T-Case shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jflan, Sep 28, 2009.
  1. Sep 28, 2009 at 7:30 PM
    jflan
    jflan [OP] Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I came from manual shifters in Jeeps and this dash-mounted dial is just plain weird to get used to.
    I found that I can get into Low Range fairly easily buy shutting down and restarting (with the dial indicating Low Range). It usually goes right in.
    Going the other way from 4 low to 2 high is another story.
    Lots of *monkeying around to get the thing out of 4WD.
    I know, RTFM :eek: , but is there a real world recipe on how to get in and out of 4 low without the *monkeying and warning buzzers etc. ?
    *monkeying:
    Forward, backward, shift out, shift in, shift out, etc, etc.
  2. Sep 28, 2009 at 8:40 PM
    Faskev
    Faskev Well-Known Member
    I usually have good luck with putting the truck in neutral on flat level ground then turning the dial from 4 Lo to 2 Hi. Any uneven road or incline seems to make shifting out of 4 Lo more difficult.
  3. Sep 28, 2009 at 8:42 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Stop, neutral, switch. No problems whatsoever, in or out of 4LO. Wait for it to go completely in or out.
  4. Sep 30, 2009 at 5:35 AM
    jflan
    Vancouver, WA
    Thanks guys, I try that.
  5. Sep 30, 2009 at 10:25 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Its a lot easier than you're making it.. RTFM.
  6. Sep 30, 2009 at 5:13 PM
    jflan
    Vancouver, WA
    Maybe there's something wrong with mine....
    Tried it in neutral and level....wouldn't even go into 4Hi :mad:
    Was at work and didn't have time to fool with it.
  7. Sep 30, 2009 at 6:44 PM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    I also like the old fashioned manual locking hubs with the floor shift. I don't know if your Owner's Manual is the same as the one for my 2008; however, page 177 on mine explains "Shifting procedure (with manual transmission)" pretty nicely. Hope that helps.
  8. Sep 30, 2009 at 8:06 PM
    jflan
    Vancouver, WA
    Yeah, I guess I'll havta break down and RTFM :eek:
    Mmmm......levers :p
