Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Oct 3, 2012 at 8:02 PM
    #921
    Joshman35
    Joshman35 Well-Known Member
    Josh
    White Mountains, Arizona
    09 Tacoma Custom
    Too many to list
    Royal Purple all the way, when I die, I will be preserved in a Royal Purple solution. I've been using Royal Purple for 15 years in motorcycles, cars and trucks, from engine oil to transmission fluid. Brings life back to beaters and keeps my equiptment is the best condition possible.
  2. Oct 3, 2012 at 8:31 PM
    #922
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's funny.
    In my motorcycle it didn't do any better than Castrol GTX non-synthetic.
    http://personal.linkline.com/rlockyer/oil/oil.xls
  3. Oct 8, 2012 at 6:00 AM
    #923
    RUT
    RUT Active Member
    NC
    2011 TRD Sport 4x4 DCSB Metallic Gray
    Bilstein 5100's w/ OME 885's (Front), Bilstein 5100's w/ TSB 4-Leaf & 2" AAL (Rear), XD Monsters with 33x12.5 Toyo Open Country M/T, G2 BAK Bed Cover
    Toyota Owners Manual says to use 0W-20 (Conventional) and change it every 5,000 miles. You can use 5W-20, as long as the next change uses 0W-20. Toyota will put full synthetic in, if customer requests. This will NOT void the warranty as long as you continue to change it every 5,000 miles. Most synthetic brands say you can go double the mileage between changes. But Toyota says that will void the warranty by not changing the recommended 5,000 miles. The only benefits you will get with the full synthetic is better wear, therefore longer engine life and better fuel mileage.
  4. Oct 8, 2012 at 1:39 PM
    #924
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    ^ that's for the 4 cyl
  5. Oct 8, 2012 at 6:34 PM
    #925
    Rich91710
    Rich
    Los Angeles
    08 Base
    Can you post a copy/image of that? It certainly does not say that in my manual.
    "As long as the next change uses" WTF? That's completely pulled out of thin air. :facepalm:
    0w20 conventional does not exist.
    0w20 is only available as synthetic.
    Factory non-synthetic fill is 5w20.
    See the attachment to see what Toyota REALLY says.
  6. Oct 13, 2012 at 6:09 PM
    #926
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Valvoline dura blend, best of both world. 5w-30
  7. Nov 3, 2012 at 11:34 AM
    #927
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Since my truck has 88K miles on it I will be using Mobil 1 "High Mileage" 5w-30 (recommended for vehicles above 75k miles) for its next oil changes. The previous owner changed the oil every 5k miles as the dealer records show. It came with a Toyota oil filter from the dealer's last change and I assume conventional oil. I prefer to run Mobil 1 in all my engines, including my backup genset. I do run Rotella T in my Kubota tractor and will probably use it in my two older Onan gensets.
    http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_High_Mileage_5W-30.aspx
  8. Nov 3, 2012 at 7:47 PM
    #928
    Madcat207
    Madcat207 Well-Known Member
    FL
    08 Double Cab Long Bed Sport
    My local dealer used Valvoline synthetic in my last change...
  9. Nov 4, 2012 at 9:33 AM
    #929
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  10. Nov 4, 2012 at 2:31 PM
    #930
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  11. Nov 4, 2012 at 4:34 PM
    #931
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
  12. Nov 10, 2012 at 12:46 PM
    #932
    Rich91710
    Rich
    Los Angeles
    08 Base
    Valvoline synthetic is a Group-III mineral oil base.
    We can thank Castrol and a jury for this.
    Mobil was one of only a couple of producers of Group-IV synthetic base stocks (Amsoil uses Mobil base stocks.)
    Castrol began producing their own Group-III mineral ("dino") base stocks and marketing it as "Syntech synthetic".
    Mobil filed a lawsuit and lost.
    Castrol's expert witnesses were able to convince the jury that the processes used to convert conventional crude oil into Group-III base stocks results in a product that is molecularly identical to Mobil's Group-IV synthetic base stocks.
    Castrol was awarded the right to use "synthetic" as a descriptor for their oil, and shortly after, Valvoline, Rotella, and a number of other Group-III products began appearing on the market.
    However, to remain competitive, Mobil began using some Group-III base stocks in it's synthetic products. How much is proprietary, but there are very few purely Group-IV synthetic products available today sold as motor oil for automobiles.
    Mobil-1 and Amsoil motorcycle oils are still solid G5 products, and they cost double what automobile oil costs.
    That's awesome.
    7k intervals, 300k, and no major work... just wheel bearings, diff, and electrical.
    Now many of those repairs were related to off-road use, or use in a harsher climate? IOTW, translate your experience to a 5-lug commuter vehicle in non-coastal SoCal or southern AZ.
  13. Nov 11, 2012 at 8:00 PM
    #933
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Dang. So does that mean the Mobil 1 5W-30 I've been using for 10 years (first in my '02 and now in my '06) isn't truly a full synthetic?
  14. Nov 11, 2012 at 8:15 PM
    #934
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's still one of the best products that you can buy.
    It is not a synthetic/conventional blend... it meets the legal definition of "full synthetic". The conventional components have indeed been molecularly altered.
  15. Nov 16, 2012 at 7:30 AM
    #935
    headshok
    headshok Member
    i just use the 0w20 synthetic that the ownersmanual calls for on my 2012 4cyl.
    i am guessing toyota has their own "house brand" of synthetic?
    toyotacare owes me 4 more changes, then its on me . stealership's normal charge for it is around $78 i think.
  16. Nov 24, 2012 at 8:42 AM
    #936
    VegasNick
    VegasNick Well-Known Member
    Nick
    Vegas
    2010 FJC
    This may have been true years ago, but is outdated information. Where are you getting your information from?
    They get a small portion of base stock from Mobil, but all of the additive packages that Amsoil uses are proprietary blends dependent on the use of the lubricant.
  17. Nov 24, 2012 at 8:48 AM
    #937
    VegasNick
    Nick
    Vegas
    2010 FJC
    I'm a die hard Amsoil guy. Not just because I sell it, but because I can back my decision and experience up with oil analysis and test data.
    I run it in the FJ in the engine and all the gearboxes. I run it in all the rest of my vehicles as well.
    I don't really like this guys sales approach, but he has a lot of good data:
    http://www.ultimatesyntheticoil.com/Scamsoil_Skeptics.htm
    Not saying there aren't other great oils on the market, but for every good oil, there are as many handing out false, misleading and just plain untrue information about it.
  18. Nov 26, 2012 at 8:44 AM
    #938
    alnewt1234
    alnewt1234 Well-Known Member
    Alan
    Texas
    TForce
    Just got the truck but will be putting Amsoil 5w-20 in it sometime in the next couple of weeks
  19. Nov 27, 2012 at 4:07 AM
    #939
    Porkchop228
    Porkchop228 Well-Known Member
    Biloxi,MS
    07 DCSB 4X4 9" LIFT W/35'S
    6" Fabtech and 3" body lift with gap guards, 315-75-16 BFGoodrich A/T, Westin Ultimate Bull Bar, LED Duallies, UWS black lo-pro toolbox, black nerf bars, K&N intake, Sportsman Camo Covers front and rear in Mossy Oak Break-up, Weathertech front and rear floor liners, Illuminated 4x4 switch
    I have been using Mobil1 for the past several years. I used it in my 06 tacoma with the 2.7L and I'm also using in my 07 tacoma 4.0 now. I noticed that it makes the engine run cooler. Cooler engine = more efficient and longer oil life.
  20. Nov 28, 2012 at 6:52 AM
    #940
    VegasNick
    Nick
    Vegas
    2010 FJC
    Good move! Don't forget to get the EA oil filter to go with that oil!
