T.R.D. Tacoma - Developed for Off Road Racing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Oct 22, 2021.
  1. Oct 22, 2021 at 8:05 PM
    #41
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    si senor!
    Very nice man. Never seen that one before.
    tacotoe and shakerhood like this.
  2. Oct 22, 2021 at 8:05 PM
    #42
    Bishop84
    Bishop84 Well-Known Member
    Working on disc brake internal parking brake sucks way more.
    The new EPB on all the toyotas including tunrda will save us from this.
    People think that the FJ and 4runners are simple disc brakes but they are a nightmare for a DIY to repair.
  3. Oct 22, 2021 at 8:11 PM
    #43
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    DrUm bRaKes KeEp DirT oUt
  4. Oct 22, 2021 at 10:01 PM
    #44
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    It’s only when I use the parking brake. I’m well aware of this issue with wet drum brakes flash rusting, but this is not that. This problem is somewhat self-inflicted as when the shop that put my lift on initially installed it, they did not slacken off the parking brake cable to compensate, so I had random wheel lock-ups for a while. These wheel lock-ups bent something on the backing plate that has plagued this one wheel for a long time. As the shoes have worn down it’s gotten a little worse. Every so often it sticks when releasing the parking brake, even when dry, and it’s not the cable. It’s like one part moves just a little too far, or has a little bit of play it shouldn’t have. I was hoping to figure out just what is bent or loose and tune it up a little. A new axle and backing plate is $2000 or something so I don’t really want to buy the whole assembly.
    Junkhead, tacotoe and shakerhood like this.
  5. Oct 22, 2021 at 10:03 PM
    #45
    Stocklocker
    17TRDORDCSBAT
    I love that beer. Worthy of the hype.
    Junkhead[QUOTED] and tacotoe like this.
  6. Oct 22, 2021 at 10:07 PM
    #46
    Stocklocker
    17TRDORDCSBAT
    I have tried to do this with it assembled, but have not yet disassembled it all. Trying to figure out what I’m up against to do that. Someone said somewhere here you need techstream if you have to bleed the rear brakes, so I’m a little nervous. Just trying to get the “lay of the land” under the drums as I’m no expert (yet) on what goes on in there. They are a bit intimidating, admittedly, to look at with all the springs and plates, and levers, and worm screws and other shit in there. I’m sure to a mechanic’s eyes it’s all easy, but I gotta start slow.
  7. Oct 22, 2021 at 10:09 PM
    #47
    Stocklocker
    17TRDORDCSBAT
    Junkhead and tacotoe like this.
  8. Oct 22, 2021 at 10:20 PM
    #48
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    Closest thing that is decent at the 7-11. Also exploring my new compressor.
  9. Oct 22, 2021 at 10:21 PM
    #49
    Stocklocker
    17TRDORDCSBAT
  10. Oct 22, 2021 at 10:33 PM
    #50
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Can I put a caliper on my drum since its the same shape as a rotor?
  11. Oct 22, 2021 at 10:34 PM
    #51
    Stocklocker
    17TRDORDCSBAT
    Wheel spacers mean you are gonna die according to TW
  12. Oct 22, 2021 at 10:40 PM
    #52
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I understand being intimidated, it looks worse that it really is. Buy a few tools and take your time, remember the other side isn't identical, it is a mirror image. For a dissemble/clean/inspect/lube/reassemble you shouldn't need to bleed the brakes.
    You will need the three tools below. All are available at your local NAPA store, maybe $20 for all of them.
    Left: Shoe hold down tool
    Center: Brake spring pliers
    Right: Brake spoon -- turns the star wheel to set the shoe clearance with the drum on
    While you are there pick up some brake grease too. Keep the bottle capped and it will last you decades.
    And a can of cleaner too, this stuff is quite useful for more than just brakes, might as well get 2 cans.
    eurowner, Junkhead, tacotoe and 2 others like this.
  13. Oct 22, 2021 at 10:49 PM
    #53
    Stocklocker
    17TRDORDCSBAT
    Thanks man. I really appreciate this advice. I’ve got the brake cleaner and grease, but gotta pick up the tools for sure.
  14. Oct 22, 2021 at 11:53 PM
    #54
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    No shit Sherlock. I’m not trolling, we’re both saying essentially the same thing.
    Junkhead, tacotoe and Stocklocker[OP] like this.
  15. Oct 23, 2021 at 12:06 AM
    #55
    Stocklocker
    17TRDORDCSBAT
    I think the somewhat missed sarcasm of my original post ended up infecting the whole thread. Everyone gets a pass in this thread. We are all in it together with our drum brakes.
    BurlyJim, 604, shakerhood and 5 others like this.
  16. Oct 23, 2021 at 12:59 AM
    #56
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    I wonder if I can drill out some old integra rear disk breaks for 6 lug and fit them on my Tacoma…:burp:
  17. Oct 23, 2021 at 1:21 AM
    #57
    Stocklocker
    17TRDORDCSBAT
  18. Oct 23, 2021 at 2:24 AM
    #58
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Stocklocker[OP] and tacotoe like this.
  19. Oct 23, 2021 at 4:24 AM
    #59
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    I can't believe I read through three pages trying to find a meaningful point to this thread.
  20. Oct 23, 2021 at 6:28 AM
    #60
    RustyGreen
    sleeping in a chair
    Pavement Princess
    If we didn't:deadhorse:around here there would be damn little going on... :fistbump:
