T-Harness Blowing Fuses
Discussion in 'Towing' started by rooftopfall, Jan 19, 2011.
  1. Jan 19, 2011 at 8:12 AM
    rooftopfall
    rooftopfall [OP] Member
    Manchester, CT
    06 Double Cab SR5 6-Speed
    2" front Skyjacker spacers 2" Toytec rear AALs Rancho RS5000 front shocks Skyjacker Nitro8000 rear shocks Flowmaster American Thunder Dual-Exit Exhaust 265/75R16 BFG A/T KO's K&N Drop-In Filter BHLM GROM iPod interface
    I want to post this before I go and buy a new harness to see if anyone has some advice/previous experience with this: I have a Curt T-Harness for my 06 taco that I installed myself and worked very well when I first got it. When installing it I couldn't find a good spot for the grounding wire (the instructions were not helpful for this) and so I bolted it into one of the existing holes inside the quarter panel even though I knew this was probably wrong. Then, after it rained a few times, several fuses blew which caused my brake/dash lights to act up. I replaced the fuses and pulled out the harness because it was the only electrical mod I had done to the truck and really was the only explanation for the blown fuses especially knowing that I most likely had an improper ground. Everything has worked fine since, but now I am moving and need to hook up a trailer once again.
    Should I try wiring up the old harness with a proper ground? If not, does anyone know where I could get a cheap yet reliable t-harness (AutoAnything.com has Curt for $53 shipped)? Also, where can I properly ground the thing? Thanks!
  2. Jan 4, 2012 at 6:42 AM
    Sighless
    Sighless Well-Known Member
    TORONTO
    10 SR5
    i have the same problem.. i also used a spare bolt inside the fender behind the tail light..
    when i hit my brakes, my parking lamps come on... when i use the left turn signal, my parking lamps flash..
  3. Jan 4, 2012 at 6:49 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bad ground.
  4. Jan 4, 2012 at 11:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If your blowing fuses not likely a bad ground, you've got a short somewhere, bad grounds end continuity (completing circuits) & bad grounds can spark (at the point of contact or lack-thereof) but don't blow fuses, break out the multi meter & start reverse hopscotching (last point of power) tracing shit out, sounds like your plug is possibly your issue.....;)
  5. Jan 5, 2012 at 12:26 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    i just put mine in last night haven't had any issues today,but i buffed the black paint on the taillight inside housing to make sure i got a good ground.
  6. Jan 5, 2012 at 12:42 AM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    One of the postives in the t harness is exposed and hitting the body/frame of the ground, short circuiting your system. Go through your positive wires and see which one is touching, and make sure you find a good grounding.
