Synthetic transmission fluid vs OEM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by knuckles67, Sep 17, 2020.
  1. Sep 22, 2020 at 9:29 AM
    #61
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    There's compatible...and then there's licensed. I thought DEXRON and MERCON both license their product; making it a known specification. But, I get what you're saying.
    On the Lubegard chart, there are several different ways you can use their product on our trucks:
    -OEM WS ATF w/ Lubegard additive
    -DEXRON VI/MERCON LV w/ choice of two different Lubegard additives
    -Lubegard Synthetic ATF
    Skydvrr likes this.
  2. Sep 23, 2020 at 3:15 PM
    #62
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I just don't get why? Why play an engineer or try to make something work when there is a specific fluid made by Aisin with all the proper additives that is widely available. Do you guys think that your trannies will somehow perform or last longer by using some fancy ATF?
    Rick111, kahanabob and BillsSR5 like this.
  3. Sep 23, 2020 at 3:31 PM
    #63
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yes
    Grossomotto likes this.
  4. Sep 23, 2020 at 4:36 PM
    #64
    splitbolt
    NW Arkansas
    My interest in Lubegaurd is academic.
    Skydvrr likes this.
  5. Sep 23, 2020 at 10:57 PM
    #65
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Did the engineers choose or have a say regarding the OEM tires? The tires do affect ride, handling, safety and suspension performance.
    Or was that decision left to the front office administrative assistant?
    Many Taco owners remove new tires and install aftermarket. ;-)
    Perhaps sometimes, the Finance Department has a say in what’s used in the design and construction.
    Scott4032 and Grossomotto like this.
  6. Sep 23, 2020 at 11:09 PM
    #66
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Apples to oranges. Transmissions need specific components in fluids to operate and lubricate properly (which OEM provides). Tires, not so much. Next idea.
    JustMeMyselfAndI and BillsSR5 like this.
  7. Sep 24, 2020 at 5:59 AM
    #67
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Just my opinion from what lesson i learned in the past using an aftermarket atf in my tundra...stick with the manufactures atf. If you develop an issue at least you know its likely not the fluid.
  8. Sep 24, 2020 at 6:18 AM
    #68
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    I contacted Amsoil (I bought their gear oil for the rear diff because I love those squeeze pouches...they make diff oil changes so much easier) and I asked about transmission oil, was told to stay with Toyota's own...so that would be something I would do.
    zoo truck likes this.
  9. Oct 5, 2020 at 5:26 PM
    #69
    knuckles67
    knuckles67 [OP] Well-Known Member
    Derek
    Has anyone bought Toyota’s ws atf off Amazon if so is it legit Toyota atf
  10. Oct 5, 2020 at 5:28 PM
    #70
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I feel like my dealer was right at or less than Amazon. So I went with what I trusted.
  11. Oct 5, 2020 at 6:38 PM
    #71
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Aisin WS on Rockauto for $6/qt. Used it on second gen with no problem. I've read online that it's identical to Toyota WS.
  12. Oct 5, 2020 at 7:18 PM
    #72
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    I found Idemitsu TLS-LV for about $6 bucks a quart at Autozone. Idemitsu TLS-LV is meant for only Toyota WS applications, and its fully synthetic. Not widely known here in the US, Idemitsu is readily known and available throughout Japan. Isn’t Toyota Japanese??
    DAS Taco likes this.
  13. Oct 5, 2020 at 8:48 PM
    #73
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    japanese name, built in mexico
  14. Oct 6, 2020 at 6:12 AM
    #74
    zoo truck
    None
    From what i gather those ws atf's are probably formulated closer to work with their japanese vehicles than the popular aftermarket brands sold here in the u.s....The question becomes if truly the same or not. All i can say and have heard toyota aisin transmissions are finicky compared to others.
  15. Oct 6, 2020 at 7:31 AM
    #75
    splitbolt
    NW Arkansas
    I've heard the way Flex lock operates is unique to Toyota; differing from other partial lock systems. One could suppose this makes the torque converter clutch particular about the fluid it uses. Then again, non-Toyota OEMs spec ATF WS as well.
  16. Jul 16, 2023 at 11:51 PM
    #76
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    Definitely going with a Full Synthetic for the ATF. Do you recommend Lubegard or Valvoline MaxLife?
    Btw any recommendations for the Motor Oil 5w-30 for full synthetic from your personal experience?
    Thank you so much for any help.
  17. Jul 17, 2023 at 4:01 AM
    #77
    zoo truck
    None
    It's when you do these 3-4 qt drain, and refills mixing some of these supposedly compatible aftermarket atf's with the rest of the toyota stuff thats still in there is where problems can happen. May not show up right away....might take a few thousand miles.
  18. Jul 25, 2023 at 4:43 PM
    #78
    MrTravelDog
    MrTravelDog Member
    Pat
    Katy, Tx.
    2023 Tacoma TRD Off-Road
    2” Lift
    Just bought my first Tacoma a 2023 TRD OR after putting 210k on a 2003 Tahoe Z71. I ran synthetic ATF in my Tahoe for about 195k of those miles. Other than routine maintenance that transmission never had an issue. I have a 2014 Lexus ES that we picked up last year and currently researching the best synthetic for it.
  19. Jul 25, 2023 at 5:52 PM
    #79
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Another great thread, old but really good info. Especially about the quality of WS fluid. I’m definitely doing a drain and refill on mine when I get back home. Don’t care that she only has 389 miles. I’m going with Amsoil Signature Series.
