Synthetic oil
Discussion in '4 Cylinder' started by jwa1028, Nov 23, 2009.
  1. Nov 23, 2009 at 7:01 AM
    jwa1028
    jwa1028 [OP] Active Member
    '01 4 cyl Tacoma
    how long between oil changes? Mostly highway miles.
  2. Nov 23, 2009 at 7:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Change at the recomended interval, and send some of the oil to have a sample performed on it. You can base the change intervals on the results of the testing.
  3. Nov 23, 2009 at 7:30 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I drain my crankcase annually. AMSOIL Signature Series is good for up to 36,000 miles but during the thirty years I've used AMSOIL products, I've never gone past 24,000 in a single year/drain.
  4. Nov 23, 2009 at 7:32 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    you should be good for 5000+ if you are doing alot of hwy driving
  5. Nov 23, 2009 at 7:35 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    I do alot of HWY driving and I use synthetics in all my vehicles. I try to go every 4500-5000. Some blends are supposed to have additional additives which are further resistant to breakdown, which, supposedly you can go further than that....
  6. Nov 25, 2009 at 5:37 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    The factory oil change interval with conventional oil is 5000 miles. I'd think you could safely double that with synthetic. Any of you experts know for sure? I guess the suggestion about getting a sample tested would be the safest way to know for sure.
