synthetic...?
Discussion in '1st Gen. Tacomas (1995-2004)' started by caligrown8, Feb 16, 2015.
  1. Feb 17, 2015 at 12:44 PM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I wont mention my Brad Penn oil then,, if price scares you.
  2. Feb 17, 2015 at 1:42 PM
    SAMROD87
    SAMROD87 Well-Known Member
    Sam
    Coachella
    99 SR5 4x4 / 2016 White TRD off road 4x4 DCSB
    Looked up the Redline and it aint that bad in price and yes the Heat is a concern low temps not so worried about, lowest we usually get down to is mid 30's a couple times a year.
  3. Feb 17, 2015 at 3:24 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Royal Purple and a Wix filter...NASCAR approved.
  4. Feb 17, 2015 at 3:50 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Definitely switch! I have an 01 Double Cab V6 Prerunner. About to tick over to 187k miles and just switched on my last oil change. Truck would vibrate some while at red lights. Now it doesn't do it. BTW, I used Mobil 1 Full Synthetic High Mileage 5w30
  5. Feb 18, 2015 at 4:06 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I'm not scared to go synthetic. Truck has 170xxx miles so far on Dino and semi Dino, whichever was decent price at Walmart. Going with Shell t6 5w40 "synthetic diesel oil" also from the Walmart. Switching over the 1994 miata at 207k and 2003 protege with 180k. Heck even my dr650. This way I just have to worry about using one oil when they start leaking.
  6. Feb 20, 2015 at 4:27 AM
    off road
    off road Well-Known Member
    So Calif
    2015 Double Cab TRD OR 4X4 & 2013 Reg Cab Base 4X4
    Pray tell us what brand of oil you switched to....
    Most likely your clapped out old engine was leaking all along, and you just began really paying attention to it when you did the oil switch. In any case, one uncontrolled experience by one guy, doesn't exactly constitute a valid scientific experiment.
  7. Feb 20, 2015 at 5:47 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    My 95.5 has only seen mobil 1 5w30 since it's first oil change at 500 original miles in 1995. I can't compare because it's still here like new.
    [​IMG] The pic is with 277,000. I just hit 301,000!!!!
  8. Feb 20, 2015 at 1:08 PM
    tacolover87
    tacolover87 Well-Known Member
    Eugene, Oregon
    2005 DCSB TRD Sport
    Mobil 1. It was a perfectly good engine and soon as I changed back to regular oil it stopped leaking. I switched back because a well known engine builder told me it was common to experience leaks when switching to synthetic. Since then I have learned it is extremely common so I don't understand what it is you are trying to refute. Already several people on here have chimed in with same experience. I may not have the most experience, but I did spend several years as a mechanic rebuilding engines and hydraulic systems.
  9. Feb 20, 2015 at 6:22 PM
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    I've been running synthetic in mine for about 70,000 miles and my current oil of choice is Pennzoil Platinum Pure Plus. It is a pretty good oil and I have tried Mobil 1 5w-30 and Mobil 1 0w-40 which is their best oil but I noticed more valve train noise with both. I will agree with most guys saying it will cause oil leaks but I'm cool with that. I would like to be better protected than dino oil.
  10. Feb 20, 2015 at 6:50 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    From my understanding the risk for leaks is highest with when you run an engine a long time on conventional oil and then switch to synthetic. The exchange of the oils, and their chemical properties, that have seeped into the seals is what causes the issue from my understanding. If you run a truck on synthetic oil from the first change though, and run the same oil weight and manufacturer every time, you won't have the same issues with leaks.
    That was told to me by a couple of shop hands years ago. It could be wrong but I've never seen a vehicle leak oil after 200,000 km's of consistent changes with either Mobil 1, Coop Gold, or Pennzoil Platinum. If any of those were dissolving seals I'd think after that span I'd notice on the work trucks I see in our fleet.
  11. Feb 20, 2015 at 6:53 PM
    tacolover87
    Eugene, Oregon
    2005 DCSB TRD Sport
    That seems to be the general consensus by most, but it sure seems to rustle some feathers on the interwebs
  12. Feb 21, 2015 at 3:23 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Kudos to you sir. Looks great.
  13. Feb 21, 2015 at 7:02 AM
    Andy.G
    Andy
    Virginia
    Thanx. I took a chance with synthetic in 1995. Not much known about syn. then. Saw a info commercial and decided to try. Worked out fine. Also still original timing chain with 301,xxx!!
  14. Feb 21, 2015 at 7:52 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    You do know Brad Penn destroys catalytic convertors.
