Synthetic vs Conventional Oil?
Discussion in 'Performance and Tuning' started by FishWolf, Jan 22, 2022.
Thread Status:
Not open for further replies.
  1. Jan 22, 2022 at 12:35 AM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Any thoughts on best oil to use in Toyota Tacomas?
  2. Jan 22, 2022 at 8:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Jan 22, 2022 at 12:27 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I use cooking oil.
    Reggie4x4 and mattrussmill like this.
  4. Jan 22, 2022 at 12:28 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    :deadhorse:
    Nevin likes this.
  5. Jan 22, 2022 at 12:28 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    This is such a yesterday thread!
  6. Jan 22, 2022 at 12:29 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Stick with your octane question, no brain, no pain.
  7. Jan 22, 2022 at 12:30 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I like super tech conventional. You get a 3,000 mi interval warning because the valve train starts to get noisy around then :burp:
  8. Jan 22, 2022 at 12:33 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
Thread Status:
