T/C Spindles + Icon Coilovers set at 0"
Discussion in 'Suspension' started by arkane, Aug 10, 2009.
  1. Aug 10, 2009 at 4:21 PM
    arkane
    arkane [OP] Active Member
    OC, SoCal
    PreRunner Off-Road
    The T/C spindles add 3.5" of lift and the Icon coilovers add 0-3.5" of lift. Combining the two adds anywhere from 3.5" - 7.0" of lift.
    Let's say I have T/C UCAs and the extended length Icon coilovers. How would the off-road rideabilty with ONLY the Icon coilovers set at the max 3.5" compare with the T/C spindles with Icons set at zero inches? Net lift for both setups is 3.5". If I'm only looking to add 3-3.5" max is there a benifit to upgrading the spindles? Or would that be a waste of $1000?
  2. Aug 10, 2009 at 4:44 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    You should pm bermise he's running TC Spindels and Icon Extended Travel C/O's.
  3. Aug 10, 2009 at 4:48 PM
    Kenny650
    Kenny650 Well-Known Member
    I would imagine Icon Coilover's riding like a Cadillac suspension set at 0" lift.
  4. Aug 10, 2009 at 4:49 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    I say do it. What have ya got to lose. Try it lifted max then run it abour 1" on the coilovers.
  5. Aug 10, 2009 at 5:15 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    It rides awesome. I have had my coilovers set at .5" & at 1.5" and it rode the same both ways. I never had just coilovers only so I can not say how that would compare. I did have adjustable bilstein shocks and the OME coil & shock setup before this and it rode like crap compared to how it is now. The only thing to keep in mind is that if you set your co's that low with spindles you will need adjustable uca's, like TC heim joint uca's or Icon uca's. That last sentence would have saved me $1,000 if I would have known that before I got my setup.
  6. Aug 10, 2009 at 6:49 PM
    Kenny650
    I thought if you had your coilovers set ABOVE 2.5 inches then you will need new UCA's?? :confused: Spindles keep the same specs as stock so I don't think there's a need for UCA's unless you go full 3 inches.
  7. Aug 10, 2009 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You are correct. You dont need the UCA's unless you set the CO's over 2" or so.
  8. Aug 10, 2009 at 9:15 PM
    bermise
    Houston
    08 TRD off road
    uca's are not just for correcting alignment issues. They are stronger than stock and allow for addtional suspension travel.The OP wants extended travel icons which do require aftermarket uca's for the extra travel.
  9. Aug 11, 2009 at 6:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt see the "Extended travle" part. :eek:
  10. Aug 11, 2009 at 8:05 AM
    bermise
    Houston
    08 TRD off road
    It's ok, we forgive you. :cheers:
  11. Aug 11, 2009 at 8:08 AM
    bermise
    Houston
    08 TRD off road
  12. Aug 11, 2009 at 12:02 PM
    Kenny650
    ^ I don't get it :confused:
  13. Aug 11, 2009 at 12:16 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    i got the camburg lift spindeles and i have my CO set at 1".... It rides really nice on and off the road... post some pics when u get a chance....
  14. Aug 11, 2009 at 2:03 PM
    bermise
    Houston
    08 TRD off road
    You have 5 inches up front and a 1.5 AAL in the rear? How bad is the bro lift? I have 5 inches up front and about 3 in the rear and my front sits higher.
  15. Aug 11, 2009 at 4:15 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Lol the bro lift isn't bad... I hav seen worse lol... Check out my pics and tell me what u think...
  16. Aug 11, 2009 at 8:22 PM
    waltonhockey17
    waltonhockey17 Well-Known Member
    Alex
    georgia
    08 DC Red Taco
    4" camburg spindles, billys at 0", 16" xd hoss rims, 285/75/16 xtreme mud terrains
    Could you put camburg spindles with the adjustable bilsteins at like 1"?
  17. Aug 11, 2009 at 9:50 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Yea... I don't see y not... As far as I know it should... I mean coil overs r coilovers...
