Synthetic oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Oct 10, 2013.
  1. Oct 10, 2013 at 7:40 AM
    smmarine
    smmarine [OP] Well-Known Member
    Sean
    Melbourne FL
    1999 Tacoma 4wd Supercharged 2.7L Auto
    LCE supercharger, Harrop Eaton front and rear E-Lockers, Ultimate headlight upgrade, LCE header
    Ok my 1999 Prerunner with the 3.4 ltr has 155000 miles on it. I don't know what the guy before me ran but the past couple oil changes I've been running high mileage conventional oil. I heard that can cause probs after awhile so I'm gonna be switching. My question is I would rather switch to synthetic because it's a better oil but I've heard that can cause leaks like crazy. Any advice? Synthetic change or stick to conventional? I can't afford to reseal the engine if I get a bunch of leaks
  2. Oct 10, 2013 at 8:23 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Thousand Oaks, CA
    '13 DCLB TRDSport PreRunner & '99 4Runner 4x4
    Tailgate Anti-theft Anytime Foglights Removed/Relocated Badges BHLM Window tint Goodyear Duratracs Satoshi Grill from Customcargrills.com
    Not to thread hijack but, I have a somewhat related question on this topic. When switching from conventional to fully synthetic, I hear they don't mix well. Is it necessary to first switch to a partial synthetic before going full synthetic?
  3. Oct 10, 2013 at 9:47 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    This is old school conventional 'wisdom'. Maybe this was the case 30 or 40 years ago, but today you wont have a problem. Go full synthetic with no worries.
    I use Mobil 1 5w-30 high mileage - get it at Walmart for $24.99 for a 5 gallon jug.
  4. Oct 10, 2013 at 9:48 AM
    Moco
    Eric
    NoVA
    If it leaks, cant you just go back to conventional?
    Personally, I run Mobil 1 high mileage on my truck with nearly 188K on it and have no issues.
  5. Oct 10, 2013 at 10:01 AM
    Shauncho
    Shaun
    Thousand Oaks, CA
    That's just what I figured and have seen that same info other places as well.. going full synth next change. :D
  6. Oct 10, 2013 at 3:54 PM
    smmarine
    Sean
    Melbourne FL
    If it leaks going back isn't going to help will it? It's removed crud and that's why it's leaking
  7. Oct 10, 2013 at 8:51 PM
    Moco
    Eric
    NoVA
    It could just be lighter (synthetic) oil finding its way through gaps that thicker oil wasnt.
  8. Oct 11, 2013 at 5:47 AM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    When Mobil1 first came out, oil leaks in an older vehicle were common because after a while sludge is broken down around main seal area and a leak ensued. This problem was solved with "seal swellers" that were introduced into the formula and these are also common in "High Milage" conventional oils. Mobil1 does market a "High Milage" version of their product as I've seen it at Wally's. I'm a believer in synthetics as they run cooler and give added protection in super cold as well!
  9. Oct 11, 2013 at 8:22 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    If it starts leaking, either live with the leak/drip or fix it!
    I have always switched my vehicles to synthetic oils/lubes and usually don't have issues. If I did, it was usually from the age of seals and the vehicle sitting unused for a long period of time. I hate leaks, so I always fixed the leak when I could.
  10. Oct 11, 2013 at 5:54 PM
    smmarine
    Sean
    Melbourne FL
    From what people are saying I guess it would be worth a shot. Just hope I don't get a major leak cause I can't afford a reseal on my engine. Should I use my normal 10w-30 or do I need different for synthetic? I live in Florida where it's usually in the 80s/90s but does get below freezing quite often in winter
  11. Oct 11, 2013 at 6:14 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Synthetic oil is not "lighter" or more slippery than conventional.
    5w30 is 5w30.
    Synthetic requires fewer viscosity improvers to function as a 5w30 so it better resists breaking down.
  12. Oct 11, 2013 at 7:10 PM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    Go to Bob is the oil guy forums. All of the answers to your questions are there.
  13. Oct 11, 2013 at 9:08 PM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    you can switch to synthetic, not a problem at all.
    I know what I'm talking about.
    I prefer synthetic, but as long as you change your oil on a regular basis you will be ok either way.
  14. Oct 12, 2013 at 5:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I bought my 96 tacoma when it had 60K miles on it. I put Mobile 1 5W-30 in it immediately. I ran Mobile 1 in it for 5 years.
    Synthetic oils tend to penetrate further than conventional oils, so you can & may get some leakage/sweating. It just depends.... I've never heard of anyone having a leak that caused 'drips'.
    I did experience some 'sweating' / leaking ( no drips). I saw most of the sweating at my oil pan bolts. I went around and tightened the bolts a tad - but I'm not sure that actually did anything or not. I also experienced a loss of 1/2 quart of oil every 5,000 miles. No biggie..... Sometimes, when I'd start the truck up....I'd get a 'lifter tap' until the oil pressure built up. Again, that was minor.
    I continued to use Mobile 1....and just kept an eye on things. Sold the truck at 110k miles.
  15. Oct 13, 2013 at 5:55 AM
    muddybamaboy
    muddybamaboy Member
    Brantley
    Bham,AL
    98 SR5 4x4
    OME 881s on OME struts, Deaver AALs, K&N air filter w deckplate mod, 305/75/16 Dick Cepeks, Clutch Masters Stage 2 clutch assembly, Pro Comp es 9000 rear shocks, Real Tree seat covers and floor mats on 2003 4Runner buckets, custom sewn transmission and transfer boot(leather), 5% tint rear sliding and Xcab, Double layered 20% on front side glass, 50% on entire windshield, aftermarket pedal kit, self improved cats, AVS bug shield and ventvisors, black BetterBuilt low pro toolbox, 200+ ft of logging chains, shackles, bed cargo net, NGK performance plugs and wire set, few more I'm probably forgetting!
    I have run Mobil One full synthetic 5w-20 in my 98 SR5. When I bought truck, guy before me used just whatever was sitting in his shop, the first time I drained the oil the Mobil One brought chunks of crap out. Drain hole was spitting globs of broke down conventional sludge. I change every 4500 to 5K and it now runs clean. Smooth as can be, odometer @ 285K clicking right away. Truck idles smoother, performs better, and doesnt leak a drop anywhere (besides outta power steering pump pressure hose but thats a whole different story). I would definitely recommend using full syn product at any stage in a taco's lifetime. I think oil stabilizers (Lucas, etc) are also overkill w synthetic products, although they make a special stabilizer for synthetic oils. You can't ask for better quality out of a product. :)
  16. Oct 13, 2013 at 6:24 AM
    Hansel
    Glenn
    Arizona
    base
    lots of good posts here.
    I agree that the additives are largely a waste of money. Liqui Moly (I have no affiliation with them) makes an additive that contains molybdenum disulfide which is a good product. you have to add it at every oil change if you decide to use in in order to get the benefits, which are increased lubrication. But the "one time" treatment products containing teflon are snake oils as proven by Southwest Research in San Antonio and other labs. And they have been taken to court several times.
    I've used synthetic oil in my Chevy truck since I bought it at 137k miles. PO used conventional oil. I now have 308k miles. Engine has never been opened and it runs like a top, and gets very good gas mileage. BTW, I double my drain intervals over conventional oil so that is another benefit. If you decide to extend your drain interval, make sure to use high quality oil filters.
  17. Oct 13, 2013 at 9:26 AM
    hikesnp
    hikesnp Member
    Todd
    Axton, VA.
    98 4x4
    I have 155k on my taco.Have used only Castrol GTX. All oils are somewhat synthetic appx. 40 %because you can't run straight crude.
  18. Oct 13, 2013 at 11:10 AM
    TTBlues
    TTBlues Well-Known Member
    1999 Tacoma SR5 V6 4x4
    Stock
    I just switched over all the fluids in my truck to synthetic. What an improvement!! More HP. Less vibration. Smoother shifting. I used redline cause I read good things about it on this forum. When I first got the truck I changed all the fluids but I used dino. It never felt right. I'm wondering if the first owner didn't use synthetic too.
  19. Oct 13, 2013 at 2:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Slick-50 took DuPont to court when DuPont refused to sell PTFE to them, citing that PTFE was not designed to be used in the oil of an ICE, and Slick-50 was marketing the DuPont product in a manner inconsistent with it's design purpose, and falsely claiming that PTFE would bond to engine parts and provide protection.
    Of course, the courts sided with Slick-50, provided they used the term "PTFE" and not the trademarked term "Teflon".
    The court decision was that Slick-50 was not harmful to DePont's name, and DuPont had no legal right to restrict the use and marketing of its products as ingredients in other products.
    So now we have Turtle Wax using it in their products... of course, marketed as PTFE.
  20. Oct 15, 2013 at 6:00 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Clearwater, Fl.
    2003 DC TRD v6, auto
    Stock - built correct from the start.
    Yea, I replied to a similiar thread awhile back. Don't go synthetic. I had a Ranger FX4, a mint machine, oil change every 3-4000 miles. At 160,000 miles I "treated" her special with a synthetic oil change. Sure did clean her crud out. The rear main seal began leaking and everything in the 4.0 began rattling/knocking. The synthetic had gotten the buildup out of all the crevasses and openned all engine clearances . Started having to run high mileage oil. Quickly progressed up in viscosity each oil change until it sounded like she was coming apart everytime she was run. She never came back. :mad:
