Synthetic Oil?
Discussion in 'Performance and Tuning' started by TonyK14, Mar 8, 2013.
  1. Mar 8, 2013 at 11:55 AM
    TonyK14
    TonyK14 [OP] You're welcome
    Tony
    Nor Cal
    07 PreRunner TRD Sport
    Lifted, wheels
    I have a pretty long commute to and from work and put a lot of miles on my truck during the week. That means I'm due for an oil change a lot sooner than I normally would be. Because of that I'm thinking of switching to a synthetic motor oil to lengthen the amount of time and get more miles out of each oil change. Does anyone have a particular brand they like to use? Or even a brand to stay away from? Thanks for the input!
  2. Mar 8, 2013 at 12:02 PM
    scocar
    scocar hypotenoper
  3. Mar 8, 2013 at 12:07 PM
    Jared
    Jared A Bad Ass Member
    Jared
    Porterville, Ca
    2011 Toyota Tacoma DCAB LBED 4WD
    Current Mods: -Viper Alarm System -Covered up seat belt buzzer -WeatherTech Floor Mats -Fog lights turn on with Bright Lights -17 inch Chrome Tacoma rims (off a 2012) -Line-x'd the front skid plate -USB charger that plays music via Mediabridge -Window Tint: Front-20%, Back-5% -Front Toyota License plate logo -2 Extra D Rings in front -Bright Reverse Light Bulbs -6,000K Head light bulb -6,000K Fog light bulb -LED Dome & MAP light bulbs -Trailer brake controller -Escort 9500 Radar Detector (hardwired) -BendMount Mirror Radar mount -C.B. Radio with a built in Mic Plug in by Aux -LED Bed lights with an extra fog light switch -30 inch LED light bar under front grill wired to an extra fog light switch
    I too drive highway miles daily (60), so I wanted to get a high quality oil that I will be able to have longer intervals with. I switched over to Amsoil SAE 5W-30 Signature Series 100% Synthetic Motor Oil. With this oil, it's recommended to change oil every 15,000 during harsh conditions and 25,000 during normal. Those seem too high, so I switch mine every 10,000 miles. I even noticed 2-3 MPG increase on highway after about 1,500 miles of it running through the engine.
    Here is a link:
    http://www.amsoil.com/shop/by-produ...ature-series-100-percent-synthetic-motor-oil/
    Jared
  4. Mar 8, 2013 at 4:56 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    I like Mobil 1 - change it every 7,500 miles
  5. Mar 8, 2013 at 5:06 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Castrol Syntec 5w30. I change it every 5000miles. It might be soon for synthetic, but my driving is a lot of stop and go, short distance driving and towing my 5x8 enclosed traile 2-3 times a week, so my truck works harder then truck used for commute to and from work in mostly highway driving conditions.
  6. Mar 11, 2013 at 8:00 AM
    wanderingwayne
    wanderingwayne Active Member
    Wayne
    Pacific Northwest
    Stock 4x4, 3.58 gears, 30" tires, man. hub
    I started using Amsoil Signature Series oil a year and a half ago. I can get it at the Napa Store in town for about $9.00 a quart. With any synthetic oil I've read that you should use the best quality filter you can find. Napa Platinum fit the bill there as far as I can tell from all the reading I've done. I had around 200,000 miles on my '97 Tacoma when I changed over. It appears that the truck has had excellent care taken of it, so I didn't use the flush that is recommended. I just change to Amsoil and started using the Platinum Filter. I've decided to change oil once a year as per manufacturers recommendation, with a filter change at 6 mo. The first year the oil looked fairly clean at 3 mo. or so and wasn't really bad looking at 6 mo. This is the second year and I was pretty shocked at how good the oil looked at the 6 mo. filter change. Still amber, just a little bit darker. As far as I know, Amsoil is the only synthetic oil that isn't made from Dino oil.
