T-case actuator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wampas cat, Aug 16, 2022.
  1. Aug 16, 2022 at 5:20 PM
    Wampas cat
    Wampas cat [OP] Member
    Kevin
    2017 Tacoma trd offroad
    So this past spring I had trouble with my truck, it wouldn't shift out of 4wd.,so I took the t-case actuator apart and took the gears out,pushed the shifting rod in 2wd,put the lid back on it and plugged the wires and vacuum hose up and drove it. Fast forward to today, put the gears back in,made sure they were in time and put it all back together. It will shift into both 4 hi and 4 lo, it won't shift out of 4wd, same problem as before, anyone have any idea what could be wrong?
  2. Aug 16, 2022 at 5:24 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Are you sure you don't have a problem with the ADD actuator? Tcase issues are pretty uncommon. ADD are relatively common.
  3. Aug 16, 2022 at 5:26 PM
    Wampas cat
    Kevin
    I don't know, how can I find out, and thanks for replying.
  4. Aug 16, 2022 at 5:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
