lived in Fairbanks, AK. I've always been a 3,000 mile oil change guy, but once I bought my current '06 Tacoma I switched to 5,000 mile intervals (per the owner's manual) with the Mobil 1. However, I don't put many miles on my truck in a year (was under 5,000 in 2010 and just under 6,000 in 2011).
    My question: What's a safe amount of TIME to keep the same oil in my engine? I may not drive 5,000 in a year, so that means my oil change intervals are sometimes beyond a year. What are your thoughts?
    Thanks!
  10. Sep 7, 2012 at 4:06 PM
    #890
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    I think at least a half general consensus is that dino oil is good for ~ 6 months, syn ~ a year
    the only sure way is to get a OA done on your vehicle
  11. Sep 7, 2012 at 8:02 PM
    #891
    Ragin Devildoc
    Doc
    Grunt Life
    Mobil 1 Extended Performance is rated for 15k or 1 year whichever comes first!
  12. Sep 8, 2012 at 6:07 AM
    #892
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I too am a Mobil 1 guy. Been for years. And as stated in prior posts, no place cheaper to get it that Wal-Mart.
  13. Sep 8, 2012 at 6:11 AM
    #893
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    good to know! im stoppin by there today to pick some up. switchin to synthetic today finally, hopefully theres no crazy out of the ordinary details i missed, just a simple out with the old, in with the new right?
  14. Sep 8, 2012 at 6:20 AM
    #894
    Rupp1
    NC
    Yes.
  15. Sep 13, 2012 at 8:28 PM
    #895
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I have 55,414 miles on my 05. Always had the oil change at the stealership with castrol syn blend. I would like to do oil changes my self now and wanting to switch to mobil 1 fully synthethic. With how old my truck is and with the miles which oil grade should I use.
  16. Sep 13, 2012 at 8:50 PM
    #896
    Rich91710
    Rich
    Los Angeles
    08 Base
    55k?
    It's not even broken in.
    Stick with 5w30 or 0w20... whatever is recommended in your owner's manual.
    Stick with that grade for the next 200k or so.
  17. Sep 13, 2012 at 9:04 PM
    #897
    Hector v
    Hector v Well-Known Member
    ca
    08 taco dc 4x4 sr5
    My truck has now 113xxx miles you guys think I need to use a thicker oil or keep using 5w30?
  18. Sep 13, 2012 at 9:14 PM
    #898
    Rich91710
    Rich
    Los Angeles
    08 Base
    5w30
  19. Sep 13, 2012 at 9:26 PM
    #899
    Johnnyh
    Johnnyh Well-Known Member
    Az
    The basics, 5100s, 885s, weathertechs, Desert racing UCAs, wheelers progressive 3 leaf, icon rears, welded in magnaflow, ultragauge, drop in filter, bet mat, 285/75/16s
    Use to use Mobil 1 but they arent what they use to be. I got into using Rotella T since its Jaso certified for a motorcycle clutch, now i just use it for everything. Its great oil thats actually affordable. Walmart usually has it the lowest. Its diesel rated but amazing for any engine. T5 is their semi synthetic, T6 is their full.
  20. Sep 14, 2012 at 8:03 AM
    #900
    dwsyab
    dwsyab Old Man
    David
    Sturbridge MA
    2012 TRD Offroad
    TRD Exhaust, rear diff breather mod, CB Radio
    I switched from regular oil to Mobil 1 at 3K and now pay extra at the dealership for M1 at the 5k service intervals. I still get the complimentary free service but I have to pay full price for oil.
