Synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Dec 16, 2008.
which synthetic do you use?
  1. Royal Purple
    7.3%
  2. Mobil 1
    65.8%
  3. Castrol
    10.6%
  4. Other, please specify.
    16.3%
  1. Dec 24, 2012 at 8:07 AM
    #941
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    been putting Mobil 1 in my 99 4runner V6 since 1998, and today it still
    exceeds MPG estimates when I drive like a granny. change it every 7500/12000 miles...
    210,000 miles later...still runs like new. stuff works. lots of different oil works too,
    but I will stick with the easy button which is mobil 1
    will be buying a 2013 Taco AC 4x4 V6 in 4 weeks and it'll get the same treatment.
  2. Jan 5, 2013 at 12:30 PM
    #942
    mikea
    mikea Active Member
    Illinois, west of the Fox
    07 DC TRD SPORT 4x4
    Weather tech, salex center console organizer
    I'm a new owner of a used taco coming up on 100,000 soon. Purchased it with 90 plus, the previous owner changed every 3000 so I'm assuming he used dino lube. Could I start using synthetic? Will I see any benefit? Such as extended engine life?
  3. Jan 5, 2013 at 12:31 PM
    #943
    max2
    max2 Well-Known Member
    Gary
    Ruidoso, NM
    I use Mobil 1 0W-40 in all my vehicles.
  4. Jan 5, 2013 at 4:05 PM
    #944
    ManMan
    ManMan Well-Known Member
    You can use whatever brand you want... Just meet OEM weight req's.
    No real way to tell, very few people drive a car till the engine wears out anyways
  5. Jan 10, 2013 at 2:32 PM
    #945
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Mobile 1 or Amsoil
  6. Jan 10, 2013 at 8:43 PM
    #946
    Rays08
    Rays08 Member
    Ray
    Kaysville, Ut
    08 TRD Sport Crew Cab
    Amsoil 5-30. I change at 10k miles instead of the recommended 20K.
    I don't have to go to the store. It is delivered to my house. Just join as a preferred member. It's cheaper than M1.
    Just sayin'...
  7. Feb 12, 2013 at 7:30 PM
    #947
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Do a little more research and you'll see that 20k intervals are only "recommended" when you are running a bypass filtration system.
    The TBN is getting quite low at 12k, but the quart added during the filter changes (both bypass and regular) at 10k replenish it.
    A lot of Amsoil dealers are telling people a bunch of bullshit about 40k+ intervals. Amsoil has a great product, but their dealer network is not doing their customers any favors.
  8. Feb 12, 2013 at 11:19 PM
    #948
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
  9. Feb 13, 2013 at 5:51 AM
    #949
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    I bought my '06 brand new, ran the factory oil for 1000 miles, drained/replaced filter & oil w/ Castrol 10w-30, ran for 7K, (sufficient rings break-in) drained/replaced filter & oil w/ Amsoil 5w-30 from then on. I have been repeating this Amsoil filter/oil routine every 15K. I now have 96K on the motor and notice deposits in the crea:cool:vases of the oil cap. I think I'll change the oil& filter at 10K like you mentioned. 15K is too long on one oil change. The Nissan hemi head hardbody I owned awhile ago had to be topped off at 2K. I do not add one drop to this GR1 engine between oil changes...excellent oil mileage.
  10. Feb 13, 2013 at 9:14 PM
    #950
    Rich91710
    Rich
    Los Angeles
    08 Base
    There are four different "Mobil-1" oils and they are all synthetic (Group-IV or a Group-III/IV blend).
    Mobil-1 is available in 0w20 through 15w50.
    Mobil Super Synthetic (newer product) is available in 0w20 through 10w30.
    Mobil Super (formerly Mobil-5000) is conventional, and is available in 5w20 through 10w40
    Mobil-1 is claimed to be the "premium" product. It is the only Mobil product suitable for TurboDiesel applications.
  11. Feb 13, 2013 at 9:22 PM
    #951
    Hektor
    Texas
    So which one is the Group IV?
  12. Feb 13, 2013 at 10:19 PM
    #952
    Rich91710
    Rich
    Los Angeles
    08 Base
    Supposedly the Mobil-1 line, but there have been a lot of accusations that they've been blending some G-III base stocks ever since they lost the Castrol lawsuit in order to remain competitive.
    My testing of the 15w50 seems to support those claims, at least comparing it's shear stability to the 20w50 M1 V-Twin and Amsoil MCV products.
    The M1 15w50 did better than Royal Purple (which didn't do any better than Castrol GTX), but it didn't do anywhere near as well as the M1 V-Twin, which is a JASO-MA Group-IV product.
    Short story, as the courts ruled, even Group-III base stocks are good. The product is molecularly altered so it is basically the same as a true synthetic.
    Just stick with reasonable change intervals and it will do just fine. Many OTR truck fleets have been using Rotella-T 5w40 (Group-III) for many years.
  13. Feb 13, 2013 at 11:28 PM
    #953
    Hektor
    Texas
    I was using M1, but switch to RP last year . But for this oil change I used Pennzoil Utlra.
  14. Feb 13, 2013 at 11:29 PM
    #954
    Rich91710
    Rich
    Los Angeles
    08 Base
    http://personal.linkline.com/rlockyer/oil/oil.xls
  15. Feb 24, 2013 at 12:08 PM
    #955
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Thinkin about switchin to synthetic in my 01' I've got 156k on it. Someone said I should start with one quart of synthetic mixed with 4 quarts of regular. And then each oil change move up another quart of synthetic. Should I do that or should I just straight up change to synthetic. Thanks
  16. Feb 24, 2013 at 12:56 PM
    #956
    Rich91710
    Rich
    Los Angeles
    08 Base
    No need.
    Just change it.
    You can mix the oils, but it's just a waste of money because you don't get the full benefit of the synthetic.
  17. Feb 24, 2013 at 12:59 PM
    #957
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Okay thanks. Someone told me it made their Tacoma leak oil. Is a wix synthetic oil filter good? Or should I use oem?
  18. Feb 24, 2013 at 1:09 PM
    #958
    Rich91710
    Rich
    Los Angeles
    08 Base
    The OEM Denso/Toyota filter is one of the best you can get, and they're only about $4 in quantity. $90 shipped will get you enough filters for 100k.
    IF synthetic "caused" any engine to leak oil, it's because the leaks were already there, but plugged with sludge that the synthetic cleaned out.
    A lot of things you'll hear about synthetics originated in the 70s. Many were never true, many were true only for engines using older seals, and some were only true for the earlier formulations of synthetic oil.
  19. Feb 24, 2013 at 1:19 PM
    #959
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Thanks I appreciate it. I think ill just go ahead and make the switch
  20. Feb 24, 2013 at 7:08 PM
    #960
    procam11
    procam11 Member
    04 Pre Runner SR5
    E
    This is the only oil I use and this goes for all fluids in my truck as well as my previous vehicles 1989 Toyota, 1987, 1995 Ford Bronco.
    Mike Doran
    D&W Images
    www.winecountrymotion.com
