Synthetic vs regular
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceTaco, Jan 20, 2013.
What oil are you using
Poll closed Apr 20, 2013.
  1. Synthetic
    224 vote(s)
    76.2%
  2. Regular
    70 vote(s)
    23.8%
  1. Apr 5, 2013 at 9:41 PM
    #81
    Twatwaffles
    Twatwaffles Well-Known Member
    Do you think the dealer knows anything about petrochemical engineering? Neither does your typical mechanic.
  2. Apr 6, 2013 at 3:17 AM
    #82
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    Holy $#%* His username is twatwaffles. I'm laughing my ass off.
  3. Apr 6, 2013 at 4:31 AM
    #83
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    twatwaffles, synthetic oil, milage. It's all the same
  4. Apr 6, 2013 at 5:25 AM
    #84
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    ^^^^ made me think of this
  5. Apr 6, 2013 at 9:41 AM
    #85
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    When I had the BMW x3 it used 7.5 litres for an oil change. Dealer uses synth. Once the warranty runs out, with the $60 filter kit you are looking at a $300+ oil change. Quickie lube shops won't touch it cause it doesn't have a dipstick.
    You think long and hard about whether to invest in 8 L/ qts of synth. I could do at least 2 natural oil changes in materials alone, do it more frequently, and have cleaner oil.
    Re breaking-in ... My motorcycle has its first maintenance at 3000km. At that time the dealer recommends synth, but not before.
    If its frigging cold where you live synth is way better for cold starts. If you live in Texas, the higher temp tolerance is better on synth. However water cooled engines even in hot climates stay in a narrow temperature zone.
    I'd vote regular oil and change often. Even synth contaminates at the same rate as natural oil, so you still have to change it to flush the dirty oil. Synth may keep its lubricating properties longer, but dirty oil is just that.
    Air cooled motorcycle ... Synth al, the way due to potentially higher engine temps in hot weather and city speeds.
    Heavy service situations like 4wd in 2lo high revs and odd angles, synth as an ace up the sleeve for any added value. same for towing that 4500 lb trailer.
    Commuting. Just the regular please.
    Depends on how you use it
  6. Apr 6, 2013 at 10:07 AM
    #86
    Twatwaffles
    Frequent initial oil changes on motorbikes is recommended because the crankcase shares the oil with the gearbox and clutch. There's more particulates present in the initial break-in period of your motorbike, which is why its often recommended to change the oil within the first 1000 km's of riding, and again at 1500-2000. This is not the case with automotive applications. Using a more expensive synthetic right away doesn't make sense from a financial standpoint in this case.
    Again, like you said, it's all about the cold starts. They operate in a narrow temperature zone - once they're up to temperature.
  7. Apr 21, 2013 at 9:54 PM
    #87
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Shell Rotella T6 full synthetic.
    Better engine wear protection, increased MPG & oil change intervals (5K).
  8. Apr 21, 2013 at 10:06 PM
    #88
    LadTacoma
    LadTacoma Well-Known Member
    Ray
    NJ
    Prime Mover
    wow, this thread is hot like full synthetic oil change! lol anyways, brothers...I have been using full synthetic oil for three years now. I just feel at ease knowing I'm using the best product for my HOT TACO! lol
